Tip & How-To about Office Equipment & Supplies
Noise while printing - Diagnosis Pt 1
Unexpected noise (such as clicking, thumping, or grinding) from an branded device are heard during printer operation.
NOTE:
Noises can be caused by a number of things, some of which may not be addressed in this document. This document deals strictly with the isolation and potential resolution of known noises through troubleshooting.
The following table describes some of the noises to be expected in a printer functioning normally:
Noise occurs:
Additional information:
During power-up
When the printer periodically makes humming and buzzing sounds as the carriage assembly moves around on the right/left side of the printer, the printer is actually cleaning the ink cartridges. This is a normal operation for the printer. This sequence may happen in the following conditions:
  • Before and/or after printing
  • During power on
  • After the printer has been on standby/idle for some time
  • After replacing a cartridge
  • In the middle of a long print job (such as printing many photos)
During printing*
  • Paper pickup: There will be some noise during paper pickup due to the movement of rollers and gears.
  • While printing: The unit has printed a few lines or the paper has been fed into the printing area. There will be some noise during printing due to the movement of rollers, gears, carriage and paper (paper feed and ejection).
During paper ejection*
At the end of the print job, there is a louder clicking noise as the paper is being "pushed off" to the output tray.
During copying/scanning
The scanner may make pulsing and dragging noises as it scans portions of the document or it may make a long rolling sound if it is doing a continuous scan. After scanning, it will make a long dragging noise as the scanner is brought back to the home position (could be on the left or right side).
Post-printing with no additional jobs in the queue
Post-completion of a print job and without another job in queue: At the end of a print job, there will be a noise on the left/right side of the printer as the pens are being capped. The printer may try to do this a couple of times, which is normal.
Between print jobs
The printer may make humming and buzzing sounds as the carriage assembly moves around on the right/ left side of the printer during the cleaning of the ink cartridges.
In the accessories
There may be some noise associated with accessories (ADF, duplexer, etc.) during the initial positioning and during normal operation.
noise in left front wheel
Grinding noise, growling noise, thumping noise? Something else? If it's a grinding noise, more than likely it is during stops. In this case it is probably metal on metal in the brake pads. If it is a growling it can be in the wheel bearing or CV shaft which usually gets louder with turning or banking. Is it is a thumping can be from a tire issue, a strut, a sway bar link banging around etc. Need to clarify the noise and how you are hearing it.
Mar 08, 2013 | 2003 Buick Century
clicking noise
Check the printer thoroughly for any small pieces of paper caught on a roller in the printer. If your printer is making a grinding noise, you may have a loose gear or roller in the printer.
If the noises started shortly after you installed a toner cartridge, turn off the printer and pull out this toner cartridge. Look up into the printer where this toner went. Make sure that both the charge roller and the transfer roller are still seated in the printer properly.
  • The charge roller is a tan-colored or gray roller attached to the inside of your top lid. Remove the toner cartridge from your printer. Close the top lid halfway with the cartridge still out. You will see the charge roller come down as you lower the top lid. Make sure that the charge roller is installed correctly within the two black arms on each end and that the roller does spin freely.
  • The transfer roller is the black, spongy roller in the bottom of the printer, under the toner cartridge. Push lightly down on it at both ends to make sure it is seated properly in its housing. NOTE: Try not to touch the charge roller with your bare hands. It is susceptible to the oil and may cause a permanent fingerprint to remain on the roller surface.
  • When you have checked the charge roller and the transfer roller, look around inside the printer. See if you can find any rollers that look loose or broken inside. Also look for any loose shreds of paper. If you do find a loose or broken part, you printer will probably require service to fix the problem.
If the rollers look fine, go ahead and reinstall the toner cartridge. If the squeaking/grinding noise continues and none of the rollers looks out of place, try swapping out the toner cartridge. There is a small chance that the toner cartridge is causing the squeaking/grinding noise. If you have any extra toner cartridges in stock, try another toner cartridge and see if that clears up the noise. If you have another working printer of the same model, try swapping the toner cartridges. See if the problem follows the toner cartridge or stays with the printer.
If replacing the cartridge does not cause the noises to go away, there are a few other things you can do to help pinpoint the source of the noise.
If the noise continues on the main printer, try opening the rear exit door while printing. See if you can tell if the grinding noise might be coming from one of those rear exit rollers/gears. If it does sound like it is coming from the rear of the printer, again look for any loose or broken part or any small pieces of paper.
If you have added any additional feed options (like a tray 2 or 3 option, duplex option, or envelope feeder), please remove these options. Try printing a few prints without these feed options attached. This will eliminate one of the feed options as the cause. If the noise goes away when you remove the options, reattach them one at a time. If the noise returns on one specific option, a roller or gear on that option may be the cause of the noise.
Is your printer making a rhythmic THUMP - THUMP - THUMP - THUMP noise when printing? This noise is a side-effect of a feature called Envelope Enhance. The Envelope Enhance feature is built into the fuser unit of the printer to help keep envelopes from wrinkling. This sound is perfectly safe and normal if the printer is printing on envelopes.
If none of the above fixes eliminates the noise, the printer will probably need service to return it to working condition.
***If you need any technical help on printer then you can reach at here
Feb 15, 2013 | Canon imagePROGRAF iPF8000S 44"...
When the drum spins with a large load of clothes a thumping sound and a high pitched squeal is heard
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker
Mar 14, 2011 | Dryers
I turn on my canon mx310 and hear a constant clicking noise that lasts for 2 mintues, the alarm button flashes/blinks, and says "scanner error"... what could be causing that? and how can I fix this?
Issue: A grinding noise is heard from the device.
Solution: Press ON/OFF switch to reset the multifunction device
Reset the device when it is not functioning properly. If the device is not functioning properly or to clear memory, reset it.
  1. On the operator panel, press and hold the <ON/OFF> button for one second. (The display will go blank.)
  2. Wait approximately ten seconds and then press the <ON/OFF> button again.
  3. Wait until the device has completed its cycling process before submitting another job request.
ALSO:
Make sure that the protective cover is removed from the FINE cartridge holder.
Jun 29, 2010 | Canon PIXMA MX310 All-In-One Printer
Making a loud noise when the paper is feeding.
This is what the HP website says about noises in the 1610..
Issue Unexpected noise (clicking, thumping, grinding, squealing, and so forth) from an HP all-in-one can be caused by a problem with the ink carriage or the scanner. Solution Follow the steps below in the order presented to determine the source and resolution for the noise. Step one: Checking the scanner This step applies only to products equipped with a flatbed scanner.
  1. Open the scanner cover.
  2. With the lid open, press the Start Copy button to make a copy. The scanner mechanism should move down the glass.
  3. If the scanner mechanism does not move and noise is present, contact HP. If the scanner mechanism moves without noise, continue with Step two below.
Step two: Checking for paper feed problems and carriage blocks Click here (buu03110) (in English) for more information on paper or carriage jams. Step three: Service the product If you have completed all the steps listed above and are still experiencing a problem, service the product. So it sounds like it needs to be serviced which could get expensive. I've looked all over the web for you & Keep finding the same answer. Sorry I can't come up with a better solution for you.
Nov 29, 2008 | HP PSC 1610 All-In-One InkJet Printer
187 people viewed this tip
k24674
