Tip & How-To about Samsung SCH-U450 Cell Phone
How to lock a Samsung Intensity cell phone
Unlike flip phones, cell phones like the Samsung Intensity are subject to accidental keypad-pressing and dialing when they are in your pocket, purse, or even a holster. To avoid unintentionally using up voice or data minutes, you can lock your phone and temporarily disable the keypad.
There are two ways to lock a Samsung Intensity - the standard keypad lock and the security lock.
- To use the standard lock:
You can lock your phone at any time from the main screen by holding down the "0" key for about two seconds. The keypad will immediately lock, and you won't be able to use any functions or make any calls (except for calling the local emergency number). To unlock the phone, press the right option button (in the upper right corner of the keypad, next to the End button) followed by the Menu or OK button.
You can also set up Auto Key Lock, which will automatically lock your keypad after the backlight turns off. The Auto Key Lock setting can be found in the menu under Settings & Tools > Phone Settings > Auto Key Lock.
- To use the security lock:
The security lock also prevents your keypad from being used, but it requires a code to be entered in order to unlock the phone. To enable the security lock, go into the main menu and select Settings & Tools > Phone Settings > Security > Lock Phone Now. (You'll need to know your phone's security code in order to access this setting -- by default it is typically the last four digits of your phone number.)
To unlock the phone, press the right option button and then enter your phone's security code, followed by the OK button.
You can set your phone to go into security lock mode as soon as you turn it on by enabling Phone Lock Setting under the Security menu. Every time you turn your phone on, you'll need to enter the security code in order to unlock it. However, once you unlock it, it will remain unlocked until you either manually lock it or turn it off and then back on.
Samsung SCH-U450 Cell Phone Logo
how do i keep samsung smooth from pocket dialing?
Pocket dialing is usually less of an issue with flip phones, but if you are having issues with your SCH-U350 pocket dialing, you can lock the keypad by holding down the zero (0) key for a second or two. A message should come up telling you that the phone has been locked.
Jun 03, 2010 | Samsung Smooth SCH-u350 Cell Phone
I own a Samsung Intensity Cell Phone. How do I
Go to menu options. Then Settings and Tools and then keypad volume. Hit down arrow key until it turns off.
Nov 13, 2009 | Cell Phones
is there a waay to lock the keys while it is in my purse?
this should help you out.
Basicall press MENU > *
Lock the keypad
To lock the keypad to prevent keys from being
pressed accidentally, in the standby mode,
select Menu, and press * quickly; to unlock,
select Unlock, and press * quickly.
When the keypad lock is on, calls may be
possible to the official emergency number programmed into
your device.
Enter the emergency number, and press the call key. The
emergency number you have entered may not be displayed on
the screen.
Apr 19, 2009 | Nokia 1600 Cellular Phone
3,560 people viewed this tip
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
