Tip & How-To about Computers & Internet
How to retrieve data from a broken laptop.
Most people today with careers on the go have a laptop. With this mobility comes great sacrifice and that's because of the risk of hard disk failure thorough dropping or mishandling. When this happens the only thing on their minds is if they'll ever see their data again. This wouldn't be such a crisis if they recently made a backup but then again how many do. So if your laptop has broken or stopped working then here is what you can do to retrieve the data yourself.
We're going to assume that the hard drive survived and is still functional.
First of all you're going to need to dismantle the laptop to remove the hard drive. As there are so many different types of laptops out there I can't give you a universal way to dismantle it, if you want the dismantling instructions just type How to dismantle Your laptops model name here laptop for example into Google or Yahoo!
We want to be able to access the data on the hard drive so you'll need a IDE to USB cable (for older drives) or a SATA to USB cable (for newer drives). This all depends of which connector your laptop's drive has. You'll need a 12 volt source for the hard disk which can be obtained from a molex power cable in the PC.
Plug the power from your power supply to the required power connector on the drive (normally a molex connector or newer thin power connecor on more recent power supplies that use SATA technology) and then plug the data cable USB into one of your free USB ports and boot up the PC.
Look around in my computer and you should see the laptop hard disk listed, it should be seen as an external hard disk just like a flash drive when you plug it in.
Copy over all the files and information that you want recovered to the desktop. Depending on the situation, you may want to format the hard disk, re-install the OS, and then re-use the hard disk.
When you purchase a new laptop you can then copy the recovered data onto it and there you have it just like before. Remember to make regular back-ups of important files in the future as the hard drive may not always be working if the laptop fails.
This is what a IDE drive looks like, notice the many pins in the IDE connection.
This is what a SATA drive looks like notice the large L shaped data connection and the smaller L shaped power connection.
Computers & Internet Logo
e-studio35 copier touch screen will come on but blank and will not copy
if the touch screen showed warming up display forever check the hard disk
You can format the hard disk as an optional choice but with the risk of data loss such as efiling storage and address data will be deleted
Press 08 on machine and key in 690
press start and key in 2
press start again and wait the formatting complete
if the problem come back high chance the hard disk failure
Jan 21, 2014 | Toshiba e-Studio 350 Copier
What are the career opportunities of mobile application development and how can it be learned?
You can jump right into mobile application development and learn step by step application development. If your basics aren't clear you won't be able to stand a chance against those frameworks data structure, database, user experience design and other stuff that is required for building an app.
This takes time and it pretty much depends on your Education as well. If you are BSCS student you will have OOP concepts somewhere in your mind you just need to recall them with the programming language of your choice. If you're education is other then Computer Science then you need to start from very basics of OOP (Object Oriented Programming).
First you need to select the OS platform for which you want to develop mobile applications. For IOS you will need to learn C and swift and for android you will need to learn Java and Android Studio there are other technologies as well which offer hybrid application development such as Xamrain React.Native and Apache Cordova as well.
I would recommend you to learn C from the beginning and learn swift which is a tool for developing iOS applications, side by side. Plan everything don't jump into coding from the beginning, Set milestones per month and week. Stick with your plan. Give more time for coding, and my advice wake-up early in the morning to learn to code.
If you can't understand an error don't get hasty in solving that error because its sometimes very hectic to find a single error which might be as small as missing a semi colon ( ; ) try to be polite with errors as that is the only key for resolving errors fast. I hope this helped you and answered your questions.
For development of native mobile application you will need to learn Apache cordova and C# because its a Microsoft development tool powered with Visual Studio IDE. For development in React Native you should have full hands-on experience in JavaScript development, but for many experienced developers JavaScript is a bad choice for beginners.
Jan 13, 2014 | Cars & Trucks
smart failure predicted on hard disk/ acer laptop during booting
you'll need to backup your critical info on a storage medium and replace your hard drive. As there is noo telling when the hard drive will crash maybe today maybe next year. If you need help in removing the hard drive please state model and i will help
Feb 21, 2010 | Acer TravelMate 507T Notebook
367 people viewed this tip
David Payne
David Payne
