Tip & How-To about Office Equipment & Supplies
Reset all models of Brother Printers
Applicable for all models of Brother Printers. Sorry, I still not yet tried this method because very difficult to get Brother Printer, this is possible cause of the printer is not popular printer. For everyone that having Brother Printer, I hope this post can assist your.
  1. Disconnect the power cord from your Brother Printer.
  2. Press Set button, while holding the Set button re-connect the power to your printer
  3. The Error code will be display "Machine Error 46′
  4. If the Error code appear, press the "arrow up button" ( ^ ) there will be numbers that are going to be display.
  5. Choose 8 then press Set Button
  6. Press Arrow Up button again then choose Zero (0) and press Set Button Again, now you will enter Service Mode.
  7. Press "Mono Key/Button" 25 times or until "Purge Counter Appear"
  8. Now press arrow up (^) again then choose "2′ press Set Button
  9. Press Arrow Up (^) again then choose "7′ press Set Button
  10. Press Arrow Up (^) again then choose "8′ press Set Button
  11. Press Arrow Up (^) again then choose "3′ press Set Button
  12. The purge counter will be reset to Zero.
  13. Now Press Stop/Exit Button
  14. You will return to Machine Error 46
  15. Press Arrow Up (^) then choose 9 press Set Button
  16. Press Arrow Up (^) again then once more choose 9 press Set Button
  17. Your Printer will reset then wait until it power up again.
Clear an F4 error message
Error F4 is caused by a loss of voltage on the printhead!
The printhead must be replaced, and it costs alot, also is so difficult to change, so much as some printer technicians don't accept to repair them.
Sorry, but you need a new printer
If you buy genuine ink cartridges take an EPSON printer
If you prefer to buy compatible ink cartridges look for a Canon ;)
Oct 20, 2014 | Brother MFC Office Equipment & Supplies
I need to Instole it in my PC I have lost the disk please help
You candownload the Brother printer drivers from their support WEB site. Please clickon this link and select your model printer to download : -http://www.brother.com.au/ProductsSolutions.aspx
Feb 03, 2012 | Brother DCP-135C Flatbed Digital MFC...
My Brother MFC 7420 frequently jams. How can I prevent this problem? Renee
Try to perform maintenance.
Go to 'Start' menu
Select 'Printers & Faxes'
Right click on your printer (MFC)
Select properties.
Here you may see a list of tabs that will perform maintenance. One in particular that I am hoping is listed is the option to clean the rollers (what keeps the paper feeding smoothly).
Good luck and sorry for the speculations. I do not own or have personal experience with this printer, however, most printers (especially newer models) have these features that can help clear up these types of issues.
Jan 24, 2011 | Brother MFC 7420 All-In-One Laser Printer
i have hp officejet pro 8500 wireless every time i try to print it want me to fax
Printing with HP Photosmart printers is controlled by the driver software that is installed during the printer driver installation. Changes to the printer preferences can be set and changed in the Preferences dialog box. Changing preferences from within a software application Preferences set from within a software application will only change settings for the application or the current document, depending upon the application. The methods of accessing the dialog box will differ, depending on the software program being used. One of the following methods will usually open the Preferences dialog box from within the application:
  • Click File , Print , then click the Preferences or Properties button.
  • Click File , Print Setup , then click the Preferences or Properties button.
  • Click File , Print , Setup , then click the Properties button.
  • Click Print , Properties , then click Printer Assistant .
Changing the default settings Preferences changed from within the printer driver will change the default settings for the printer. One of the following methods will open the printer driver Preferences dialog box:
  • Click the Taskbar Printer icon.
  • Right-click the applicable Photosmart icon in the Printers folder, then click Printer Preferences from the pop-up menu.
  • Right-click the applicable Photosmart icon in the Printers folder, click Properties from the pop-up menu, and then click the Printer Preferences button on the General tab.
If you need more help come back.Post / thumbs / testimonial are welcome!
Nov 15, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
476 people viewed this tip
jasbo
jasbo
