Tip & How-To about Office Equipment & Supplies
Setting up printer on XP
To add a printer, first follow your printer's instruction manual to assemble your printer and connect it to your computer. When you are ready to install the software, have your printer's CD-ROM or floppy disk handy.
1. Open the Start menu and choose Settings, then Printers.
2. Double-click on Add Printers.
3. Follow the instructions provided by the Print wizard. If you're adding a network printer, be sure to find out its name or network path. To make sure you're using the most recent printer driver, insert your printer CD-ROM or floppy disk when asked. You can also choose a preinstalled driver that matches the printer make and model you're trying to add, but it might be older than a driver that came with the printer. (If you're installing a networked printer, ask your system administrator if there are newer drivers available on the network.)
4. When prompted, indicate whether you want to use this printer as the default. If you have only one printer, you will say yes. If you have two, you must choose which one is to be the default.
5. When asked if you want to print a test page, say yes.
6. When satisfied, click Finish to complete the installation process.
I need to know how to add it as a printer on my computer. This number is not in my list of printer choices for Citizen.
Follow procedure for Printer setup in CD or instruction manual.
When ready, it sgould appear as a printer option in your computer
May 07, 2015 | Citizen Watches Citizen Idp 3500 Dot...
installing software for x3470 printer, get install error #MSG_invalid_OS#
Try following this steps:
To add a printer, first follow your printer's instruction manual to assemble your printer and connect it to your computer. When you are ready to install the software, have your printer's CD-ROM or floppy disk handy. Step2Open the Start menu and choose Settings, then Printers. Step3Double-click on Add Printers. Step4Follow the instructions provided by the Print wizard. If you're adding a network printer, be sure to find out its name or network path. To make sure you're using the most recent printer driver, insert your printer CD-ROM or floppy disk when asked. You can also choose a preinstalled driver that matches the printer make and model you're trying to add, but it might be older than a driver that came with the printer. (If you're installing a networked printer, ask your system administrator if there are newer drivers available on the network.) Step5When prompted, indicate whether you want to use this printer as the default. If you have only one printer, you will say yes. If you have two, you must choose which one is to be the default. Step6When asked if you want to print a test page, it is a good idea to say yes. Step7When satisfied, click Finish to complete the installation process. Hope that helps....
Jul 18, 2008 | Lexmark Office Equipment & Supplies
vista driver
The print driver solution for this product is included with the Microsoft Windows Vista operating system and is already on the computer. No special driver download is necessary for this product.
Please follow the simple instructions below to easily get the product working with Microsoft Windows Vista Operating system.
Installation Instructions
Direct Connection (Parallel & USB connector)
  1. Verify that the printer is turned ON.
  2. Connect the Universal Serial Bus (USB)/ Parallel (IEEE 1284) cable to the printer and to the computer
  3. Click on the Close button when the message "Your devices are ready to use" is displayed in the screen.
  4. The printer is now ready to accept the print job.
Wired Network & Bluetooth Connection
NOTE:For Bluetooth connected printer, please ensure that the printer's access mode is set to public mode for detection.
  1. Verify that the printer is turned on.
  2. Click Start > Control Panel and then select Printers .
  3. Click on Add a printer .
  4. Click Add a network, wireless or Bluetooth printer . A list of detected wired network or Bluetooth printers will be displayed.
  5. Select the printer you want to install and click Next . Follow the on screen installation instruction to complete the printer driver installation.
Wireless Connection
  2. Ensure the printer's wireless network setting is set to the correct wireless profile matching the local wireless network/computer's wireless card setting.
    If you have previously configured the printer's wireless network setting, matching local wireless/computer's wireless card setting, please proceed to step 3.
    if you have NOT previously configured the printer's wireless network setting to match local wireless network/computer's wireless card setting, please follow the steps below.
    To set wireless network settings in an infrastructure network
    Connect the printer to the computer with the cross cable (included with the printer) or connect the printer to the network with a network cable.
    Press the configuration button once to print a configuration page.
    Open web browser, and type in the IP address that has been assigned to the printer.
    Configure the printer's wireless setting to match local wireless network/computer's wireless card setting.
