Tip & How-To about Cell Phones
How to get Locked code in your Motorola phone and how to unlocked it?
Locked code is one of the features in your Motorola phone ,but what will you do if you forget the code you are enter to it?And do you want to used other simcard in your Motorola phone that is locked to a particular network? here is the solution to that ,just download the software and the Motorola Driver Installer below....
here is the MotoP2k software ...http://www.4shared.com/file/D6OAM03b/MOTOP2K.html
Motorola Driver Installer >http://www.4shared.com/file/4Rsb9FH3/Motorola_EU_Driver_Installatio.html
just open the software and follow this instruction...
1.http://img850.imageshack.us/img850/7932/30908486.jpg
2.http://img16.imageshack.us/img16/9918/14967439.jpg
3.http://img850.imageshack.us/img850/2246/48000409.jpg
4 .http://img856.imageshack.us/img856/63/keypadt4e3st.jpg
here is the following service that you can use in this software ....
*READ/WRITE = SECURITY CODE & UNLOCK CODE
*READ INFO
*KEYPAD TEST
*CAMERA TEST
*EDIT MODEL
* LIGHT TEST
*BOOT MODE
*RESTART
****And the most important is this pasword ***< www.tapgsm.com.ph/forum>
Cell Phones Logo
what is the code to unlock a motorola V365?
hi Your phone’s four-digit unlock code is originally set to 1234. The six-digit security code is originally set to 000000. If your service provider didn’t change these codes, you should change them:
If you forget your unlock code: At the Enter Unlock Code prompt, try entering 1234 or the last four digits of your phone number. If that doesn’t work, press M and enter your six-digit security code instead. If you forget other codes: If you forget your security code, SIM PIN code, PIN2 code, or call barring password, contact your service provider.
May 13, 2010 | Cell Phones
forgot my lock code ..motorola phone ,please help
Sir, try to enter the security code instead of the lock code. It will unlock it. Its default is in the manual. If it doesn't work, go to a Service Centre. They will update the phone and make its features and the code to default. Now you have to enter only the default code. Thank you Sir, Have a nice day.
Sep 20, 2009 | Motorola Mobility L6 Cellular Phone
i dont remember the phone lock code of motorola v3i
Your phone’s four-digit lock/unlock code is originally set to 1234.
last four digits of your phone number. If that doesn’t work, press and enter your
Jun 24, 2009 | Motorola Mobility RAZR V3i Cellular Phone
Factory ringtones
Sir,
You can lock your phone manually or set the phone to
lock automatically whenever you turn it off.
To use a locked phone, you must enter the unlock
code. A locked phone still rings or vibrates for incoming
calls or messages, but you must unlock it to answer.
You can make emergency calls on your phone even when
it is locked (see page 68).
Locking Your Phone Manually
Find the Feature > Settings > Security
> Phone Lock > Lock Now
Unlocking Your Phone
Tip: Your phone’s unlock code is originally set to 1234.
Your service provider may reset the unlock code to the last
4 digits of your phone number.
Setting Your Phone to Lock Automatically
You can set your phone to lock every time you turn it
off:
Find the Feature M> Settings > Security
> Phone Lock
> Automatic Lock > On
If You Forget a Code, PIN, or
Password
Note: Your phone’s 4-digit unlock code is originally set to
1234, and the 6-digit security code is originally set to
000000. Your service provider may reset the unlock code
to the last 4 digits of your phone number before you
receive your phone.
Press To
1 keypad keys enter your unlock code
2 OK (+) unlock your phone
> Phone Lock
Master
Clear
Clear all user settings and entries
except SIM card information, erase all
downloaded pictures and sound files,
reset all options except unlock code,
security code, and lifetime timer:
M > Settings > Initial Setup
> Master Clear
Caution: Master clear erases all
user-entered information (including
phonebook and datebook entries) and
user-downloaded content (including
photos and sounds) stored in your
phone’s memory. After you erase the
information, you cannot recover it.
Thanks
Good Luck
Don't forget to rate the solution
Jul 05, 2008 | Motorola Mobility Mobile PhoneTools 3.0...
1,157 people viewed this tip
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
