Tip & How-To about Health & Beauty
How to Exfloite your body by using home made scrub.
Sometimes you feel rough or protuding outward pores over your body especially when you wax or epillate your unwanted hairs.
To get rig of the roughness of your skin.. Take 2 to 3 tablespoon sugar and add few drops of Olive oil to make a paste.
Rub gently and softly on to your skin in circular motion and after apply let it rub for 15 to 20 mins. and after it wash your body with mild soap or shower cream.
Health & Beauty Logo
What are the benefits of using epilators to remove hair?
Epilator is a lot more beneficial then using old methods for removing hair. As it helps you to save a lot more time that waxing does not do. It is less painful. Helps one to get smoother skin. Improves the circulation of the body. Can make you feel fresh and energized. And a lot more benefits are there that you can have a look at from
How to Exfoliate Legs. To get more better options for a person to get their skin look smoother and you can also buy the best epilator from there to buy it after looking for the reviews on it.
May 03, 2017 | The Health & Beauty
What are the possible side effects of waxing and how can they be minimized?
Although we can not predict or guarantee who may react, most clients do not experience reactions beyond redness and minor irritation. Hair may break at the root during waxing, causing some hairs to grow out faster. Please follow these guidelines to minimize irritation and possible break outs.
Avoid the sun immediately after waxing and please wear sun screen; recently waxed areas are prone to hyperpigmentation (permanent darkening of the skin) if exposed to the sun.
Avoid heavy exercise for at least 10 hours after waxing.
Avoid saunas, steam rooms, whirlpools and other heated sources for at least 48 hours.
Do not use exfoliating products (AHAs, scrubs, etc) and loofas until at least 24 hours after waxing.
Avoid tight clothing after waxing, especially in the waxed areas. Tight clothing may result in irritation and ingrown hairs
Regular exfoliation may be helpful especially on leg and arm areas.
Routine waxing helps the skin get accustomed to the procedure and may minimize irritation
Unfortunately, no shower or oral *** for 10 hours after a Brazilian.
Products are available that can be applied topically to avoid in-grown hairs and condition the skin for better waxing results.
Nov 23, 2010 | Health & Beauty
My Mom order this product and never used it. She
This interchangeable tweezers device (pat. pending) will do wonders for the way you feel about yourself. When you follow these simple instructions, Emjoi Beauty Forever will rid you of unwanted hair for the long haul! You can decide whether to use the coil-tweezers or the gold-plated tweezers based on these broad criteria:
The coil-tweezers enable you to clean out at a time a multiple number of unwanted hair (most notably, at the bikini line and some facial hair).
The gold-plated tweezers are intended to remove individual unwanted hair (like those on the eyebrow or on the breasts).
To use Emjoi Beauty Forever efficiently, please read carefully the enclosed Instruction Manual and pay a special attention to the following:
Clasp the unwanted hair with the Emjoi Beauty Forever's coil tweezers or gold-plated tweezers. At the same time, press the handle button for 15-20 seconds. The indicator light on the inside panel (near the adapter outlet) lights more brightly and will remain so during the application.
Slide the hair out gently in the direction it grows. If the hair doesn't slide out easily (some hair is more stubborn than other), gently tweeze it out. Even the coarsest hair is removed with a lasting effect by the Emjoi Beauty Forever's unique epilation treatment.
These helpful tips will assure extra-effective epilation!
The shorter the hair, the better the results. Preferably, hair should be no longer than 2-3 mm (1/10 in.)
Your skin should be completely clean before treatment.
To make skin more supple and relaxed, wash with warm water and gently massage.
Make sure no radios, TVs, or cordless phones are operating during treatment since they may interfere with RF transmission.
If a hair remains after 3-4 consecutive treatments, tweeze it. It has been sufficiently treated. There are some hair roots that need more treatments, particularly those that are dark and thick, or near throat, chin, lips, thighs and bikini lines.
Mar 08, 2010 | Emjoi Beauty Forever Epilator
Where to find?
You really don't need instructions. Just got over area using a small circular motions. I just keep going over the entire leg this way until all hair is removed and yes there will be some pain (especially if you have never experienced waxing!).
Jul 31, 2009 | Epilady Classic Epilator
1,120 people viewed this tip
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
