Tip & How-To about Computers & Internet
Maintain Your Hard Drive.
Your hard disk drive is one of the most important parts of your PC. It's where all your system files, applications and user data is kept. Most people understand the issue of security, the importance of making regular backups of your user data as an insurance policy against hard drive crashes. Few people realise and appreciate the importance of having regular hard disk maintenance which is designed to keep it in good working order.
The ultimate way to revitalise and cleanse your PC is to wipe the hard drive, start from scratch and then reinstall the operating system. However, there is much you can do to avoid such a situation arising, simply by using utilities provided within the bundle of your Windows operating system.
Disk cleanup
The Disk Cleanup tool helps you free up space by searching your disk for unwanted files that you can safely delete. It can remove all of the following:
Temporary Internet files.
Files in the Recycle Bin.
Temporary Windows files located in the Temporary files folder.
Optional Windows components that you are not using.
Installed programs that you no longer use.
To launch Disk Cleanup via Start menu go to Start > All Programs > Accessories > System Tools
A dialogue window should now appear enabling you to select the drive you want to clean up. Select the required drive and click OK.
The specified drive will be exampined and the amount of space you can potentially free up is calculated.
The results, showing the amount of space that can be recovered by deleting files that are not needed are then displayed on the Disk Cleanup tab.
Error Checking
Chkdsk.exe is a utility which verifies the logical integrity of a file system. In the event of the utility encountering logical inconsistencies in file system data, it will perform the necessary actions to repair the file system data. The same utility in earlier versions of Windows was called to as ScanDisk.
To Launch Chkdsk go to My Computer and right-click the hard disk you want to have checked. Then click Properties and select the Tools tab.
Click on Check Now.
A dialogue box showing the Check disk options is displayed.
Select the appropriate options and click Start.
You may get the following message.
If so click Yes and your computer will reboot and then perform the scan.
Disk Defragmentation
Since files are constantly being written, deleted and over written to the hard drive, files are likely to become fragmented and scattered all over the drive. The disk defragment tool takes these files and puts them in order by eliminating spaces between files.
To start the disk defragment tool go to Start > Programs > Accessories > System Tools > Disk Defragmenter
Then select the Tools tab and click Defragment Now.
It should now display the hard drives showing total capacity as well as the free space of the drive(s).
Now select the drive you want to defragment and click Analyse.
The drive is scanned and a visual representation of how it is currently fragmented is displayed.
Depending on the the results of the analysis, you will be advised as to whether or not the volume should be defragmented.
Even if it's not necessary, you can choose to Defragment anyway if you like.
The time it takes to defragment the hard drive is dependent on the size of the drive, how the fragmentation lies and how much free space it has.
As the drive defrags you can see how it is neatly repacking the files by looking at the bottem visual bar.
Once it is complete you will get the following message
You can choose to view the report which will show hard drive information such as free space, used space, cluster size and the free space as a percentage. Or you can just lick Close as the defragmentation is now complete.
Doing these checks frequently will prolong the lifespan of your hard drive and make sure it's running at maximum speed.
Computers & Internet Logo
After I format my hardisk for several times and the file system still showing RAW. how to make it ntfs.
Install the drive on a working computer and access through disc management. that will allow you to initialize the drive and format it ntfs. Goto my computer right click select manage select drive management. This works on XP if you have other OS than search for disc management for your OS.
Aug 29, 2013 | Seagate Computers & Internet
A compaq mybook 6710B 843GB, My girlfriend has lost the key for our disk. Is ther any way to use de disk now that the security key is gone? PLEASE help! it contains many important files and photo's of our children/holiday's I hope you can help me.
You could try this software it sounds pretty good although I have not used it so I am unable to direct you on how but it reads as though it has a password reset tool as well as windows password cleaner and a blank the password utility on any user that has a valid account on windows system and many other tools you might find helpful http://majorgeeks.com/Dr._Freeware_System_Utilities_d6416.html Dr.Freeware System Utilities which includes data recovery software, data backup, password reset tools for Windows helps you to maintain your system. Dr.Freeware is freeware, you can download and use it for free.
