Tip & How-To about LG 42LC2D 42 in. LCD HDTV
Plasma TV viewing tip
When watching a plasma TV make sure that your room lighting is with in 1/3 of the distance between the TV panel and your seating position ( when measured from the screen end ). In other words, if the TV is off you should not be able to see the light source on the blank screen from your seating position. This method can reduce a lot of eye strain while viewing .
LG 42LC2D 42 in. LCD HDTV Logo
lg plasma tv 42PA4500 no picture
1) Make sure it is plugged in
2) check the power cord to make sure it is tight on both ends
3) plug something else into the wall outlet to make sure that it is working properly
3) If the power light comes on than it is not a power problem, check the cords to the cable TV or to the DVD player, or whatever it is you are trying to watch
4) If the power light comes on but the screen is black, use your remote to make sure you are on the correct input channel to watch whatever you have hooked up to the TV. For instance, if you are watching cable, and it is plugged into input 4, you need to make sure that you have input 4 selected or else you will get a black screen.
Jul 30, 2014 | LG 42PG20 42 in. Plasma HDTV
reflection off of screen
Plasma TV's are known for their glare and reflection issues, you can still fix it by buying a third party anti-glare filter and applying it on your television. For example, "ViewGuard" makes filters that goes up to 65" in size. It is not cheap though, depending on the size of your television.
Of course, the best solution is to adapt your room accordingly. If the glare is caused by the sun light coming from the windows, installing curtains on your windows or moving your television to a better spot is a very effective way to reduce the glare and the reflections on your television.
If the glare is caused by the room's lights, the best solution is to install ceiling spot lights with a dimmer.
Hope that helps!
Mar 19, 2014 | Samsung 51 Class Plasma 1080p 600Hz Smart...
pink vertical line in center of screen th-42pz80u
it could be either the SD or SU boards going. check the cable connections and make sure the ribbon cables are seated properly.
Feb 24, 2013 | Panasonic Viera TH-50PZ80U Plasma TV
how to install a home theater
Follow these steps:
•Plan out your setup. Before you start unpacking speakers and moving furniture, it's a good idea to have a placement scheme in mind.
•2
Consider the location of the outlets in your home theatre room. If possible, choose a room powered by a single circuit breaker to reduce the risk of damage due to the overload your home theatre system might cause. Supplement the number of outlets with power strips.
•3
Place your TV. The television should be placed where it can be viewed straight on. The center of the screen should be aligned with the eyes of a seated person.
•4
Place your speakers before you start hooking things up. If there are hearing-imparied people in your household, place the speakers so that someone could sit directly next to at least one speaker.
•5
Position your central channel speaker above or below your TV. If you put it on top of your TV, make sure the front edge of the speaker is aligned evenly with the front of your TV screen.
•6
Place your front left and right speakers at equal distances on either side of your TV. The height of your left and right speakers should match the height of your central channel speaker.
•7
Put your surround speakers at equal distances to the left and right of where you would normally sit and view your TV. Do not point your surround speakers directly at your viewing position. Try pointing them toward the back of the room or toward the ceiling.
•8
Place your subwoofer to the side of the room, about halfway between your viewing position and your TV. You can adjust the bass reaction of your subwoofer by moving it closer to a wall to increase the bass, or by moving it away from a wall to decrease it.
•9
Connect your speakers and theater system by running flat speaker cables down the length of your baseboard or lower portion of your wall. Consult your owner's manual for exact instructions.
Mar 13, 2011 | Philips 55PFL7505DF7 55 in LCD TV
white corners SONY KDL52XBR6
This is called a dark shading error. All the LCD consumer sets have some visible degree of this effect. Some will be a little less or more than others even from the same batch in the assembly run. This has to do with the optical design quality of how the back-plane lamps illuminate the screen. The design and assembly tollerance of this area is very critical.
Normally, LCD screens don't show their best picture in a darkened room. The very black regions of the picture content may look a little washed out. LCD screens are best watched in a room that is lit, but not very bright. You have to consider that there is a powerful set of lights behind the polarized panel of the LCD display, and there will always be some breakthrough of light.
If you want a TV that is more like a CRT in its characteristics a Plasma would have been a good choice. The trade-off with the Plasma is that it does not have the picture sharpness of the LCD. A Plasma set is best watched in a darkened room.
If you have an LCD computer monitor, take a look at it in a dark room with a black screen. You will most likely see the dark shading errors. Only the very expensive production studio type LCD monitors have less of this error than the consumer sets, and they are not absolutely perfect.
Jerry G.
Nov 19, 2008 | Sony BRAVIA KDL-40S2010 40 in. LCD...
3,929 people viewed this tip
Computer Repairing
Computer Repairing
