Tip & How-To about Computers & Internet
Sony PCG-7142L - VGN-NS110E CMOS Reset via jumper
This method will remove the master password from the system or reset the CMOS when the system will not boot to allow bios clearing.
1) First you need to remove the ram cover at the back of the unit.
2) Remove the battery from the unit
3) Remove the 2nd Dimm if it is there (the one closest to you)
4) Locate solder beads J3. This is what you will jump
5) Next you will need to lay the laptop on its' side.
6) Jump the J3 beads and then turn the unit on.
7) If you did this all correctly, the unit will clear its cmos and reset.
8) Turn unit off and then replace the memory, memory cover and battery.
Good luck
Computers & Internet Logo
need hdd master password
When you boot up to the log in screen type in administrator as user to log in if you cant log in
during the boot up process you will see on the screen for a short amount of time press a certain key to enter set up press and hold that key during the boot up process to enter BIOS scroll down to set user password or supervisor password you can change or remove your password from there
also
The most common way that we know on how to reset or clear the BIOS password is to physically remove the power from the computer by disconnecting the power plug and then removing the Cmos battery for 30 minutes from the motherboard. Another way is to reset the clear CMOS jumper on the motherboard itself. Both of the 2 methods mentioned works because most motherboards use a battery to sustain the BIOS/CMOS settings for the motherboards PROM chip. So by cutting off cmos the battery power, the BIOS/CMOS settings will be erased. Hope this helps
Aug 07, 2011 | Toshiba MK2529GSG (HDD1F07) 250 GB SATA...
How to reset or remove BIOS password
My HP2230s was BIOS locked. How can I boor up the Hiren's boot CD?
Dec 12, 2010 | Computers & Internet
hello : my problem is i have laptop acer model 5230z : i cant access to the bios becuas is encrypted in passwoed and i try all way that found in web put is no result thank you i hope be help me
There are four common categories of solutions to remove or reset a BIOS password and here are the details on how to go about resetting your BIOS password.
Manufacturer Backdoor BIOS Password
Most of the BIOS makers have set a backdoor password on the older computer models. That is the master password for BIOS. To reset BIOS passwords first you need to check the manufacturer of your computer's BIOS. Most computers have BIOS include AMI,
IBM, Award, and Phoenix. These are the most common BIOS. You can unlock your locked BIOS using this master password. It works, no matter what the user sets the password to. Many popular computer and laptop manufacturers such as HP and DELL lock the BIOS because they want to protect their machine's most sensitive areas (those areas which have warranty) from their customers. These passwords are usually used by computer technicians for testing and repairing.
Reset the jumper that holds the password
Open the computer and locate on the motherboard the BIOS password jumper. The jumper is usually jumper 1 and often labeled as PSWD, PWD, CLRPWD, CLEAR, JCMOS1, CLR, CLEAR CMOS, PASSWD, or PASSWORD. Normally you would have 3 pins and to reset the password you just need to put the jumper on the 2 and 3 pins leaving pin 1 empty. After you move the jumper, turn the computer on to clear the password, then once password removed turn it off and put the jumper back to its original position.
Removing the CMOS Battery to reset the BIOS to default
Switch off your computer, and open up the case. You'll see a circular metallic silver item on motherboard. This is called CMOS Battery. Remove it carefully, and leave it out for about 2 minutes. This act will remove the CMOS memory which contains BIOS password. Set the CMOS battery back and switch on the computer. Restore the CMOS configuration as default. Your BIOS password has been cleared now.
Using third party software utility to reset BIOS password
To reset BIOS you can use third party software like Kill CMOS which wipes out CMOS, or CmosPwd which is a BIOS utility. Hiren's Boot CD has a few programs including the above two that will help you to reset the password. Here is a link to Hirens Boot CD website http://www.hirensbootcd.org/. To download the latest version, click on the Download link on the left side and go to the last page. You will need a CD writer to put the content on a blank CD.
Please let me know whether this works or not.
Dec 26, 2010 | Computers & Internet
My Dell XPS 400 PC will not Boot up past the "System password"
Both the system password and the BIOS password are set in the BIOS CMOS. You need to clear the CMOS.
The online Dell service manual for the XPS 400 provides a clear and detailed procedure for clearing the CMOS. It's just a matter of moving some jumpers around:
http://support.dell.com/support/edocs/systems/xps400/sm/index.htm
If you are not used to working inside computers, start with "Removing the computer cover", then go to "System Setup" and click on "Clearing Forgotten Passwords".
Another method is to unplug the power cord and remove the CMOS battery for a 1/2 hour or so. For details on how to do that, try this website:
http://www.askvg.com/how-to-reset-remove-bypass-a-bios-or-cmos-password/
May 22, 2010 | Dell XPS 400 PC Desktop
type the correct pass word to continue and press enter
A. By Using the Motherboard Jumper:
In most motherboards CMOS battery is soldered, which makes it difficult to remove the battery. In this case we use another method.
Almost all motherboards contain a jumper that can clear all CMOS settings along with the BIOS password. The location of this jumper varies depending upon the motherboard brand. You should read your motherboard manual to check its location. If you don't have the manual then look for the jumpers near the CMOS battery. Most of the manufacturer label the jumper as CLR, CLEAR, CLEAR CMOS, etc.
When you find the jumper, look carefully. There will be 3 pins and the jumper will be joining the center pin to either left or right pin. What you need to do, is remove the jumper and join the center pin to the opposite pin. e.g. if the jumper joins center pin to left pin, then remove it and join center pin to right pin. Now wait for a few seconds and then again remove the jumper and join the center pin to left pin.
Make sure to turn the PC off before opening the cabinet and resetting the jumper.
B. By Using Software:
I have found that BIOS/CMOS Password Recovery Tool is the most effective.:
BIOS/CMOS Password Recovery Tool is a program that works instantly to remove any lost or forgotten BIOS/CMOS password. Simply boot your PC to DOS and execute the program, and get access to forgotten BIOS/CMOS passwords in just seconds
BIOS/CMOS Password Recovery Tool Service: http://www.biospasswordrecovery.com/
Sep 09, 2009 | Dell Vostro 1500 Notebook
2,269 people viewed this tip
David Payne
David Payne
