Tip & How-To about Heating & Cooling
I have a standing pilot that wont stay lit.
If you have a standing pilot that wont stay lit and you have to keep relighting it, it can only be a couple of things that will do this.
1. Try tighting the thermocouple at the gas valve. (this is a thin copper line that goes from the gas valve and goes to the pilot light.)
2. Make sure that the tip of the thermocouple is in the pilot light flame.
3. Make sure that the thermocouple is clean.
if you have done these and it still doesnt stay lit, buy a new thermocouple.
Heating & Cooling Logo
pilot on furnace wont stay lit
Sounds like the thermocouple is shot
Nov 09, 2014 | Dayton Gas Furnace Heater
My Kozy heater turns off after a few minutes, I then have to re light it and when it kicks on again after a few mins it turns off again. It will stay lite if I turn it down but when it goes on agin it will turn off again
Mar 22, 2011 | The Companion Group Kozy World Portable...
hello, i lite the pillot and and start up fire so its working and some time during the day the pillot goes out?
Mar 21, 2011 | Heating & Cooling
im calling for heat from the thermastat and control panel, the boiler light and and the fan is running, but no matter how many times i keep re trying the pilot and burner will not commence, is there anything more i can do
I would check to make sure control on gas valve is in on position and pilot is lit if you have a standing pilot. If you have a spark or hot surface ignitor make sure they are trying to lit pilot. If you have standing pilot model and pilot lit is not on. Turn control on gas valve to off,wait five mins. then turn to pilot. Depress botton and try to light pilot. If it lights hold down for a couple of mins. then release.. If pilot stays lit turn control to on. If thermostat is calling for heat this should bring main burner on. If pilot does not stay lit then replace thermocouple. Hope this helps. Thanks
Nov 16, 2010 | Heating & Cooling
pilot blights wont stay lit on older model American gas range
Take a very small wire and clean out the pilot holes. Then find the pilot flame adjustment screw and re-set your pilot to 1/4 inch flame.
Mar 24, 2009 | Kitchen Ranges
1,308 people viewed this tip
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
