Tip & How-To about Nokia E5 Cell Phone
How to unlock your Phone when you've forgotten the Unlock Code
It happens people forget things, but this is a simple and quick fix.
Step 1: Locate your Battery cover and remove it.
Step 2: Take out your Battery.
Step 3: Put the Battery back in.
Your phone will reboot and should be unlocked. This will work on a majority of code locking phones, the exception being some smart-phones.
Nokia E5 Cell Phone Logo
unable to turn the phone on the only thing that happens is that the screen lights up for 1 seconds
Cell phones get worn out and break from daily use. The Motorola Razr is no exception. While this phone may be durable against minor accidents, it can still stop working without warning. From a blank screen to water in the phone, there are a few simple methods you can use to try and fix your phone before you pay for costly repairs or resort to buying a new cell phonemag-glass_10x10.gif. Try these tricks to get your phone working again.
  1. tep 1 Check your warranty. If the phone is still under warranty, contact your cell phone provider to get it fixed for free.
  2. Step 2 Turn the phone off. Take the back cover off the phone. Remove the battery and reinsert it. Replace the cover and turn the phone on. Sometimes the phone will begin working again with this simple step.
  3. Step 3 Turn the phone off and back on if the phone will turn on but won't work or has a blank screen.
  4. Step 4 Buy a new battery if the phone won't stay charged. Check that your phone's charger isn't broken or damaged. Make sure the phone says "Charging" when the charger is plugged into the phone.
  5. Step 5 If the phone has been dropped in water, take off the back cover and remove the battery. Dry the phone with a paper towel and a hair dryer on the lowest heat setting. Stop every two to three minutes and let the phone cool down before starting again. Wait three days, then reassemble the phone and try to turn it on
Nov 14, 2009 | Motorola Mobility RAZR V3
wireless mouse
INSTALLING THE MOUSE
STEP 1 - Battery Installation:
The first step in installing your Wireless Wheel Mouse is to install the batteries.
1 - Locate the two AAA sized 1.5 Volt batteries that came in your Wireless Wheel Mouse package.
2 - Remove the battery compartment cover located on top of your mouse by pressing the cover release button and sliding the cover backwards.
3 - Install the two batteries into the compartment paying close attention to proper polarities.
4 - Replace the battery compartment cover.
STEP 2 - Connecting the Receiver:
If you are connecting the mouse to a notebook that has an onboard pointing device or if you are using a keyboard with an onboard pointing device, you may need to
disable that device before installing and using the mouse.
Sep 14, 2008 | Computers & Internet
need to locate control head for ac and locate ac expansion valve
step 1.Remove steering wheel horn cover
step 2.Remove steering wheel retaining nut (disconect airbag if so equipped)
step 3.Using moderate force remove wheel from steering column
step 4.Discard vehicle (donate,push off cliff,leave on train tracks,ect)
step 5.Purchase new vehicle (preferably a non-lemon)
step 6.Swap steering wheel with one from step 3
step 7.Enjoy the feeling of having "fixed" your auto troubles
Jul 31, 2008 | 1998 Dodge Ram 1500 4WD
lens cover error
TIPS:
1.)NEVER PUSH THE LENS IN AFTER CAMERA DIES, BUY A NEW BATTERY IMMEDIATLY AND TURN IT BACK ON, CLOSING THE LENS!
2.)NEVER USE AN AC ADAPTER, USE A RECHARGEABLE BATTERY OR A REGULAR BATTERY!
..to fix this...
Do as i say..
1.) Remove battery
2.) Remove front plate (screw driver may be needed)
3.) Check all gears, make sure they are correctly fitted in place)
4.) Move the gear manually to make the lens come out.
5.) keep it out, put the front plate back together.
6.) reinsert the battery, turn it on.
or...
1.) Remove the battery.
2.) Wait about 6-8 hours.
3.) Reinsert the battery.
or...
2.) Try hooking it up through AC adapter, put correct voltage.
3.) Try turning it on.
4.) Remove AC adapter, reinsert battery.
5.) Turn it on.
Hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE
Jun 17, 2008 | Nikon Coolpix S1 Digital Camera
2,575 people viewed this tip
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
