Tip & How-To about Tools & Hardware - Others
Paslode Cordless Nailer Problems
Paslode cordless nailers are a very common tool used by many professionals and do it yourselfers. These nail guns are a great tool when they work correctly, but can drive you nuts when they do not work as they should. When answering problems that people have on www.Fixya.com I come across many questions about these nail guns and why they do not work.
If you are having problems with your Paslode nail gun the first thing you need to do is get the Paslode manual out of the box and checkout how to clean the nail gun. One of the most common causes for these nail guns to have problems is because of a lack of maintenance. If you do not have the manual for your Paslode nailer you can download one here. www.paslode.com/owners-manuals.html
They have all of the current models and also discontinued model Paslode manuals there.
The manual will also contain troubleshooting information also. The troubleshooting guide can often help you to find the problem with your tool. Do not do the common man thing and be too proud to get out the directions and READ them. There are many tips and helps contained in them that will save you a ton of aggravation later.
Now, there are a few things that I have found out through my experiences with this nail gun that are not in the manual.
First, When the manual tells you that the tool needs to be cleaned and lubed regularly it means that you NEED to do that. Most problems are because of a lack of cleaning and lubing the tool.
Besides that, gas cylinders are a problem sometimes even if they are new. If you just replaced the gas cylinder and the nail gun will not work, try another one. Also, sometimes the end that goes on the gas cylinders will not snap on correctly or completely. You sometimes can still get the cylinder into the gun but it will not work because the top is not attached completely or correctly.
Check that the nails do not get jammed in the magazine and then not push up to the front of the gun. No nails, no work. Paper from the nails can sometimes cause them to bind up and not slide front. Make sure to always use nails that are only for the Paslode nail gun.
The firing pin can also be a problem. The firing pin will bend sometimes, but usually because of lack of the right nails or maintenance. Another problem that can happen is that the o-rings around the firing pin will break or crack. When this happens the gun may not fire or the pin will not return after it shoots a nail. If you are having these problems then check the o-rings both top and mid-pin to make sure they are in good shape. If they are chipped or cracked in anyway the gun will not work correctly.
The battery contacts on these nailers are also a problem. They can get dirt and dust in them or become bent. If they fail to make good contact they can cause the gun to have all types of problems. If you are having unexplained problems then check the contacts of both the battery and the gun. You can clean them with a soft cloth or sometimes with a pencil eraser.
The last but least likely problem is the internal wiring in the nail gun. Because of the violent nature of the gun firing the wiring takes a beating inside the nail gun. Every time the gun fires the vibration can cause the wires to move just a bit and eventually a wire can work loose. If all other things check out then look for wires that do not go anywhere. If there is a wire floating around that has no home then you have found your problem. After adjusting the end of the wire so it is tighter, reconnect the wire and you will be working again.
As you can see there are many things that can go wrong with these nail guns. Because of this there also are many things that you can find online that will help you. E-how.com has some tips that will help. You-tube also has some videos that will show you how to clean and troubleshoot these nail guns. Doing a simple online search will give you many places that can help you and also give you sites from which to buy parts if needed.
If you need parts for your nail gun, here is a good place to get those parts.
http://itwconstructionparts.com/xcart/
Tools & Hardware - Others Logo
I am using senco gas in a paslode 2nd fixing nail gun. Is the senco gas 'bad for' my gun in any way as i am having a few firing problems
You can use most gases in your gun, but paslode is the best that's why its more expensive. Try warming the gases in your pocket that sometimes helps.
Dec 17, 2014 | RTO Paslode 902000 IM250 Ii Cordless 16...
looking for the nearest repair shop for paslode nail gun in Northren Va
Have all the nails been cleared out of the tool where they were jammed? If not take the fuel cell out of the tool, and remove the battery before working on it. If still persists come back to this website for further help.
Sep 19, 2014 | Omega Paslode 901000 Impulse Cordless...
Paslode framing nailer: compressor powered, hisses but will not shoot nails, appears to be in the sliding mechanizism that touches the wood first before it will shoot, help
I've used paslode for years and whenever there was a "hiss" of air and no fire- it was o-rings- When were the o-rings changed last? And how do you know they are in 'good shape'? You can't tell by just looking at them. If that isn't the problem then I can't help. Just as an aside- do you oil the gun (down the air intake nipple) every time you use it? Lack of oil will wear out o-rings fast. Sorry if this isn't overly helpfull but most gun problems are o-ring or seal related unless you've worn out or damaged a mechanical part.
Feb 10, 2013 | Air Tools & Compressors
I AM LOOKING FOR AN ELECTRIC ROOFING NAIL GUN, DO YOU CARRY AND WHAT BRAND NAME AT WHAT PRICE?
Raymond - Fixya does not carry or sell tools.
I recommend you go to an online retailer like Amazon.com. Search for "electric roofing nailer", or just "electric nailer" and see what you find. Amazon.com is good source for tool specifications and customer reviews. You don't have to buy from Amazon, but its a good place to research what's out there.
I can tell you one thing...electric (corded) nailers that shoot a nail of that size are uncommon. If you're looking for an alternative to pneumatic, other options include gas-driven (takes a small gas canister - usually a butane mix)...a common brand for this is Paslode. Another option is a cordless battery nailer - I believe Bostitch makes a cordless roofing nailer.
Hope this helps.
DIYpro
Jun 09, 2011 | Ace Hardware Ace & Electric Staple / Nail...
Universal nails appear to be messing up paslode im65 nailguns, 5 guns on one site.
You need to use the correct nails...
Here is a tip that I wrote about the Paslode nailers and the problems that can come up with them.
I also have a link to the Paslode manuals which contain Paslode cleaning and troubleshooting guides.
If you need parts for your Paslode, there also is a link for a site that sells the Paslode nailer parts.
heatman101
Feb 03, 2011 | Craftsman Nailer Kit, Palm Air Driver
21,115 people viewed this tip
Top Tools & Hardware - Others Experts
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
