Tip & How-To about Sony Playstation 3 (PS3) Console
Lite-on
[IMG]http://hotimg23.fotki.com/a/4_90/63_164/IMG_0978-vi.jpg[/IMG]
I've had my Lite-On LH-20A1S SATA connector optical drive for about three years, and in the past year or so it had become difficult to get the tray to open whether there was a disc in it or not. I had to push the button very hard and hold it for several seconds, releasing it, pushing it and doing this three or more times to get the tray to open. Then, in the past couple of months, closing the tray has become difficult, needing to push and hold the button very firmly. Even a paper clip would not open the tray, nor did using computer to "eject" to open the tra
Sony Playstation 3 (PS3) Console Logo
what does f25 eror mean
F25 indicates a possible drive motor tachometer error. (NOTE: The tech sheet is located behind the front quarter panel– remove the three hex head screws at the very bottom to remove the panel. The tech sheets will be folded up in a little plastic pouch.
The f25 error code is a motor tachometer error. To determine the problem you will have to remove the top cover and the front access panel. On some models, the rear panel will have to be taken off for easier access to the motor control. Now with the washer-unplugged remove the each plug one at a time and make sure the pins in the connector are not bent then reseat them on the board. Now retest the washer. If the washer still fails, you will need a meter to ohm the motor.
With the washer unplugged, locate the motor harness. Now unplug the motor connector to ohm the motor. Follow the list below to check the motor.
* Pin 1 to 3 6 ohms
* Pin 1 to2 6 ohms
* Pin 2 to 3 6 ohms
* Pin 4 to5 115 ohms
If the readings are close to what is listed above the motor is fine.
Live voltage checks are dangerous, and possibly deadly. Exercise caution at all times. If you are not comfortable working with live electricity I suggest you call an experienced service technician. I have provided you with a wire diagram with what the voltages should be. If the voltages are correct I would then recommend that you replace the motor control.
http://media.fotki.com/1_p,ssqftgqdqbftqgbxgtqsskgwtqkq,vi/sbbsgkqrgxstbrqrgwf/1/1303472/5961857/image5533851340308453439img-or.jpg
http://media.fotki.com/1_p,ssqftgqgtstgdfrxgtqsskgwtqkq,vi/wwkfkbqwwxkftrskdkw/1/1303472/5961857/image1769329000959650960img-or.jpg
http://media.fotki.com/1_p,ssqftgqbrdddksdxgtqsskgwtqkq,vi/stbrqrgwfxsbdkgqfbr/1/1303472/5961857/image5269611314094350944img-or.jpg
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 10, 2010 | Whirlpool Duet GHW9150P Front Load Washer
my kenmore he2 plus front loader washer machine has a code F25 what do I do?
F25 indicates a possible drive motor tachometer error. (NOTE: The tech sheet is located behind the front quarter panel- remove the three hex head screws at the very bottom to remove the panel. The tech sheets will be folded up in a little plastic pouch.
* Pin 1 to 3 6 ohms
* Pin 1 to2 6 ohms
* Pin 2 to 3 6 ohms
Feb 15, 2010 | Kenmore HE2 Plus Front Load Washer
code f25 error kenmore elite he5
Nov 09, 2009 | Kenmore Washing Machines
whirlpool washer wfw8400tw codef25
* Pin 1 to 3 6 ohms
* Pin 1 to2 6 ohms
* Pin 2 to 3 6 ohms
Oct 29, 2009 | Whirlpool Duet GHW9150P Front Load Washer
kenmore he2 plus washer stopped mid cycle - flashes f-25 which is drive motor tachometer error - I unplugged and then plugged in again - ran wash and got same code - any suggestions
* Pin 1 to 3 6 ohms
* Pin 1 to2 6 ohms
* Pin 2 to 3 6 ohms
Jun 28, 2009 | Kenmore HE2 Plus Front Load Washer
773 people viewed this tip
Top Sony Video Game Consoles & Games Experts
shaun taylor
marley mcelhinney
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
