Tip & How-To about Computers & Internet
Enjoy DVD Movie on iPad2, iPad
Apple fans' new pet iPad2 has released with several newest features: lighter body, new display technology, faster processor, improved graphics, front and rear cameras, etc. Share home movies with your family or friends or watch hot movies on the flight with iPad2 is every fan's thought.
Everybody wants to enjoy favorite DVD movies on the go. However, How to do that?
Before enjoy movie on iPad, we should know about what video formats iPad supported. Just the same as iPad, iPad2 support H.264 video, up to 720p, 30 frames per second, main profile level 3.1 with AAC-LC audio up to 160kbps, 48kHz, stereo audio in m4vm, mp4 and mov file format. And MPEG4 video, up to 2.5 Mbps, 640 by 480 pixels, 30 frames per second, Simple Profile with AAC-LC audio up to 160 Kbps, 48kHz, stereo audio in .m4v, .mp4, and .mov file formats; Therefore, if we want to enjoy DVD video on iPad2, we have to change DVD video to H.264 video or MPEG4.
If you had got iPad2 and can't wait to putting DVD movie on iPad2, please use Tenorshare DVD to iPad2 converter to help you convert the video. Besides convert video, Tenorshare DVD to iPad2 video converter also can edit DVD video by changing the brightness, contrast, size of the video and so on.
Here is the step by step guide how to about to use Tenorshare DVD to iPad2 and tips about edit DVD movie.
Step1. Click "files" to load DVD disc
Step2. Select iPad output format from the Profile
Step3. Click "Setting" button to set the parameters of your output video to get the most perfect quality.
Step4. Click "Start" button to start conversion
Tips about editing DVD movie
1.Crop movie
If you want to share movie on iPad2 with full screen, use the function of cropping movie. Tenorshare DVD to iPad2 video converter offers two options for you: Adjust the crop frame or set the crop value. The crop frame is the dashed line around the movie video. There are four adjustment lines on the crop frame. Each line allows you to crop the movie video from a different position. Or you can just set the value to get what your wanted.
2.Trim movie
Sometimes you only want to get one part of the movie to iPad2. Then you can use the function of trimming movie. Trim a duration of the selected title or chapter by either dragging the Start Time and End Time or setting the time parameters in each corresponding field.
3.Add text or image watermark to the movie
Tenorshare DVD to iPad2 video converter allows you to add text or image watermark to the movie. You can upload your favorite images or just one famous saying to the movie.
4.Change movie effect
Everybody loves something new. Especially something special, Use the function of change movie effect including changing the contrast, brightness, contrast of the DVD movie to enjoy personalized movie on iPad2.
Computers & Internet Logo
I can upgrade to windows 7 in my n1000
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Personally i would recommend to upgrade ram then install win 7
Regards
Uttam
Windows 7 requirement If you want to run Windows 7 on your PC, here's what it takes:
  • 1 gigahertz (GHz) or faster 32-bit (x86) or 64-bit (x64) processor
  • 1 gigabyte (GB) RAM (32-bit) or 2 GB RAM (64-bit)
  • 16 GB available hard disk space (32-bit) or 20 GB (64-bit)
  • DirectX 9 graphics device with WDDM 1.0 or higher driver
http://www.microsoft.com/windows/windows-7/get/system-requirements.aspx
Here is you laptop spec
Processor Processor Intel Pentium M 733 / 1.1 GHz
  • Core voltage technology Ultra Low Voltage (ULV)
  • Data bus speed 400.0 MHz
  • Processor features Enhanced SpeedStep technology , Power-optimized processor system bus
  • Chipset type Intel 855GME
Cache Memory Type L2 cache
  • Cache size 2.0 MB
RAM Installed Size 512.0 MB / 2.0 GB (max)
  • Technology DDR SDRAM - 333.0 MHz
  • Memory specification compliance PC2700
Video Graphics Processor / Vendor Intel Extreme Graphics 2
  • Video Memory Dynamic Video Memory Technology 2.0
Operating System / Software
  • OS Provided Microsoft Windows XP Professional
  • Software Drivers & Utilities
Dec 10, 2009 | Averatec 1000 Notebook
what are the compatible processor for asus p5p800 mx
Asus P5P800-MX Motherboard Features
64bit CPU support
64-bit computing, the next generation technology to replace current 32-bit architecture, delivers advanced system performance, faster memory access and increased productivity. This motherboard provides excellent compatibility and flexibility by supporting either 64-bit or 32-bit architecture.
Intel EM64T
Intel EM64T (Intel Extended Memory 64 Technology) allows processors to run newly written 64-bit code and to access larger amounts of memory, which delivers exceptional graphic performance and higher data processing speed. Digital media applications can take advantage of Intel EM64T in high quality video and audio processing as well as 3D rendering.
Intel EIST
Intel EIST (Enhanced Intel SpeedStep technology) automatically adjusts Intel 64-bit processor voltage and core frequency according to system performance demand, establishing a self-managed, lower-power consumption, less heat and quieter environment. Combined Intel EIST and ASUS Q-fan technology (adjusts fan speeds according to system loading), this motherboard provides excellently quiet, cool and efficient platform for Intel lovers.
Intel 865GV chipset
Leveraging the Intel 865GV chipset to support P4 CPU on 800MHz FSB, Dual-channel DDR 400 memory, Intel Hyper-Threading Technology, and a full-range of advanced features, P5P800-MX really delivers a full-value, high-performance solution for today's most demanding tasks.
Intel LGA775 Pentium 4 CPU
This motherboard supports the latest Pentium 4 CPU from Intel in LGA775 package. With 800MHz FSB, 1 MB L2 cache, Hyper-Threading Technology and core-speeds up to 3.6GHz and beyond, Intel's LGA775 Pentium 4 is one of the fastest desktop processors to date.
Jul 27, 2009 | ASUS Computers & Internet
201 people viewed this tip
David Payne
David Payne
