Tip & How-To about Computers & Internet
How to Change your wallpaper in Windows 7
On your desktop, (this is the screen that you see right after you login to windows) Do a right-click and then left click on Personalization.
Click on the Desktop Background (See Screenshot below)
This will take you to the following window:
Click on the picture you like to be your wallpaper, you also set it as a slide show if you chose a lot of pictures. Plus, you can set it up how the pictures will be positioned and how many minutes before it changes to the next picture.
Once your done, click on Save Changes
Computers & Internet Logo
screen saver wallpaper
To set or change a screen saver in XP
1.
Open Display in Control Panel.
2.
On the Screen Saver tab, under Screen saver, click a screen saver in the list.
FOR WINDOWS VISTA & 7
  1. Open Screen Saver Settings by clicking the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33_47.png, clicking Control Panel, clicking Appearance and Personalization, clicking Personalization, and then clicking Screen Saver.
  2. Under Screen saver, in the drop-down list, click the screen saver you want to use.
Click Preview to see what your chosen screen saver will look like.
Click OK.
Also make sure "On resume, display login screen" is unchecked.
Jan 16, 2013 | Computers & Internet
how to change wallpaper for hp mini 210 3000
HI........................
Using the "Personalization Panel" Program
notesmall1.png Note This will show you how to download and use the Personalization Panel program to add Personalization to the desktop context menu to be able to change the desktop background, Windows Color and Appearance, Sounds, and Screen Saver in the Windows 7 Starter and Home Basic editions.
This program does not add the desktop slideshow feature though. 1. Download and install the Personalization Panel program
2. When finished installing, you can now right click on the desktop and click on Personalization.
3. If prompted by UAC, then click on Yes.
4. From here you can select and set the Appearance and Personalization options you like. (see screenshot below)158605d1307509511t-desktop-background-change-windows-7-starter-personalize-1.jpg
5. Desktop BackgroundA) In Windows Starter158606d1307509511t-desktop-background-change-windows-7-starter-starter-1.jpg
B) In Windows Home Basic158607d1307509511t-desktop-background-change-windows-7-starter-basic-1.jpg
6. Windows ColorA) In Windows Starter158608d1307509511t-desktop-background-change-windows-7-starter-starter-2.jpg
B) In Windows Home Basic158610d1307509524t-desktop-background-change-windows-7-starter-basic-2a.jpg
7. SoundsA) This is the same Sounds settings as in the other editions of Windows 7.
8. Screen SaverA) This is the same Screen Saver settings as in the other editions of Windows 7.
That's it,
GOOD LUCK.....................
Sep 26, 2011 | HP Mini 1000 Netbook
I have a Sony vaio laptop with OS of windows 7 Home premium and converted to window 7 ultimate. My problem now the screen is dim and I can't adjust the brightness
1. Click on Start -> Type " Personalization " / Right Click on the desktop Left Click on " Personalize " 2. Under the Personalization window Click on Windows Color 3. Slide the Color Intensity bar to the right ....
Hope This Helps
May 29, 2011 | Sony Computers & Internet
how can i change my display settings on my inspirion mini i cant change my screen resolution
Just right click on a BLANK area of screen and select the graphic properities from there
depending on the operating syetem vista and windows 7 will actually offer you the "change resolution" option near the bottom of the pop up when you do that.
Feb 04, 2011 | Dell Inspirion Mini 884116022442 Notebook
my icons no longer appear on my desktop
1.Go to control panel and click on personalization
2.On the left hand column of the 'personalization' screen you will get 'Tasks"
3. Under tasks click on - change desktop icons
4.check on the desktop icons you need.
5. click ok
Mar 09, 2010 | Computers & Internet
250 people viewed this tip
David Payne
David Payne
