Tip & How-To about Computers & Internet
How to perform a Disk Cleanup.
Disk cleanup
The Disk Cleanup tool helps you free up disk space by searching your disk for unwanted files and temporary files that you can safely delete without problems. It can remove all of the following:
Files in the Recycle Bin.
Temporary Internet files.
Temporary Windows files located in the Temporary files folder.
Optional Windows components that you are not using.
Installed programs that you no longer use or wish to use.
To launch the Disk Cleanup tool via Start menu go to Start > All Programs > Accessories > System Tools
A dialogue window should now appear enabling you to select the drive you want to clean up. Select the required drive and click OK.
The specified drive will be examined and the amount of space you can potentially free up is calculated and displayed.
The results, showing the amount of space that can be recovered by deleting files a secific type of file that is not needed is then displayed on the Disk Cleanup tab as shown below.
Select the files and click Ok to remove these un-needed files.
Now that a Disk Cleanup has been performed your hard drive should perform slightly faster and have less clutter lying around.
I suggest you perform the disk cleanup tool every once in a while to ensure that your hard drive has a greater lifespan, never has any need to crash or come up with errors caused by unnecessary files, greater performance and increased productivity especially where it is needed most, in the workplace.
Computers & Internet Logo
computer is slow
your System may be slow due to following reason
- Too many programs running at startup or in the background
- Data Corruption, hard disk fragmentation
- Missing Windows updates or outdated drivers
- Not enough hard drive space, too many unused programs
- Left over programs, old cached and temporary files
So Follow these steps to fix computer problem::
- Delete all the temp files
- Remove unused programs
- install latest drivers from the manufacturer site
- Install and run antispyware software
- Free up wasted space with Disk Cleanup tool
- Defragment your hard disk drive
If you are unable to perform above tasks then use a single utility tool like PC Fresher that will fix windows errors that cause of system slow
Sep 08, 2013 | Computers & Internet
usb speed 900kbps
you might have to many programs running at the same time putting to much strain on the CPU central processing unit
try uninstalling a few unnecessary programs This tool deletes unnecessary or temporary files on your hard disk so you can increase the amount of storage space you have. Delete the files using Disk Cleanup If you want to reduce the number of unnecessary files on your hard disk to free up disk space and help your computer run faster, use Disk Cleanup. It removes temporary files, empties the Recycle Bin, and removes a variety of system files and other items that you no longer need. Open Disk Cleanup by clicking start all programs accessories system tools and then clicking Disk Cleanup. In the Disk Cleanup Options dialog box, choose whether you want to clean up your own files only or all of the files on the computer. If you are prompted for an administrator password or confirmation, type the password or provide confirmation. If the Disk Cleanup Drive Selection dialog box appears, select the hard disk drive that you want to clean up, and then click OK. Click the Disk Cleanup tab, and then select the check boxes for the files you want to delete. When you finish selecting the files you want to delete, click OK, and then click Delete files to confirm the operation. Disk Cleanup proceeds to remove all unnecessary files from your computer. This tool deletes unnecessary or temporary files on your hard disk so you can increase the amount of storage space you have. Delete the files using Disk Cleanup If you want to reduce the number of unnecessary files on your hard disk to free up disk space and help your computer run faster, use Disk Cleanup. It removes temporary files, empties the Recycle Bin, and removes a variety of system files and other items that you no longer need. Watch the demo (1:00) this should speed up your computer
Mar 12, 2013 | Computers & Internet
UNIBLUE SPEED UP MYPC 2013 LICENSE KEY
IT'S A SCAM, DELETE IT. SEE: http://answers.microsoft.com/en-us/windows/forum/windows_vista-security/uniblue-scam-and-very-harmful-virusesmalware/ecf044e8-9c5e-e011-8dfc-68b599b31bf5 Use Freeware MALWAREBYTES to remove, if necessary. Download at : http://www.filehippo.com/download_malwarebytes_anti_malware/ In the install UNCHECK the TRIAL PRO version, you want the freeware version, Run a FULL Scan, Delete ALL results, reboot machine. If you must , Boot to Safe-Mode with Networking and download, install, run.
Feb 08, 2013 | Dell Inspiron Mini 1012 Netbook...
i have dell inspiron 5160 is very slow n getting problem in more time now problem is laptop wanted boot ,where is problem i dont know but stopped in unwanted time n after
5 ways to speed up your PC
By following a few simple guidelines, you can maintain your computer and keep it running smoothly. This article discusses how to use the tools available in Windows 7, Vista, and http://www.microsoft.com/atwork/maintenance/speed.aspx#">XP Service Pack 3 (SP3) to more efficiently maintain your computer and safeguard your privacy when you're online.
1. Free up disk space
The Disk Cleanup tool helps you free up space on your hard disk to improve the performance of your computer. The tool identifies files that you can safely delete, and then enables you to choose whether you want to delete some or all of the identified files.
Use Disk Cleanup to:
  • Remove temporary Internet files.
  • Remove downloaded program files (such as Microsoft ActiveX controls and Java applets).
  • Empty the Recycle Bin.
  • Remove Windows temporary files such as error reports.
  • Remove optional Windows components that you don't use.
  • Remove installed programs that you no longer use.
  • Remove unused restore points and shadow copies from System Restore.
Tip: Typically, temporary Internet files take the most amount of space because the browser caches each page you visit for faster access later.
To use Disk Cleanup
Window 7 users
  1. Click Start, click All Programs, click Accessories, click System Tools, then click Disk Cleanup. If several drives are available, you might be prompted to specify which drive you want to clean.
  2. When Disk Cleanup has calculated how much space you can free, in the Disk Cleanup for dialog box, scroll through the content of the Files to delete list.
  3. MORE INFORMATION GO TO THIS LINK: http://www.microsoft.com/atwork/maintenance/speed.aspx
Dec 06, 2010 | Dell Computers & Internet
Have an ACER netbook. It was running very slowly. Was told that there is zero space left on the hard drive and that a system restore is required. Would you please tell me how to do this? Thanks
I recommend you have a quick look in your documents, music & pictures folders and clean out unused/unwanted files first.
System restore is a great tool but not usually the right tool to use to free up hdd space :)
If your running on Windows I also suggest running the Disk Cleanup wizard.
Win 7 / Vista : Start -> Accessories -> System Tools -> Disk Cleanup.
Win XP : Start -> All programs -> Accessories -> System Tools -> Disk Cleanup.
Once DC has analyzed the PC it will come up with a set of options. It should be safe to select the following and Click OK to continue removing them.
  1. Temporary Internet Files
  2. Recycle Bin
  3. Debug Dump files (WIN 7 / Vista)
  4. Temporary Files
Once you click OK Windows will then remove these files from your HDD freeing up some space. Its always a good idea to run Disk Defragmenter afterwards to ensure optimum performance.
Win 7 / Vista : Start -> Accessories -> System Tools -> Disk Defragmenter.
Win XP : Start -> All programs -> Accessories -> System Tools -> Disk Defragmenter.
Select your primary O/S drive (usually C:) from the list and Click Defragment. Wait for the Defragementer to complete (It might take some time :) ) then restart the PC.
Hope this helps
BD
Sep 23, 2010 | Acer Aspire One Netbook 8.9" Notebook
469 people viewed this tip
David Payne
David Payne
