Tip & How-To about Linksys Wireless-G WRT54G Router
Wireless Network Password - Linksys
If you are unable to connect your laptop wireless to your Linksys wireless access point/router, the easiest and fastest way to get going is to reset your router to the factory defaults. This will make your router work like the day you bought it.
There are 2 steps involved Reset your router, Setup/Secure a new router
Reset your router:
First
  • Unplug your DSL/Cable modem from power (not your access point/router) Leave this unplugged for now
Second
  • On the rear of your Linksys router you will find a small RESET button
  • With the power still on the router, Press and hold (with a pin/pen tip) the RESET button for 30 seconds.
  • Release the RESET button a wait 15 seconds for the router to reboot
almost done....
  • Unplug your Linksys router from power
  • Plug your DSL/Cable modem back in to power
  • Wait 1 minute for the modem to boot up
  • Be sure the ethernet (cat5) cable from your modem is securely plugged into the WAN port on the back of your Linksys router. This is usually labeled WAN or Internet above the jack
  • Plug your Linksys router back into power.
You will now be able to connect to the internet with your wireless device. I would advise that you follow the next steps in securing your wireless network.
Log into your router
  • Type 192.168.1.1 into your web browser and hit enter
  • In the login fields (case sensitive):
  • Username: leave_this_blank
  • Password: admin
  • Click OK
Once in the web interface for your router
  • Click Wireless tab - Basic Wireless Settings
  • Find the Wireless Network Name (SSID) field
  • change this to your new network name (this is the name you will see when you connect through your wireless device)
  • Find the Wireless Channel field
  • Change this from 6 (default) to 1 or 11
Magoo
Linksys Wireless-G WRT54G Router Logo
delete information on drive
There are 2 ways to reset the information on the Linksys WRT54GS.
One is by using its web interface and the other is by using the reset button on the back part of the device.
The reset option is the easiest and fastest, you will need a small pin/paperclip as it is a inset button.
Follow the procedure below:
1) Turn on the device.
2) Press and hold the reset button for at least 10 seconds.(IMPORTANT: Make sure that the Power LED of the router is blinking when you press the Reset button. This indicates that the router is being reset properly.)
3)After pressing the Reset button, unplug and re-plug the router's power adapter.
Oct 02, 2013 | Linksys Wrt54gs V7 2.4 Ghz 54 Mbps 4-port...
link led keeps on flahing and act led is not coming only
Try resetting the Linksys router.
To reset the Linksys back to the default settings - Press and hold the pinhole RESET button at the back of the router with the power ON for 20 secs. then release the RESET button.
To connect to your wireless router, the router's wireless settings needs to be configured with the SSID, encryption etc. and also the wireless cards in all the laptops/computers needs to be configured with these router's wireless settings. Then the laptops/desktop computers can communicate with your wireless router.
Connect a LAN cable from the Linksys to the LAN port on your computer.
Open a browser and enter the Linksys configuration URL
http://192.168.1.1
The default login = admin
The default PW = admin
You can protect your router by changing the default admin PW (write it down and put it in a safe place)
Go to the wireless configuration and set up the SSID and WPA or WPA2 encryption to protect your wireless network and Internet from unauthorized access.
Now apply these settings to the wireless card in your laptop/computer.
To secure your wireless network from unauthorized access, please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Mar 02, 2013 | Linksys Wireless-G WAP54G 802.11g/b...
i have a Linksys Wireless-G WAP54G 802.11g/b Wireless Access Point but when i connet to the laptop to configure it does not detect the access point . the Act light does not blinks nor the acess point gets reset . please provide me ur advice on it
Try reseting the Linksys back to the default settings - Press and hold the pinhole RESET button at the back of therouter with the power ON for 20 secs. then release the RESET button.
To connect to your wireless router, the router's wireless settings needs to beconfigured with the SSID, encryption etc. and also the wireless cards in allthe laptops/computers needs to be configured with these router's wirelesssettings. Then the laptops/desktop computers can communicate with your wirelessrouter.
http://192.168.1.1
You can protect your router by changing the default PW (write it down and putit in a safe place)
Go to the wireless configuration and set up the SSID and WPA or WPA2encryption.
Apply these settings to the wireless card in your laptop/computer.
To secure your wireless network from unauthorized access, please click on thislink and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Aug 15, 2011 | Linksys Wireless-G WAP54G 802.11g/b...
1,759 people viewed this tip
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
