Tip & How-To about Washing Machines
CONTROL LOCKED on Whirlpool/Kenmore Washers/Dryers
The Whirlpool duet washer needs a reset to resolve the control lock problem. To reset the washer you have to Press and hold the END OF CYCLE/CYCLE SIGNAL button for 20 seconds. This button is usually located on the right side of the panel facing the front of the washer.
Similarly, if it is a Kenmore Washer you can press and hold the DRAIN/SPIN button for 20 seconds.
To reset the Kenmore Dryer for this Control Lock problem you have to Press and Hold the AUTO DRY LEVEL button for 20 seconds to unlock the Controls.
Kevin
Washing Machines Logo
My washer won't get off control lock
Hello & Welcome to FixYa
This is a common issue with Whirlpool Duet washer however; your whirlpool duet washer needs a reset to resolve the control lock problem. Press and hold the END OF CYCLE/CYCLE SIGNAL button for 15 seconds to reset the control. Please get back to me if you have any other questions.
Kevin
Aug 26, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Control locked lidht is on , on washer.
This is a common issue with Whirlpool Duet washer however; your whirlpool duet washer needs a reset to resolve the control lock problem. Press and hold the END OF CYCLE /CYCLE SIGNAL button for 15 seconds to reset the control. Please get back to me if you have any other questions.
Kevin
Aug 06, 2011 | Whirlpool Duet GHW9150P Front Load Washer
the control panel is locked.
This is a common issue with Whirlpool Duet washer however, your whirlpool duet washer needs a reset to resolve the control lock problem. Press and hold the END OF CYCLE /CYCLE SIGNAL button for 15 seconds to reset the control. Please get back to me if you have any other questions.
Kevin
Jun 26, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Duet ht washer control locked. How do I unlock it? Really need your help
This is a common issue with Whirlpool Duet washers however, your whirlpool duet washer can be reset to resolve the control lock problem. Press and hold the END OF CYCLE/CYCLE SIGNAL button for 15 seconds to reset the control. Please get back to me if you have any other questions.
Kevin
Apr 25, 2011 | Whirlpool Duet GHW9150P Front Load Washer
How to release Whirlpool Duet button control lock button
Kevin
Mar 20, 2011 | Whirlpool Washing Machines
539 people viewed this tip
Top Washing Machines Experts
