Tip & How-To about Office Equipment & Supplies
HP printer UNINSTALL using CD
Resolution:
  1. Run the uninstaller from the SETUP.EXE driver
  2. Delete printer from Printers folder
Removing printer using the SETUP.EXE driver:
  1. Run the uninstaller from either the printer CD-ROM, diskettes, or the downloaded Setup.exe printer driver.
  2. Go to Start, then Run and in the Open line type X:\Setup.exe, (where X is the CD-ROM drive or the floppy drive or the Directory on the hard drive where the downloaded driver as copied to.
  3. Follow the on screen instructions.
Deleteing Printer:
  2. Go to Start, then Run and in the Open line type X:\Setup.exe, (where X is the CD-ROM drive or the floppy drive or the Directory on the hard drive where the downloaded driver was copied to.
errors
solution 1>
CAUSE:
Certain HP services (and associated DLL files) were somehow partially/improperly installed. (Possibly, from a previous failed install?)
The Windows services (files) were:
Pml Driver HPZ12 (C:\Windows\System32\HPZipm12.dll)
Net Driver HPZ12 (C:\Windows\System32\HPZinw12.dll)
The existence of these 2 files in the System32 directory was causing this error in my situation. Somehow, the installation script was not identifying that these files were already installed (or improperly installed) and failing to properly set them to be installed again.
SOLUTION:
Steps:
1) Check to make sure that the 2 Windows services above are not running (or not installed).
2) Rename/delete the 2 associated service DLL files (this will only be possible once the services are stopped)
3) Run the installation again.
solution 2>
complete uninstall printer software from computer.
run uninstall L1 L2 L3 L4(if not an hp computer).
run same uninstall l1l2l3l4 from 7z..folder or hp folder from temp if availalbe.
then clean from add remove programs/program and features.
then clean from cleanup utility all hp pritner related entries.
then clean temp folder. clean recycle bin.
delete c:\program files\hp and hewlett packard folders (if not an hp computer). on hp computer delete digital imaging bin folders.
delete following folders from following locations-
C:\windows\System32\Spool\Printers and deleted entries inside it
C:\windows\System32\Spool\drivers\w32x86\*.* deleted entries inside it
C:\windows\twain_32.
cleanup from regsitry--
plz make back up for registry first.
>> hklm/system/current control set/control/print/environment/windowsNT(x86/64)/drivers + processors delete all pritner entries from there.
>> hklm/system/current control set/enum/usb/vid_000,vid_003 delete.
>> hklm/system/current control set/enum/usbprint delete pritner entries.
>> hklm/system/current control set/control/print/monitors/hp standard tcp/ip ports/ports.
>> hklm/system/current control set/control/print/monitors/standard tcp/ip ports/ports.
>> delete same ports from printers and faxes/pritners pritner properties ports
>> hklm/system/current control set/control/print/monitors/hpz..
>> hklm/system/current control set/control/print/providers/lan man settings.
>> hklm/SYSTEM/CURRENTCONTROLSET/CONTROL/PRINt/PRINTERS
>> hkey_Current_User\Software\Hewlett-Packard
>> hKey_Local_Machine\Software\Hewlett-Packard
>> HKEY_USERS\.DEFAULT\Software\Hewlett-Packard
>> hkey_current_user\software\hewlett packard delete if not hp computer.
>> hkey_curent_configuration/system/current control set/control/print/pritners.
then go to msconfig
make it selective startup disable all microsoft services except hp services. hide all microsoft services. disable all startup tab apply restart.
after restart install cue version 12 officejet pro 8500 or 6500.
then run msiexec.exe /unregister then msiexec.exe /regserver cmd commands.
then install software from downloaded version of original pritner install only basic drivers first and imaging devices only and use solution center 12. cue 12.
issue resolved.
Nov 02, 2009 | Computers & Internet
j6480 fatal error 2753 MSI.dot4wrp during full driver install. I tried uninstalling al related hp drivers, all the HP advice. Disabled firewall, services etc. Do you have a solution that works?
you can try with installing the windows installer 4.5 and then try.. otherwise reinstalling windows might work because the error you are getting is related to installer.. and its a service of windows itself which is responsible for all the software installation..
Oct 29, 2009 | HP DeskJet 648c InkJet Printer
can not install on my laptop
If you are having problem to install the printer, or get your printer on, do the following:
Check all connections first if necesary replace the cables and try again.
Be sure the printer is ON
Go to Printers Folder (Start >> Control Panel >> Printers) And be sure your printer status is marked as "READY"
If not, Uninstall the printer and install the printer again but
During the printer installation follow the software steps
to remove your software go to >> Start >> Control panel >> Add/remove programs
If you did it already and your software is still in your computer do this:
1) Uninstall the printer,
2) Delete all the printer folders created during the last installation. (Usually in folder "Program Files")
3) In the computer registry (start >> run >> regedit.exe) Delete all printer paths
4) Reboot your computer
5) Re-install the printer again.
If you dont have the CD:
To get your software go to: www.canon.com
Support >> Sotware and drivers
And download there your printer software
Have a great day!
Pablo :-)
Oct 18, 2008 | Canon Office Equipment & Supplies
I need to delete the software for a Cannon MP30 printer from my computer. I have Windows XP Home and the regular Microsoft program for removing it does not get the job done. I can not find the installation disc that came with the printer. How can I remove the uninstall the program for the Canon MP 30 printer?
2) Delete all the printer folders created during the last installation. (usually in folder "Program Files")
And download form there your printer software
Oct 14, 2008 | Cannon Office Equipment & Supplies
installationcompletedprinternotprinting
If not, Uninstall the printer and install the printer again (*A) but
(*A)
This will fix your problem.
Thank you for using FIXYA!
Cheers!
Pablo
Oct 10, 2008 | HP Office Equipment & Supplies
151 people viewed this tip
k24674