Data Recovery/Data Backup: Supports Logical scan and Raw scan, Supports NTFS, FAT, UFS 1, UFS 2, EXT2FS, EXT3FS, and ISO 9660 file sytem, Supports IDE/SATA/USB Hard Drives.
Data Recovery - Recover your lost data
Available in Live CD to run offline
Recover accidentally deleted files in your hard drive
Recover data from RAW Drive(partition table or file system is damaged)
Support NTFS, FAT, UFS 1, UFS 2, EXT2FS, EXT3FS, and ISO 9660
Support IDE/SATA/USB Hard Drives, memory cards, "
USB Memory Drives"
Drive Dumper - Backup your hard drive
Available to run on Windows
Support Windows 2K / XP / 2003 / Vista / 7 (Windows Editition)
For data rescue, backup, migration, or computer forensics etc.
Transfer important important data from damaged Drive(partition table or file system is damaged, has lots of bad data blocks)
, "USB Memory Drives"
Windows Password Cleaner
This is a utility to blank the password of any user that has a valid (local) account on your Windows system.
You do not need to know the old password to blank the password.
Support Windows NT/2k/XP/Vista
hope this helps you and you get your photo
Aug 29, 2011 | Western Digital My Book Home 500GB...
How can we repair a USB which is crashed like a hard disk.
Dear i have send some information of solve your problem. I hope you have satisfied my suspicion if you can solve your problem you can read this information
Thanks.
Pen drive is the best way for people who are looking for larger space to store their important data and want a compact, easy-to-operate storage drive. These pen drives are mainly trendy among system and network administrators. They can load a large amount of information about configuration and software that can be used for the system maintenance, recovery and troubleshooting. But what if there is a problem with your pen drive having important documents have been crashed? Ddipr.com releases new USB repair software to ensure user to get back files and folders stored in USB pen drive.
Pen drive data recovery software securely restores lost digital images, office documents, database files, audio, video files etc from your damaged and logically crashed USB pen drive.
Ddipr provides advanced and professional USB repair application to recover missing or erased files and folders lost due to accidental deletion, virus attack, software malfunction or power failure etc from corrupted or formatted pen drive. Kingston pen drive files undelete utility easily restore data from various USB drive (flash drive, memory stick, jump drive, thumb drive, key drive) and many more USB drives. Thumb drive data restoration program provides reliable and secure method to recover all digital files format including midi, ppt, doc, pdf, mov, xls, jpg, gif, mp3, wav, exe, bmp etc. Software support pen drive in all capacities including 512MB, 1GB, 4GB, 8GB, 16GB, 32GB and even higher capacity drives. USB drive data backup utility support all leading brands like Kingmax, Samsung, Sony, Toshiba, Jet flash, Apacer, Lexar and many more. Software easily installs on all windows operating system such as Vista, 98, 2000, 2003, XP, ME, NT. The software development team of ddipr.com combines a variety of advance features in this particular software. Some of the important features are:
- Pen drive data salvage program recovers data even if Drive Not Formatted message is displayed on your computer.
- Software provides GUI interface which makes it easy to use and operate.
- Application supports all versions of windows like Vista, 98, 2000, 2003, XP, ME, NT.
- Software provides easy data recovery from logically crashed or inaccessible pen drive.
I am a company representative and fully satisfied with this application to restore deleted data from formatted or corrupted USB pe
Feb 16, 2010 | Kingston Technologies 512MB DataTraveler I...
Will additional RAM increase the speed of my computer. I have the original 512mb?
Increasing the RAM on your PC will considerablly increase of your system. The RAM is your computers work sheet. Whatever you see on the screen of your computer is first stored on the RAM. If the RAM is small, it gets fill easily with data. Older data on the work sheet not being currenty accessed is move to the temporary area on the hard disk. When this data is needed the older data move to the same temporary area for this data to be displayed. This impacts on the response time of the PC which you see as the system bring slow.
Inceased RAM will increase the work sheet area and reduce the rate data is move to the Temporary area of the Hard disk thereby improving the PC Speed.
More importly if you wand to improve the speed of your system, check the applications you are running against the system requirement of these application. Follow the recommended system configuration for all the application and you system speed will not be impared.
Jan 08, 2010 | HP Pavilion 725n PC Desktop
569 people viewed this tip
David Payne
David Payne
