Tip & How-To about Office Equipment & Supplies
How To Reset Ink Counter On An Epson CX7300, CX8300 or CX9300
You must set the date in your computer to "April 11, 2008" to run Resetter Epson CX7300, Epson CX8300 and Epson CX9300 without error. If do not alter the setting of date of according to rule then software will deleted automatically when running.
If you have an error, delete all following entry before you rerun the software.
delete registry key: HKEY_LOCAL_MACHINE\SOFTWARE\EPSON\PTSG
and delete folder: C:\adjustment program
To reset waste ink pad counter Epson CX7300, CX8300 and CX9300F use adjustment program. I have tried this software and this software worked. To run this software without error please follow the instructions above.
Here How to use this software:
  1. Download the adjustment program (see below)
  2. Extract the file you have downloaded
  3. Go to The extracted folder then click tricks-collections.bat file
  4. Now set the date setting in you PC to 11 April 2008,
  5. Run adjustment program by click AdjProg.exe file the click accept
  6. Click Particular adjustment mode then select destination and printer port then click OK
  7. Select Waste ink pad counter from the below window and double-click to execute it
  8. Click [Check] button to check current protection counter's value.
  9. Then Click [Initialization] to reset the protection counter to the initial value.
  10. After finishing, you can change the date back to normal.
Link Adjustment program for Epson CX7300, CX8300 and CX9300F
connect computer
Go to Epson website and download what you need.
Feb 06, 2014 | Epson Stylus CX8300 Printer
wast ink counter epson stylus cx 9300f rest
Extrak adjustment you have downloaded
Go to The extrakded folder then click tricks-collections.bat file
Then Click [Initialization] to reset the protection counter to the initial value. Thats all.
After finishing, you can change the date to normal.
Link Adjustment program for epson CX7300, CX8300 and CX9300F
Adjustment program for epson CX7300 : http://www.mediafire.com/?8wrkugah2mj
Adjustment program for epson CX8300 : http://www.mediafire.com/?0xfnrgarvuj
Adjustment program for epson CX9300F : http://www.mediafire.com/?o020wlaf6te
Jul 29, 2012 | Epson Stylus Multifunction Inkjet Printer/...
My Epson Stylus Photo R230 will not print. It has 2 red flashing lights & gives an error message:"Parts inside your printer are at the end of their service life. See your printer documentation." if I try to print a test page. It was connected to a continuous feed and printed a page (after replacing cartridges) then stopped. I cannot move the carriage to check cartridges but they all seem ok.
Jast go to the web:
http://epson-r230-reset-software-free.fyxm.net/
Then download The epson r 230 resetter and install the software in your pc. In this time please follow these instruction:
12 Jan 2006
Please follow the steps below to reset the protection counter effectively.
If you have any anti virus software, please deactivate first.
The resetter software (adjprog.exe) requires specific date to run and your anti virus will prevent that.
Make sure you printer is ON and connected to your computer.
Run "Start.bat" file.
This program will set your computer date to 12 Jan 2006.
Click "Accept" button.
Click "Particular adjustment mode" button.
Select on "Waste ink pad counter" and click "OK" button.
Click on "Initialization" button and the program will reset the protection counter.
Click "Finish" button.
Change your computer's date back when it prompted.
Reactivate your anti virus if any.
Thank you.
Jun 07, 2011 | Epson STYLUS R230 InkJet Photo Printer
I refill my epson C60 cartridges and have a chip resetter. Now, the cartridges won't release ink when printing. I get a blank page. The printer recognizes the cartridges. What is causing the blank page?
Put the ink cartridge onto a damp paper towel.
Does ink "bleed" onto the paper towel?
If not, then the print-heads are clogged,
and you should run the "head-cleaning" software (part of the software package for the Epson printer).
Dec 30, 2009 | Epson Stylus CX8300 Printer
have lost my installation disk as I can not install printer to this computer, how could I install without disk???
Here is the support page for the Epson CX8300.
Epson CX8300 Support
Click on the "Drivers & Software" link.
On the left side of the page that opens will be the drop-down menu to select your operating system.
Thanks for using Fixya. If you have any problems, just use the Comment button.
May 19, 2009 | Epson Stylus C86 InkJet Printer
10,737 people viewed this tip
jasbo
jasbo
