Tip & How-To about LG GD510 Cell Phone
HOW TO CHANGE FONTS IN LG GD510 (LG POP) CELL PHONE.
What you need:
1) The CUST file
2) One or two true type fonts (.ttf)
3) Winmage installed (DOWNLOAD HERE)
1. First, open up your CUST file using Winimage.
2. In the DMF folder (or the MEDIA folder) there is a sub folder called fonts. In this are two true type fonts.
3. Make sure the fonts you are adding are on the desktop. Then rename them both like the ones in the CUST file. To do this quickly, simply right click on one of the fonts, and then click on properties. You can then just copy the titles.
4. If you only have one font, just make a double of it, and rename it like one of the original fonts. Notice how they are different in names. Make sure your two fonts are as well.
5. Highlight both of the original fonts and hit delete. Then click on the small icon with an arrow going upwards out of sheets of paper. This lets you insert files. Find your two custom, properly named files and insert them.
6. Once you have done all this, you can then save the CUST file and upload it to your LG pop. Then you should have a new font
Not all fonts will work, but the majority of them do. Notice how similar the way your pop reads the files to a computer
LG GD510 Cell Phone Logo
download shivaji fonts
Go on Google, type in the font name you want and download and install the .ttf (True-Type Font) file. Then you should be able to use the newly installed font in any application installed on your computer.
Apr 30, 2014 | Computers & Internet
HOW TO CHANGE FONTS OF N73
SECMAN not installing on N 73 .It showing Unknown file format.Be more precise please.
Apr 14, 2010 | Nokia N73 Cellular Phone
hoe to download madura font (free)
1. Download the font below... Madura Font
(when u open it it will be just a english font, dont worry about that)
2. Go to your downloads where u save the madura.ttf file, COPY it (select, Ctrl +C)
3. IMPORTANT STEPS
--Go to My Computer,
--then C drive (double click, where your operating system is),
--Double click on Windows folder (NOT Program files),
--scan through the folders and open Fonts folder, it should preview all the fonts installed on your computer.
4. Now Paste (Ctrl+V) the madura.ttf file that u copied in STEP 2. (it should say installing font when u paste it)
5. Open Madura Dictionary and it shuold work fine now.
I have tried this in Windows 8 computer so it should defineatly work fine with windows 7 and XP.
Madura Font
http://www.maduraonline.com/download/madura.ttf
Madura Software (you probably already have this installed because u only wanted the font, for other people who wants to uninstall and start from the beginning)
http://download.cnet.com/Madura-English-Sinhala-Dictionary/3000-2279_4-10571464.html
Peumal Pushpakumara
Monash University
Aug 19, 2011 | maduraonline.com Madura English-Sinhala...
how to insert the rupee symbal in excel
Let me add with a brief details on how to download, how to install and how to type Indian Rupee Symbol:
Click here to download INR Rupee font, download this, extract the font file (once you open the zip file, you'll see a file name "Rupee"), copy it and paste it in the Fonts folder of the Control Panel of your computer.
Open a word processing program like Ms-word (in your case, Excel) and select the font as "Rupee" from the drop down lists, now press
on the keyboard.
You'll see the Rupee symbol :
Good luck.
Thanks for using FixYa.
Jul 21, 2010 | Microsoft Excel for PC
Increase font size on Nokia E65 Mobile Phone
NOKIA SAYS THAT THE FONTS ARE NOT CHANGAABLE THEY ARE WRONG!
There is quite a simple way to change system fonts in the Nokia E65 phone.
The following is how I did it in my E65.
First you have to select the memory as phone NOT the memory card.
Then connect the phone to PC through the standard USB cable. When the phone prompts you, select “Data Transfer” NOT PC Suite”. Once the phone is connected you can view it as a removable drive. First check if a directory named “Fonts” exists.
If it does not exist, just create it in the resources folder. If it already exists, just make a backup copy of it.
Now, go to your PC Fonts directory (usually c:\Windows\Fonts) and do the following:
You can use any TT font I used a font called Baveuse.TTF as the bold I used the Baveuse3D.TTF as my normal font. You have to have (3) three fonts and they have to be renamed to what is below or it won’t work.
Copy Any (True Type you want) font file to:\resources\Fonts\NSSB60.ttf
Copy Any Bold (True Type) font file to:\resources\Fonts\NOSNR60.ttf
Copy again the same normal Bold (TT) font file to:\resources\Fonts\NSTSB60.ttf
The (3) Three fonts have to be renamed as above or they wont work!!!
Then just disconnect the phone from USB turn it off. Then restart your phone and put the memory back to the card and you will have the new fonts in place. This is how I did my E65 and it worked ok for me. If the fonts are to big just start over delete the three fonts and use a different font to you find one you like I like the Baveuse.TTF font its personal choice.
Oct 18, 2007 | Cell Phones
2,806 people viewed this tip
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
