Tip & How-To about Cell Phones
Disable Mobile Data on Android, Samsung Galaxy etc
I am sure, at times you want to disable your internet connection on Mobile (e.g. While roaming or to save battery) and given the fact that the Android phones stickiness it may be a bit challenging.
Easy way, is to install a third party app "quick settings" and disable the data there. After you install you can open the app and disable or enable the data.
There are other apps or ideas to change the APN name but the problem is some of the operators are using a feature called 'flexy apn' which still connects with a wrong apn name.
Use it and save your precious $ :)
Cell Phones Logo
How do I connect to the internet when I am not connected to home Wi-Fi connection? I get an error message even though it shows I have a 4G connection.
Usually simply rebooting your phone, regardless of make and model, takes care of any connectivity issues.
Oct 12, 2015 | Cell Phones
How can i switch off data on my HTC phone ?
  • On most Android phones (ICS, JB, KK): go to Settings -> Data Usage -> Data Connection -> Slide the switch on off
  • On some HTC phone: use the Data Connection widget
  • On some Android phones (1.5 - 2.3): go to Settings -> Mobile Networks -> uncheck Data Connection
Other ways:
How to Turn Off and Disable Mobile Data Connection 2G GPRS Edge 3G on...
How to Disable Mobile Data Usage Beginners Guide
Enable or Disable Mobile Data Android 4
How to disable the internet connection on your smartphone turn off your...
Aug 25, 2014 | HTC Magic Cell Phone
My android phone use my airtime fast and without using it not even a call
You may have your 3G active especially if you have a plan with the service provider and your 3G is activated by default. Go to settings ,and disable data roaming and data transfer. More specific answer can be given if you inform the model do the phone the carrier etc. some like at& t are coming out with models like LG a 340 which do not have disable data roaming or 3G at all.
May 12, 2014 | Cell Phones
Can't restore network connection
check your network connection
register to your network automatically
disable roaming
and check data connection is on in network connection
Dec 29, 2013 | Kocaso M752 Dual Camera Android 4.0 ICS...
my samsung tocco lite has only just started showing a r next to the signal strength what is the R representing
It stands for roaming, which means that the phone is connected to your providers network. You may want to check with your provider to make sure that your not being charged extra for roaming, as this can become costly.
Hope this helps
Ray
Mar 03, 2011 | Cell Phones
105 people viewed this tip
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