    Unplug the cross cable/network cable.
    Activate the printer wireless network, activate the computer's wireless network profile.
    Proceed to step 3.
    To set wireless network settings in an ad hoc network
    Do the following to reset the printer's network settings:
    1. While pressing the Configuration Page button, press (Resume button) three times.
    2. Wait about 20 seconds, and then press (Power button) to turn off the printer.
    3. Disconnect the power cord from the printer.
    4. Wait about 20 seconds, and then reconnect the power cord.
    5. Press (Power button) to turn on the printer.
    6. Open the configuration utility for the computer's wireless network card, then create a new wireless profile with the following values.
      • Communication mode: ad hoc
      • Network name (SSID): hpsetup
      • Security (encryption): disabled
    7. Activate the wireless profile.
    8. Wait two minutes for the printer to obtain an IP address, then print a wireless configuration page to verify the following for the printer's network settings.
      • The IP address is NOT 0.0.0.0
    9. If one of the above conditions is not true then repeat the preceding steps. Proceed to steps 3 below.
  3. Click Start > Control Panel and then select Printers .
  4. Click on Add a printer .
  5. Click Add a network, wireless or Bluetooth printer , a list of detected printers will be displayed.
  6. Select the printer you want to install and click Next . Follow the on screen installation instruction to complete the print driver installation.
Dec 15, 2013 | HP DeskJet 450wbt InkJet Printer
bluetooth connection issues
There are several things to try:
Remove and then reinstall the device:
Click the Start Control Panel, click Hardware and Sound, and then click Bluetooth Devices.
Select the device that's not working, and then click Remove.
Click Add, press the reset button on the device
(or make it discoverable following the manufacturer's instructions), select the My device is set up and ready to be found check box, and then click Next.
If the device is not found, repeat the previous step.
When the device is found, select it, and then click Next.
Follow the rest of the instructions in the wizard.
Make sure the device is turned on and that the batteries don't need to be replaced.
Make sure the Bluetooth adapter for your computer is attached and turned on, and that the device is turned on and discoverable.
If you're not sure how to turn on discoverability, read the instructions that came with the device or check the manufacturer's website.
Make sure that you installed the device using the correct program. If not, reinstall the device.
For a printer, follow these steps:
Open the Add Printer wizard by clicking the Start Control Panel, clicking Hardware and Sound, clicking Printers, and then clicking Add a printer.
For a mobile phone, if you have Bluetooth wireless technology installed on your computer, use the Add Bluetooth Device Wizard. To do so, follow these steps:
Click Add.
For a keyboard or mouse, if you have Bluetooth wireless technology installed on your computer, use the Add Bluetooth Device Wizard. To do so, follow these steps:
Connect a wired keyboard or mouse to your computer.
Click Add.
The device might be out of range of your computer, or too close.
Try moving it closer or a little farther from your computer.
hope this helps
http://download.cnet.com/%7Bvalue=http://www.download.com/bluetoothview/3000-2648_4-10800572.html
Runs in the background, and monitors the activity of Bluetooth devices around you
Oct 06, 2012 | HP Pavilion dv8000z Notebook
I have a Brother HL2070N printer. I have 2 computers and want to share the printer. I connected the printer via the USB port to Computer 1 and it prints fine. I set the printer to SHARED. Computer 1 has a direct connection to the internet via a wireless router. Computer 2 shares the internet connection via a wireless card. I cannot print from Computer 2. When I try to Add Printer on Computer 2 it does not see the shared printer.
hi there,
Because printers and networks vary, the best instructions for setting up and networking your printer should be in its users manual. Also, your network-ready printer may have come with installation software that can help you share the printer over the network.
There are three main steps you need to take when networking a printer, including the following: Enable the File And Printer Sharing setting, Make the printer available to all users, and Direct PCs to the printer.
For detailed instructions on sharing printers at home, please refer to the "Get Your House In Order" article in the "See Also:" section below.
For detailed instructions on sharing printers in a small business, please refer to the "Select & Share The Right Printer For Your Small Business"
Apr 14, 2009 | Brother Office Equipment & Supplies
139 people viewed this tip
jasbo
jasbo
