Tip & How-To about Computers & Internet
Monitor buying tips you should know.
Over the years monitors have transformed from those bulky CRT monitors to square LCD screens to stylish flat wide screen LCD's and now to new stylish extremely thin LED screens. On average every PC user spends at least 5 hours a day looking at the monitor. If the picture is fuzzy and not clear enough then there is a very high possibility that the eyes get damaged.
An older CRT monitor
A wide LCD monitor
A newer ultra flat widescreen LED monitor
Monitor Sizes
There are many different sizes of CRT, square LCD, wide LCD and wide LED monitors available on the market at the moment.
If you want an older CRT screen then sizes can range between 14" to about 20", they use the 4:3 aspect ratio.
If you want an older LCD screen then sizes can range from 15" to 19", they also use the 4:3 aspect ratio.
If you want a newer wide screen LCD then sizes can range from 18.5" to about 27" and even larger. They use the 16:9 if they are full HD or 19:10 if they are not ratio.
If you want a newer wide screen LED then sizes can range from 18.5" to about 27" and even larger. They also use the 16:9 if they are full HD or 19:10 if they are not ratio.
Image quality
The sharpness of the image in a monitor greatly depends on your Graphics card as well as whatever resolution you are running at. Nevertheless the quality of the monitor plays an important role.
Here are some of the tips that you should know before buying a monitor.
1. There are three types of monitors namely CRT, LCD and LED. The monitor that looks like a TV is a CRT monitor. In CRT monitors there is a Cathode Ray Tube that shoots electrons into the screen to create the image. An LCD monitor is smaller in width and consumes less power and is healthier if you are going to be spending large amounts of time at your PC. The LED screen looks the same as an LED monitor and the difference between it and the LCD is that it has a much higher contrast ratio resulting in darker blacks and much lighter whites.
3. A CRT monitor is much heavier than LCD monitor as you can imagine by it's bulky appearance. A LCD monitor is very lightweight and so is a LED monitor.
4. The distance between two adjacent pixels in a monitor is called 'dot pitch'. This is measured in millimeters (mm). Smaller the dot pitch the clearer the picture quality. Usually there are monitors with dot pitch varying between 0.20 mm to 0.27mm. Some manufacturers use diagonal dot pitch while most of them use horizontal dotpitch. The diagonal dot pitch is always longer than the horizontal dot pitch
5. Resolution of a monitor has to be considered with care. Most of the CRT monitors have resolutions of 800×600, 1024×768 and 1280x1024. The square LCD monitors have 1280×1024 and 1600×1200 resolutions. Newer wide screen LCD monitors have resolutions of 1600x1900, 1680x1050 and the Full HD 1920x1090. When the resolution is higher the images and text will appear smaller. But you can see more text and bigger pictures in the monitor with high resolution.
6. Another thing to note is the 'Refresh rate'. This rate is usually 60Hz, 73Hz, 75Hz, 85Hz. Refresh rate of 85Hz means the picture on the monitor is refreshed 85 times within a second.
7. The brightness and contrast can range between a low 5 000:1 to a high 80 000:1 in a LCD monitor and an average of 5 000 000:1 in a LED, yes that's 5 million to 1 with a LED. This just shows how much better a LED monitor is to a LCD.
8. If you are a gamer then the thing you have to look at with LCD monitors and LED monitors is the response time. If it is 16ms then this is a very bad monitor for gaming and you will experience a ghosting effect in most games and if it is 5ms then you will have an average gaming experience. What you want to get is a 2ms response time monitor, with it you will have the best gaming experience with no ghosting what-so-ever.
Computers & Internet Logo
tvgoes on ok and shows which channel - then goes black What is the cause please - and can I fix it
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
Feb 22, 2015 | Home Styles 56" Wide Nova Teak Finish Hd...
Can I fix a flickering band on VP2250wb?
It sounds like one of the backlights are going, or one of the inverter transformer and there are two capacitors near the inverter transformers that do give trouble. The monitor would need to be dismantled to investigate the problem and it will involve money, since it is four years old I would be inclined leave it alone until a new one is required.
Apr 15, 2012 | ViewSonic VP2250wb LCD Monitor
no picture at all. speakers work though.
gstanz52, Oh, Oh, looks like someone needs a new wide screen lcd monitor!!! What is the "date of manufacture" from the rear label???? Maybe the "black screen of death" has finally caught up with your 6 to 8 year old lcd monitor. I would guess that the internal electronic ballast circuit (inverter) has failed and will not supply 500 to 1000 vac to light-up the cold-cathode-fluorescent-lamps" any more!!! Next thing to do is go HERE: http://www.lesliewong.us/blog/2005/05/02/hp-pavilion-f1703-flat-panel-display-blackout-solution/ Do some reading to determine if a possible DIY refurbishment of your unit is in your future. If you want to try refurbishing unit, then do some reading in the fixya profiles of "budmrtn" "buddymc" "12fixlouie" (me) for more information and or do comment to this post. Then you should watch some video clips at YOUTUBE of owners/ technicians disassembling and repairing typical CCFL back-lit lcd monitors.
My advice to you is: Get new higher resolution Wide Screen unit. Then and only then, attempt a refurb job on F50 to keep as a working antique spare monitor. 12fixlouie
Aug 28, 2010 | HP Pavilion F50 17" Flat Panel LCD Monitor
degauge monitor
If your using a CRT " older bulky monitor " your looking for a horseshoe magnet symbol, If your using an LCD or flat screen you do not degauss the screen, CRTs are driven by electromagnets steering a beam onto the front. The newer screens do not use an electromagnetic device and they do not have a use for degauss. You used the word degauge did you mean degauss? If your screen is a flat panel LCD/plasma and has color warping you may need to seek servicing.
Apr 26, 2010 | ASUS 22" LS221H Wide LCD Monitor
337 people viewed this tip
David Payne
David Payne
