Tip & How-To about Cell Phones
How to send Applications from One balckberry to Another blackberry?
BlackBerry applications are small programs that run on BlackBerry devices to help your phone perform more tasks than your operating system can do alone. Google Maps, Twitterberry and Facebook for BlackBerry are examples of such applications. When replacing or upgrading your BlackBerry, you may want to take your applications with you. To send them from one BlackBerry to another, use BlackBerry Desktop software. Instructions
  1. Open the BlackBerry Desktop software program on your computer.
  2. Connect the BlackBerry with the application on it to the computer using the USB cable.
  3. Click "Device" on the BlackBerry Desktop software. Click "Switch device."
  4. Select third-party applications in the list of items to be transferred. Click "Next."
  5. Replace the first BlackBerry with the BlackBerry you want to transfer the applications to. Click "Next." Disconnect the BlackBerry from the computer when the program indicates the process is done.
Cell Phones Logo
blackberry mobile has error102 on screen
You need to reinstall your device OS to regain access to your device.
Check steps below for OS upgrade -
Before starting make sure that BlackBerry Desktop Software is installed on the computer.
Make sure that you have installed updated device software installed in your PC. Check this link to get update device software from carrier OS download site.
Users can perform a full or selective backup of the data using the Backup and Restore tool in BlackBerry Desktop Manager by completing the following steps:
  1. Connect the BlackBerry device to the computer running BlackBerry Desktop Manager.
  2. Open BlackBerry Desktop Manager.
  3. Double-click Backup and Restore.
  4. Select Backup to perform a full backup or select Advanced to perform a backup of specific databases.
  5. Choose a location to save the backup file, then click Save.
To perform a clean install of the BlackBerry Device Software, perform the following steps:
  1. Connect the BlackBerry smartphone to the computer and open BlackBerry Desktop Manager.
  2. Double-click the Application Loader icon.
  3. Click Next to start the installation process.
  4. Type your BlackBerry smartphone password, if prompted, and click OK.
  5. Click the check boxes next to the names of the applications you want to load, and then click Next.
  6. Click Advanced, and then click the check box beside Erase all currently installed applications.
  7. Click Next.
  8. Click the check box next to Do not automatically backup the application data during the loading process.
  9. Clear the box next to Backup and restore applications installed wirelessly.
  10. Click Next > Finish.
  11. When the process has completed, the message The loading operation was successful will appear. Click Close to return to BlackBerry Desktop Manager.
Regards
Jun 28, 2011 | RIM BlackBerry Bold 9700 Smartphone
i get app error 523 every time on my blackberry 8220 pearl flip display
On the BlackBerry smartphone, the following error message appears after pressing the Mute button, accessing an application, or performing a hard reset:
523 app. error. Reset.
To resolve this issue, first perform a hard reset.
A hard reset involves physically removing the battery from the smartphone and then reinserting it. To perform a hard reset, complete the following steps:
1) Remove the battery cover from the back of the BlackBerry smartphone.
2) Remove the battery, and then reinsert it after a few seconds.
3) Replace the battery cover.
If this does not resolve the issue, the BlackBerry® Device Software must be re-installed.
Before proceeding, make sure that the latest version of BlackBerry Device Software is installed on the desktop computer by completing the following steps:
To perform a clean installation of the BlackBerry Device Software using BlackBerry Desktop Manager 4.5 to 5.0, perform the following steps:
  1. Open BlackBerry Desktop Manager.
  2. Click Help.
  3. Select About Desktop Manager.
  4. Click the Device Software tab.
  5. Verify that the BlackBerry Device Software displayed is the latest version currently available from the wireless service provider
Warning: The following procedure will delete either all data, or all data and applications on the BlackBerry smartphone. Back up the BlackBerry smartphone data before proceeding.
  2. Double-click Application Loader.
  5. Select the check boxes next to the names of the applications to be loaded, and then click Next.
  6. Click Settings, and then select the check boxes beside Delete all application data and Erase all currently installed applications.
  7. Clear the check box next to Backup up device data automatically during the installation process.
  8. Click Ok > Next > Finish.
  9. When the process has completed, the message The loading operation was successful will appear. Click Close to return to BlackBerry Desktop Manager.
