Tip & How-To about Computers & Internet
Windows XP Repairing
XP is a windows based operating system. XP is client OS which file format is Fat32 and NTFS. Some time for user fault, unauthorised operation, improper shutdown, viruses or any other cause may corrupt this file system and it may crash your windows also. Formatting and reloading of windows can solve your problem easily. But maybe there formatting is not possible for important data or for product key. So there repair of OS is only way to recover.
I have facing almost the same problem once. There customer have a confidential file in his system's desktop. Desktop belongs in C: drive where the OS resides. First I tried to recover the data but nothing is possible there. Then I started to repair the Widows. I insert the XP CD in DVD-Rom drive boot from it. Start the windows setup after loading files it ask for a repair (R key) I have ignore it by pressing Enter then the license agreement screen appeared. Then the OS instruct to press F8 to agree with the license and continue setup. After pressing F8 it will find the previous version of OS, if setup found any previous version then it will give you option to repair the OS again. But that day I don't get this option. It shows total disk space of C: drive have remain free space. So that there was not any file to recover the OS.
Then I go to boot the system again but formatting is not possible so after loading files at the first while the first repairing option appeared I have accept this repairing option. This option is from dos repairing option. After pressing "R" while appear the dos screen. Then press Enter to continue. Then I run the command "chkdsk" in C: drive to check the disk. After complete the disk checking and fixing the error I reboot the system again. After that I have Boot the system and after completing the whole process I choose the second repairing option. Then I got the previous version of OS and start to repair the previous OS. It now just loads the file and get started XP after booting. I got success to repair the OS and recover the data.
So it is a secure and easy process of recovery.
Computers & Internet Logo
how can i make my WD passport fat 32 compatible
  • By default Windows Operating System follow NTFS Format and NTFS based File Managers support FAT32 format without any additional changes.
  • Fat32 is also accessible in Linux Operating System without any modification whatsoever
Apr 06, 2010 | Western Digital WD Passport 250GB Portable...
Which partition is the best in NTFS & FAT32?
For most users running Windows XP, NTFS is the obvious choice. It's more powerful and offers security advantages not found in the other file systems like FAT16, FAT32.
Feb 01, 2009 | Microsoft Windows XP Professional for PC
I have an 8 GB PNY Attache flash drive that can be read by a Windows XP operating system but not on a Mac OS X operating system. The problem is even more confusing because a Mac that can run both Windows and the OS X can read the flash drive when started up in a Windows environment but not when started in a Mac environment (same port used for the flash drive in both instances). Any thoughts as to why...
You may have the drive formatted in a way that the Mac cannot read. If you go to your "My Computer" in XP, find your drive, right click on it, look for something that says either NTFS or FAT32. If it's NTFS, the Mac won't read it.
You can copy files off the drive and then reformat it, also with a right-click in that My Computer menu. Format to FAT32. FAT32's major limitation will be no files over 2gb each.
There is free software out there that will -try- to read and write NTFS drives. It worked for me, but killed my brother-in-law's Mac.
http://macntfs-3g.blogspot.com/
Dec 05, 2008 | Computers & Internet
DOES THE VERBATIM HARD DRIVE NEED TO BE FORMATED?
Many Verbatim hard drive models with a FireWire interface come “Mac formatted” – pre-formatted for immediate use with Apple Macintosh computers running Mac OS. They are formatted as HFS+, the preferred format when using the drive exclusively with Mac OS computers.
Note: A Mac-formatted drive will not mount on a Windows PC.
If you plan to use a Mac-formatted hard drive only with computers running Mac OS, you can leave it formatted as it comes from the factory. However, if you plan to use your hard drive with computers running Windows, or with both Mac OS and Windows computers, you should reformat your Verbatim hard drive before saving data to it. Generally, for use with both Mac OS and Windows you should format to FAT32, and for use strictly with Windows you should format to NTFS. More information about these two format types is given below.
FAT32 FAT32 is compatible with the following Windows operating systems: Windows 98, Windows 98 SE, Windows Me, Windows 2000, Windows XP, Windows Vista. FAT32 can also be read by Apple Macintosh computers running Mac OS.
Limitations: Maximum file size is limited to 4TB. Furthermore, using the formatting tools included with Windows 2000, Windows XP, and Windows Vista users will not be able to create partition sizes larger than 32GB (though they can access these larger partitions). This limitation does not apply to other supported operating systems. Furthermore, Verbatim provides a FAT32 format utility (see further below for download instructions) that eliminates the 32GB partition limitation.
FAT32 is a good choice if you’ll be using your Verbatim hard drive with older computers running Windows 98, Windows 98 SE, or Windows Me, or if you’ll be using it with both Windows and Mac OS computers.
NTFS NTFS is compatible with the following Windows operating systems: Windows NT, Windows 2000, Windows XP and Windows Vista. NTFS usually results in higher performance than FAT32, and will permit users to create partition sizes larger than 32GB, and file sizes larger than 4TB.
Limitations: NTFS is not compatible with Windows 98, Windows 98 SE, Windows Me, or Apple Macintosh computers running Mac OS.
NTFS is a good choice if you will be using your Verbatim hard drive only with one or more computers running Windows XP, Windows 2000 or Windows Vista. This is also a good choice if you plan to store files larger than 4TB, such as digital video files.
Per: http://www.verbatim.com/downloads/format.cfm
Good Luck
cbinny1
Oct 20, 2008 | SimpleTech SimpleDrive Portable USB 2.0...
i wan to use windows 98 along with XP
this is tricky as win98 is not supported and can not work on faster processors, The book says 2 gig but I had a problem on 1.8 ghz.
the next problem is win98 does not rceognize ntfs file systems. so a bootable partion manager (like linux GParted) would have to be run, to shrink the ntfs partition without altering content to allow another partition to be created then formatted into FAT32 so you could load 98 from a bootable cd.
Mar 21, 2008 | Microsoft Windows XP Professional
277 people viewed this tip
David Payne
David Payne
