Tip & How-To about Toys
How to Sync Stylus with LeapFrog Leapster 2 Learning System
If you need to sync the device to the stylus just follow the steps below.
1. Turn your Leapster 2 off, and remove the game cartridge
2. Hold down the 'hint' button while the game is off. The 'hint' button is the middle small button in the row of three above the directional pad on the left, with a '?' on it.
3. With your finger still firmly on the 'hint' button, turn the Leapster 2 back on. Keep your finger on the 'hint' button.
4. The screen should be displaying the calibration screen. You can release the 'hint' button now.
5. Press the 'A' button on the right to enter the calibration screen.
6. A small '+' sign will appear on the screen. Touch it with the stylus. A new '+' sign will appear. Touch this with the stylus too, and repeat for as many '+' signs as your Leapster 2 throws at you.
7. The screen will return to the calibration screen. You can now turn the machine off. Leave the cartridge out of the console, and turn it back on.
8. Your stylus and touch screen should now be working, enabling you to sign in as usual.
9. If it is working correctly then you can turn it off, add a game cartridge and turn it back on.
Thanks for using Fixya
Toys Logo
I can't calibrate the leapster.I can't get pass enter a name
Welcome to Fixya. If you need to sync the device to the stylus just follow the steps below.
If you have questions please let me know.Thanks for using Fixya
Aug 03, 2011 | LeapFrog Leapster 2 Learning System
Leapster2 is 2 1/2 years old. Placed brand new batteries in Leapster2. Try to power it on, screen comes up like it is going to turn on, and it turns off.
Welcome to FixYa!
Ensure NO GAME is in unit
Power Unit off
While turning Leapster 2 on, hold down HINT KEY. (Key in middle with question mark on left hand side)
Once unit switches to other menu, Hit A to begin calibrating.
Follow prompts with Sylas pen to reprogram Stylus pen.
Once you are done it will return to original Calibrating Menu.
Power Unit off Turn unit on with game inserted. Stylus pen should respond.
1) Ensure that a cartridge is not inserted
2) Hold down the Hint (?) button while turning the unit on. Continue to hold the Hint button down until the LEAPSTER menu appears. 3) When the LEAPSTER menu screen appears, press the A button 4) Touch each of the crosshairs that appear with the stylus 5) Restart unit
Do comment if it helped or not in any manner ill know.
Apr 15, 2011 | Leapster 2 Handheld Game
the pen has stopped working when touching the screen
If your Leapster 2 will turn on, but the touch screen is not responding to the stylus, try re-calibrating the stylus with the screen using the steps below: 1. Turn your Leapster 2 off, and remove the game cartridge.
Thank you for using fixya! I hope I had helped you with your problem. May you have a good day!
Mar 28, 2011 | Leapster 2 Handheld Game
the touch screen does not respond to the stylus what can i do?
Thanks for using Fixya,
Mar 02, 2011 | LeapFrog Leapster 2 Learning System
How do you delete existing profile in Junie B Jones Leapster game
To delete a player profile, go to the player profile screen and press and continue to hold down the following buttons in sequence: Home
A button
Left arrow
Then, touch the X icon that appears at the bottom of the screen and follow audio instructions.
Note: You can only delete a name when all three name slots are filled.
The above procedure only works on LEAPSTER 2.
Directly from Leapster website -
Question How do I delete or change a player name on Leapster™ cartridges? trnsp.gif Answer It is possible to remove a player once you have added three player names to the cartridge. If there is a name on the cartridge that you want to remove, take these steps.
1- Add new players until there are three players on the cartridge.
2- Once you have three players on the cartridge, an "X" will appear below each player's name.
3- Touch the "X", then touch the name of the player you want to delete. Touch "Yes" to delete the name. Then add a new name, or touch OK twice to go back to the sign-in screen without adding a name. Two names will always remain on the cartridge.
This is a design flaw with leapsters games (apparently nobody thought to think that they do get sold secondhand or passed down in families)
Since you havent specified the system -
LEAPSTER ORIGINAL
LEAPSTER 2
LEAPSTER LMAX
Clicking on any of the above will get you the owners manuals in PDF format.
Thanks for using FixYa - if you need more clarification on your question, please reply to me first.
Thank you.
Apr 04, 2009 | Leapster Electronic Book: Junie B. Jones...
3,393 people viewed this tip
Top Toys Experts
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Toy Expert? Answer questions, earn points and help others
