Tip & How-To about Cell Phones
Palm Pre Plus tips and tricks
1. Soft Reset Hold the power button and cycle the ringer button on/off three times.
"Orange button" "Sym" and letter "R". It's like a Ctrl Alt Del for the Pre.
Another way is go into "Device Info" --> "Reset Options" At this point you have three choices:
a. Soft Reset -restarts it
b. Partial Erases -erases all installed apps and their data but not personal files stored in Mass USB drive mode.
c. Full Erease -Everything Partial erase does and personal files stored on USB partition.
3. Save Battery Life
Pre_with_battery
- Log out of AIM (There is some problem with AIM draining battery power that Palm is currently fixing. And plus, who really uses AIM these days?)
- Change your email settings. Note: each email account can be set-up in a different way.
Top on the upper left corner of the screen in the email program.
Open the Preferences menu.
Set frequently used accounts to check every 15 minutes.
Set rarely used accounts to Push.
- Turn on WiFi. (It's weird, but the Palm Pre has better battery life with WiFi than with 3G.)
4. Gestures
Tap
Swipe A horizontal gesture on the touchscreen or the gesture area. The most common swipe is "back", which is a swipe from the center of the phone to the left in the gesture area.
Drag Drag upward from the gesture area onto the touch screen to bring up the Quick Launch menu when you are in an application.
Flick
Scroll Speed sensitive. Tap or drag the screen while scrolling to stop.
Zoom Double tap on an image or area, or use two fingers in a pinch-like fashion.
5. Turn On Advanced Gestures
Go to "Screen & Lock" app
Turn on "Advanced gestures" setting
The advanced gestures allow you to scroll in between apps while they are open in fullscreen mode. Simply swipe from the far right the far left, or from the far left to the far right, in the gesture area to move between apps without going to the Card View first. The back gesture still goes from right to left in the gesture area, but it takes a shorter swipe from right to left (halfway).
6. Tap the Battery
Pre_popup
Tap the battery icon to see an exact percentage of remaining battery life, the date, WiFi options, Bluetooth settings, and Airplane Mode settings.
7. Uncapitalize a Letter
When typing, the Pre autocapitalizes letters where appropriate (beginning of a sentence, "I", etc...). To undo this, simply press backspace once. Rather than deleting the letter, it will change it to lower case. Pressing backspace again, obviously, will delete the letter.
8. Pre Recovery Tool Leak
This Pre hack applies mainly to the super tech-savy guys out there, particularly the developers. The "WebOS Reset Doctor" has leaked out (including the 195 MB webOS root). This means that you can now view the Pre's "hidden" code, which means you (or some really skilled developers somewhere) can find and tweek some hidden Pre features.
9. Sync the Palm Pre with iTunes
Simply connect the Palm Pre to your Mac or PC, select "Media Sync", and iTunes will auto-launch. You can then choose which DRM-free media files to transfer.
10. Use your Pre as a Mass Storage Drive
Simply connect your Pre to your Mac or PC with a USB cable, and the Pre will appear as a drive on your computer desktop. Drag and drop files into the Pre, or drag files from your Pre to the computer.
11. Solve Post-Shut Freeze
Pre_battery
Numerous people have reported that when you close the screen too hard, the phone becomes black yet backlit, and the only way out is to reboot. Turns out there is a problem with battery, because it becomes loose when you slide the screen down hard. Simply put a piece of paper on the top part of the battery between the battery and the phone.
12. Konami Code
Konami
This one is funny. To access the "secret" Palm Pre dev mode, simply type the famous Konami cheat code right from the launcher screen of your Pre. The code is "upupdowndownleftrightleftrightbastart". This opens something called "Developer Mode Enabler". This was discovered due to the leaked ROM (number 9 on this list). This allows you to connect the Pre to a computer running Palm's Mojo SDK for webOS, which allows you to do some dev stuff.
Cell Phones Logo
I can't hear the person Im talking to, but they can hear me.
Soft Reset Hold the power button and cycle the ringer button on/off three times then let go and it will reboot! it may work and wont hurt your device or delete any thing!
Mar 13, 2011 | Palm Pre Cell Phone
how do you reset your latptop?
You can perform a hard reset by pressing and holding the powered button for 5 seconds.
Please leave feed back if this helped you :)
Nov 12, 2010 | Computers & Internet
how to reboot my computer
Either press the "Reset Button" on machine. hold down the CTRL-ALT-DEL all at once. Remove/Turn Off Power. Or if at desktop from the "START" button and click on the Padlock at bottom and choose it from there. OR press CTRL-ALT-DEL and task manager will pop up... then choose reboot from the Shutdown Tab.
Jan 30, 2010 | HP Pavilion a1520n PC Desktop
how to soft boot a dell 4600
I used the reset button on my last one whenever ctrl/alt/del failed to soft boot
my computer.
Here is what Dell Chat tells me to do if ctrl/alt/del doesn't work:
Turn off the system from the power button. Remove the plug to the
power supply from the back off the system tower.Then hold the power
button on the tower down for 10 secs ( with the power cord removed).
Reconnect the power cord and then restart the system.This time do a
normal shutdown.
Regards,
Pp
Dec 02, 2009 | Dell Dimension 4600 PC Desktop
how do I reboot my mini
Hello, Abba.
Hard reboot your mini by pressing the power switch. On the front edge of the Mini 1000 are two switches. The switch on the left is for power.
Soft reboot by pressing the Alt-Ctrl-Del keys. Hold down the Alt and Ctrl and press Del.
Hope this helps.
Nov 24, 2009 | HP Mini 1000 Netbook
260 people viewed this tip
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
