Tip & How-To about Televison & Video
LCD or plasma TV or monitor won't turn on or stay on or is black
This is a rampant issue, and it spans so many makes and models of flat panels right now, that I am going to post this as a tip so that people can find it more easily.
A while back, an electrolytic capacitor manufacturer that sells their product to a plethora of manufacturer got the electrolyte formula a little off.
Apparently they got the ratio wrong for a stabilizing agent, and these caps fail usually just after the warranty has expired on the product.
Some repair shops want up to $800 to replace the boards in larger plasma units. Well, that's a bit nuts because they can be repaired for about $25.
How you say? well, here's the deal...
There's a good chance you have failing electrolytic capacitors either in the power section or the inverter section or both.
Any caps in these sections that look bulged at the top, or bulged/leaking at the bottom need to be replaced.
If you repeatedly turn it on, eventually it'll probably stay on, but every time you turn it off, the TV will get harder and harder to start up until one day it just won't.
Some units will just click, others give the "7 blinks" of death.
Sometimes you have to do the opposite to start it up and unplug it for 5 mins, then try.
If you aren't tech savvy, find someone who is to help you replace these caps.
If you are handy with a soldering iron and can identify the power supply and inverter / FM section for the back lights, an inexpensive handful of capacitors will likely fix you right up.
Match the capacitance on the capacitors. Go over voltage if you can, and still have them fit.
IE - it's not a bad idea to replace a 10V cap with a 16V or 25V or even a 50V(if they physically fit the board), but don't replace a 680uF cap with a 500uF or a 1000uF (unless you are positive it's only doing ripple filtering).
Most of the caps that go are 10V at 470uF, 1000uF or 3300uF and are usually rated for 105 degrees, but the temperature rating isn't as important.
I found some great videos of the procedure (for different models with same issue) on youtube so you can see how simple a FixYa this is.
http://www.youtube.com/watch?v=Mm51C_RDIZE
http://www.youtube.com/watch?v=BNHHrgX_6cs&feature=related
http://www.youtube.com/watch?v=8l0AUj8QUkg&NR=1&feature=fvwp
http://www.youtube.com/watch?v=Y7b_nTaZYcU&feature=related
http://www.youtube.com/watch?v=e9gltBI2yCw&feature=related
http://www.youtube.com/watch?v=Y7KQAWV3Vog&feature=related
and I found a new video that I like
http://www.youtube.com/watch?v=6XoF6QZ1dmw&feature=related
As you can see, this issue spans plasma TVs, as well as large and small LCD TVs and monitors.
The parts are cheap, and skills and tools required are minimal.
if you use a resin core solder, then solder flux is not really necessary.
Televison & Video Logo
My TV model number is se222fs flat screen
TV model number is se222fs Michael, RE POST make model # and *your complete question,* so we at Fixya can answer your question effectively.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Mar 25, 2016 | Televison & Video
is this tv converter ready
have no idea as we do not see a make,model
Mar 05, 2016 | Televison & Video
why wont my sa-ht720 turn on... i have everything plugged up but when i hit the power it just makes a clicking sound
Check first for shorted speaker leads or blown (shorted) speakers.
Chances are, that's not the issue though.
There's a good chance you have failing electrolytic capacitors in the power section.
If you repeatedly turn it off and on, eventually it'll probably stay on, but every time you turn it off, the unit will get harder and harder to start up until one day it just won't.
Sometimes you have to do the opposite to start it up and unplug it for some time and then try again.
If you aren't tech savvy, don't worry, read the rest of this solution and watch the videos.
If you are handy with a soldering iron and can identify the power supply section an inexpensive handful of capacitors will likely fix you right up.
IE - it's not a bad idea to replace a 10V cap with a 16V or 25V or even a 50V, but don't replace a 680uF cap with a 500uF or a 1000uF (unless you are positive it's only doing ripple filtering, and even then, you should go OVER, not under the uF rating).
Most of the caps that go are 10V 1000uF or 3300uF.
I found some great videos of the procedure (for many Samsung flat panels, but the principal is the same) on youtube.
As you can see, this issue spans plasma TVs, as well as large and small LCD TVs and monitors, amplifiers, and many other electronic products using these components - and it's becoming more and more a rampant issue!
The parts are cheap, and skill required is minimal.
I order mine from www.digikey.com as they are less than a buck a piece plus shipping, and they usually arrive the next business day.
Jul 15, 2011 | Panasonic SC-HT720 System
dlp tv
No, don't wait. Make sure you get RCA to cover this under warranty. Don't wait for everyone with this model to have the same problem and jam up RCA with the customer service nightmare that is rampant in this industry.
Dec 07, 2007 | RCA Scenium HDLP61W151 61 in. HD-Ready...
12,191 people viewed this tip
Top Televison & Video Experts
Electro Med Services...
