Tip & How-To about Audio Players & Recorders
IPod hookup to Home audio system
More people these days seem to want to connect their iPod to a home amplifier setup and so there are more units being sold to do so but for those folks who have an older stereo or amp/receiver there is a way to do this. All you need is a little adapter cable sold at Radio Shack or online at Amazon.com which connects iPod to audio amp/receiver. Just plug the 3.5mm stereo male end into the iPod earphone jack and the other end with the 2 RCA plugs, red and white, into an available input on the amp or receiver (CD or AUX for example) and adjust the volume. Be sure to select the input on the receiver where you connected the iPod.
For $2 at Amazon.com, get this cable.
2005 Toyota Sienna. Radio turns on, can see station or CD, but no sound from speakers at all. Complete silence. Just one day, stopped working while driving.
If you have a multi-speaker setup like my 4Runner (also an 2005) Toyota uses a separate amplifier; i.e. not built into the the head unit (radio). The only home solution would be to clean the contacts where all the plugs connect. Back of the head unit, and the amplifier. If this doesn't fix it the amplifier probably has failed or the electronics in the head unit. Don't forget to disconnect the negative battery cable before doing any of this work, and make sure you have the security codes for the radio before you disconnect.
Nov 25, 2014 | 2005 Toyota Sienna LE
My car stereo
Many options are available to connect your iPod to your car stereo. Back on September 7, 2005, Apple reported that approximately 30% of new cars sold in the US in 2006 would offer seamless integration with the iPod, and that number has been steadily increasing since then. In 2008, Apple heralded that "over 90 percent of new cars sold in the United States have an option for iPod connectivity".
As a result, third-party solutions have become less and less necessary for those lucky enough to be able to afford new or newer cars. Regardless, a round up of options still may be useful for those with older vehicles and/or limited budgets.
Jul 29, 2012 | Alpine MRP-F300 Car Audio Amplifier
everytime i hook ipod upthe powere cuts off
Possible that the ipod is giving some errors like a high input which is not matching to the amplifier and so make the protection cut off.
Reduce the voltage of the ipod, connect the ipod using a cord that has a impedance matching circuit to the input of the amplifier.
if you are using the earphone output to the aux input it is a mismatch, so the impedance must be matched with a resistor network.... converting a low to a high impedance.
Sep 29, 2010 | Panasonic Home Theater System System
MTX Thunder 3401 not responding. Lit but no sound.
turn down music open sub box and put another speaker at wire and check again if work means sub is ok if not check the signal cable, and put there the speaker to try signal
Apr 05, 2010 | MTX Thunder 3401 Car Audio Amplifier
334 people viewed this tip
 Grubhead
Grubhead
