Tip & How-To about Computers & Internet
Play/watch Blu-ray DVD movies on iPad 2
Do you need an iPad 2? You probably know the answer to this. If you have an iPad 1, I'd recommend in most cases to stick with it until iPad 3 rolls around. The cameras are great and all, but it's not nearly as convenient to shoot a quick picture or video with a big ol' honkin' tablet as it is with a pocketable device. Thus, the main use is video chat - and outside of regular travels with family at home and others who've already jumped into the future by making video chat a part of their lives, it tends to become a cute novelty after a use or two. If you don't have an iPad 2 (and can't wait a few months to see if the super-quick-iPad-3-followup rumors pan out), or if the apps that come along and take advantage of the new A5 processor really get your gears churnin', go ahead and dive in.
Video actually played a big role during the announcement, with Job's saying that a new device only made sense if it was better at watching video, among other tasks, than current laptops and smart phones. And the fact is that iPad can do a good job in HD movies and TV shows playback. The 9.7- inch LED-backlit glossy widescreen Multi-Touch display with IPS technology will make you enjoy a more wonderful visual experience than ever. However, it is pity that there is no built-in optical drive, and the external drives are very expensive. So, how can we watch Blu-ray and DVD movies on iPad in an easy and cheap way? Here I will share the best solution with you all.
To rip Blu-ray disc and DVD, Blu-ray Ripper and BD drive are required. You may download Blu-ray DVD to iPad 2 Converter from here. It is naturally support DVD ripping and allows you to select audio track of any language of the movie. Now find a step-to-step guide below:
Step 1: Click "DVD ROM" or "IFO/ISO File" to import Blu-ray files.
Step 2: Click the drop-down list of "Format" to select an output format. Here I follow iPad-> MPEG-4 (*.mp4)" for instance.
Step 3: Click "Browse" button to look for and set a save path to store the output HD videos.
Step 4: Click "Settings" button to do advanced settings.
After clicking this button, you will enter the window shown below, on which you are allowed to adjust video and audio parameters like codec name, bit rate, image pixel, sample rate, etc., in that way you can take charge of the output file size as well as image quality on your hands freely.
Step 5: Click "Convert" button to start Blu-ray ripping.
As long as the ripping work is finished, you can click "Open" button to find out the ripped HD files with ease. Then, you can transfer the generated file to your iPad to enjoy wonderful high quality Blu-ray movies.
For Mac Users: Blu-ray DVD to iPad 2 Converter for Mac
Computers & Internet Logo
how many quart oil is needed for LS'1998 LS 400 ?
I don't know the correct amount, but if it is empty, put 3 quarts or liters in, then use the dipstick level as a guide. Put in 1/2 of another quart and check the level on the stick. Keep adding and checking the level until it is full. Probably somewhere between 3 1/2 liters and 4 or 4 1/2 liters. When shows full on the stick, that's how many. If you overfill it, just drain some out through the drain plug.
May 27, 2014 | Cars & Trucks
Remove baidu from iPad
Have you installed a Baidu app on your iPad and wanna remove it?
Well, the first method recommended for you is to directly delete apps from Home screen on your iPad.
1. You only need to keep touching the icon of the app until it wiggles with an X at the upper left corner.
2. Then tap the X and choose "Delete" in the pop-up dialog. You will get the apps deleted with no efforts.
Sometimes you cannot see the X and don't know how to delete apps on iPad directly, you can check the Settings at this moment. Then you can try to delete the apps on your iPad again.
1. Check the "Settings", then scroll down a bit and tap on the "General" option.
2. Tap on "Usage" (older version of iOS) or tap on the "Storage & iCloud Usage" (newer version of iOS).
3. You need to tap on "Manage Storage" and you'll see a list of all app installed on your iPad. Simply select the app and tap on "Delete" to delete that app.
There are also some other methods to help you remove unwanted apps from your iOS device. Click the following link to know more.
How to Delete Apps from iPad
Dec 09, 2013 | Tablets & eReaders
iPad 3 Printing
You can download hp eprint from appstore.Works with variety of printers.
Aug 09, 2012 | Apple iPad (16 GB) WiFi Tablet PC
forgtton unlock code on ipad2
hard reset the device
OK, you have noticed the strange behavior of your iPad / iPad 2 or even new iPad 3. It tends to freeze for about a few seconds every minute or is running too slow or something else. This is probably the best time for the hard reset of the tablet. To make things easy follow simple sequence:
  1. Make sure your iPad /iPad 2 / iPad 3 battery is charged above 20% (we would recommend at least 50 - 60 %). If you are not sure charge you tablet for at least 40 minutes.
  2. Make sure your Apple tablet is in Power On state.
  3. Watching the shining screen of iconic tablet with apps' icons on it press and hold down the Wake/Sleep and the Home buttons simultaneously, ignore the red slide "to power off", just keep both buttons holding until the Apple logo appears. This logo is the signal that the hard reset has succeeded. Be patient, some times the hard restart of iPad may take up to 10 - 15 minutes. But such a long restart is a rare case.
Be sure that hard reset retains all data and settings on iPad, it doesn't delete anything. If you want to start over and delete all personal data from iPad you should use iPad Recovery Mode.
Jun 19, 2012 | Tablets & eReaders
166 people viewed this tip
David Payne
David Payne