To perform a clean installation of the BlackBerry Device Software using BlackBerry Desktop Manager 4.1 to 4.3, complete the steps 1-5 above and then proceed with the following:
  1. Click Advanced , and then select the check boxes beside Erase all application data and Erase all currently installed applications
  2. Click Next.
  3. Select the check box next to Do not automatically backup the application data during the loading process (if prompted).
  4. Clear the check box next to Backup and restore applications installed wirelessly (if prompted).
  5. Click Next > Finish.
The BlackBerry smartphone will not show a Connected state in the BlackBerry® Desktop Manager. Proceed to open and run the application loader tool.
If BlackBerry Desktop Manager cannot connect to the BlackBerry smartphone, perform the following steps:
  1. Remove the battery and run loader.exe from C:\Program files\Common Files\Research In Motion\AppLoader.
  2. Remember to reinsert the battery after the loading operations begin.
Oct 26, 2009 | RIM BlackBerry Pearl Flip 8220 Cellular...
how to reset blackberry7290 its pop up on the screen error reset 532 when i push the scroll before its operated im on the mood of exploring the phone i change the language from english i turn to portugues then immediately reset that flash on the screen i press the button okey/scroll but it always turn to error reset 532
smartphone.
1) Open BlackBerry Desktop Manager.
2) Click Help
3) Select About Desktop Manager.
4) Click the Device Software tab.
5) Verify that the BlackBerry Device Software displayed is the latest
version currently available from the wireless service provider.
1) Connect the BlackBerry smartphone to the computer and open
2) Double-click Application Loader.
3) Click Next to start the installation process.
4) Type your BlackBerry smartphone password, if prompted, and click
OK.
5) Select the check boxes next to the names of the applications to be
6) Click Settings, and then select the check boxes beside Delete all
7) Clear the check box next to Backup up device data automatically
8) Click Ok > Next > Finish.
9) When the process has completed, the message The loading
1) Click Advanced , and then select the check boxes beside Erase all
2) Click Next.
3) Select the check box next to Do not automatically backup the
4) Clear the check box next to Backup and restore applications
5) Click Next > Finish.
Note: The BlackBerry smartphone will not show a Connected state in the BlackBerry® Desktop Manager. Proceed to open and run the application loader tool.
1) Remove the battery and run loader.exe from C:\Program
2) Remember to reinsert the battery after the loading operations begin.
Oct 24, 2009 | RIM BlackBerry 7290
BlackBerry Calls N' Messaging Problems
are you using an unlocked bold?
it appears you have a corrupt software and you will probably need to reinstall the software.
here is a procedure I found on the Blackberry forum that will possibly help you.
You will need the Blackberry Desktop Software installed on your computer before attempting this.
Problem
The following error is displayed on the BlackBerry device:
net_rim_bb_phone_app killed due to message queue overflow
Cause
This issue may be caused by call logs or BlackBerry device software.
Resolution
To resolve this issue, do the following:
Task 1: Clear Phone Call Logs
  1. In BlackBerry Desktop Manager on the computer, double-click the Back Up and Restore icon.
  2. In the Back Up and Restore window, click Advanced. The BlackBerry device database information will populate the right hand side of the window.
  3. Scroll down through the list and highlight Phone Call Logs, and select Clear. Note: If you are unable to clear Phone Call Logs, delete the Desktop [SYNC] service book on the BlackBerry device. This can be performed on the BlackBerry device by selecting Options >Advanced Options >Service Book and clicking Delete.
  4. Once the Phone Call Logs database has been cleared, disconnect the BlackBerry device from the computer, and then re-connect it to obtain a new Desktop[SYNC] service book.
If this does not resolve the issue, proceed to Task 2.
Task 2
Create a full back up of the BlackBerry device and run Application Loader in the BlackBerry Desktop Manager to erase all data and applications from the BlackBerry device. Refer to KB02318 for these steps. Once Application Loader has completed, perform a syncronization or advanced restore to restore the data to the BlackBerry device. To do this, double-click on either the Synchronize or Backup and Restore icons, and follow the on-screen instructions.
May 30, 2009 | RIM BlackBerry Bold 9000 Smartphone
Blackberry endless reboot
Try a firmware update on your blackberry. I do not know which country you are in which service provider you are with so please check carefully when going through step 2.
Check below steps for OS upgrade -
Step #1
Step#2
Step#3
Step#4
  7. Click Next.
May 27, 2009 | RIM BlackBerry Curve 8310 Smartphone
138 people viewed this tip
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
