Tip & How-To about Video Game Consoles & Games
Joystick fix in Battlefield Bad Company 2 for PC (and Vietnam)
In Bad Company 2 if you wish to use a joystick the yaw will be reversed. You want to yaw left and it goes right, go right it instead goes left. This will tell you how to fix that.
Locate you settings in your My Documents\BFBC2\input folder
There is a file called air.dbx. This is an XML file. Open it with wordpad so you can read it formatted.
Search for ConceptYaw by pressing ctrl+f.
Scroll down til you find GameSharedResources.PadInputActionData
Below this line there is <field name="ScaleValue">1</field>
Change the 1 to a -1
Save the file and load the game.
Now your yaw will work correctly.
Video Game Consoles & Games Logo
Where is the yaw sensor located on a 2008 Pontiac Torrent?
yaw-xozrttqlr3qpoa0t2tmccx0o-1-0.png 1 - Floor Panel
2 - Console
3 - Yaw Rate and Lateral Acceleration Sensor
4 - Seat Belt Pretensioner - Right
5 - Inflatable Restraint Side Impact Sensor (SIS) - Right (ASF)
6 - Rollover Sensor (ASF)
7 - Inflatable Restraint Sensing and Diagnostic Module (SDM)
8 - Seat Belt Pretensioner - Left
9 - Inflatable Restraint Side Impact Sensor (SIS) - Left (ASF)
Apr 16, 2017 | Pontiac Cars & Trucks
chair goes in opposite direction to joy stick control left and right only
batrans your motor connections are reversed. remove the seat and shroud over the batteries find the motor connectors that come from the joystick cable and switch them. This should fix your problem Hope you geterdone
Sep 13, 2010 | Jet 3 Ultra Power Chair
How do i get rid of replace lamp message & reset lamp timer
If you are using the RM-PJ2 remote control, following these instructions. You will have 5 seconds to complete the key sequence.
1. Make sure the Projector is in "Standby" mode. There will be a red light instead of green
2. Press the Reset button
3. On the "joystick" type button, toggle the left directional arrow
4. On the "joystick" type button, toggle the right directional arrow
5. Press down on the "joystick" button to press Enter.
6. Your lamp hours should now be reset.
Recap: Reset, left arrow, right arrow, Enter, all within 5 seconds.
Mar 26, 2008 | Sony VPL-EX1 Multimedia Projector
4,717 people viewed this tip
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
