Tip & How-To about Computers & Internet
How to choose a High-Definition Multimedia Interface HDMI Cable
The HDMI cable is the best part of the user interface for digital data transmission and is highly recommended to use part of a high-definition (HD). Today, most HDTVs can assign this connector to the first versions of HD. This is a technique for direct high-resolution and good sound quality. Important measures are the following:
HDMI cable version
There are different versions of the cable specification, version 1.0 to 1.2, version 1.3 to version 1.4. Greater the higher bandwidth and increased capacity to transmit data over cable. 1.0 to 1.2 is recommended for earlier versions of HDTVs. Version 1.3 is recommended to ensure good quality and high resolution, color and sound. Version 1.4 supports 3D technology and 3D cinemas is recommended and HDTV home movies, 3D animations or effects.
HDMI cable connector type
Connector types vary in different sizes. Mini-and micro-container port with support for HDMI version 1.3 and 1.4, respectively.
HDMI cable length
The cable has no maximum length, since it depends on the quality of building materials and conductor, but generally ranges from 10 to 15 meters. However, in real time use, do not consume the 15 meters long. Therefore, it is better to know the recommended and can be 50 cm to the edge.
HDMI cable thickness
HDMI cable has two categories: Category 1 and 2 have already been tested and classified as standard cable and high speed respectively. However, you should emphasize the thickness of the cable. Too thin wires are not recommended because it can affect signal quality and the screen is too small can lead to problems and even the power of high-definition output.
HDMI cable brands
There are many brands on the market such as Akihabara, Sony, Toshiba and others as we all know the quality expensive, but high. Marks Considered one of the factors in the choice of cable.
There are many things that should draw attention to the selection of cable and what are the above, it is suggested that consideration should be given first. The following suggestions might be one reason for success in choosing the correct cable.
Computers & Internet Logo
Dx-L321-10A: M-B315AA on direct tv. Can't get HD. Says restricted. Tried comp. No good, haven't used HDMI. Do I need Digital? Thanks for your time.
These are directly from your users manual:
  • Built-in HDTV tuner: Add HD-capable antenna to receive over-the-air high-definition broadcasts, where available. Optional set-top box required for high-definition cable or satellite programming
  • 2 HDMI inputs: Provide an uncompressed all-digital audio/video link for the highest quality connection and support copy-protected HD broadcast content.
  • you need to do one of 2 things to get HDTV on your device. Either attach an HD- capable antenna or attach an HDMI cable from your satellite tv providers box. Good luck.
Aug 03, 2015 | Televison & Video
I NEED SONY BRAVIA T32 FULL MANUAL...how to conect to computer and camera
Hello there,
Here is the link to the full manual:
http://support.sony-asia.com.edgesuite.net/consumer/IM/4110401121.pdf
Before connecting your devices...
The signals that enter the TV and connected devices will need to be output in the correct format using the suitable connections. Below are the different types of video connectors. When connecting the TV, use the inputs that are available on your devices that provide the best video performance.
Video performance level Name Aspect Signal transmitted Separate audio connection required arrw.jpg HDMI cnn_hdmi.jpg Picture + Sound No DVI*1 cnn_dvi.jpg Picture Yes
L-AUDIO-R Component video cnn_component.jpg Picture S-Video cnn_s_video.jpg Picture Composite video cnn_composite.jpg Picture RF/Coaxial cnn_coaxial.jpg Picture + Sound No
*1 If the equipment has a DVI jack and not an HDMI jack, connect the DVI jack to the HDMI IN (with HDMI-to-DVI cable and/or adapter jack), and connect the audio jack to the AUDIO IN (L/R) jacks of HDMI IN. (The DVI connector is for video signals only) To enjoy the best visual experience with your system, it is preferable to connect your best devices with the highest quality connections available. For example: your Blu-Ray Disc player or HD Set Top Box with HDMI, followed by your DVD player with Component, then your Video Cassette Recorder with S-video etc.Note: The quality of the picture also strongly depends on the quality of the cable used.
HDMI The High-Definition Multimedia Interface (HDMI) is an all-digital audio/video interface capable of transmitting high definition video and audio signals. HDMI provides an interface between any compatible digital audio/video source, such as a set-top box, a DVD player, a PC, a video game system, or an AV receiver and a compatible digital audio and/or video monitor, such as a digital television (DTV). DVI The Digital Visual Interface is capable of transmitting high definition video, but does not transmit sound. You will need to use the audio connectors of your device (usually Optical/Coaxial digital, or RCA). It is possible to connect an HDMI device to a DVI device using a HDMI to DVI adapter. Component video Component video is an analogue connection. It is capable of transmitting high definition signals. Component does not transmit sound. You will need to use the audio connectors of your device (usually Optical/Coaxial digital, or RCA) S-Video Separate video, abbreviated S-Video and also known as Y/C is an analogue video signal that carries the video data as two separate signals (brightness and colour), unlike composite video which carries the entire set of signals in one signal line. S-Video, as most commonly implemented, carries standard definition video. It does not carry audio on the same cable. Composite video Composite video is an analogue video (no sound) format. This is the connector you should use if you do not have any other connector available, in terms of quality. RF/Coaxial RF Coaxial Cable connection is used for transferring television signals (audio and video) originating from an antenna or cable box to a Television.
Hope this was helpful to you.
Goodluck
Elect_Comp
Aug 10, 2011 | Televison & Video
what is HDMI
Its a vidio/audio input which looks like this. If you have an hdmi port on a laptop you can connect it to a TV and have the audio and video transfer to the TV.
Mar 16, 2011 | Computers & Internet
Sky new zealand say my hd z70rx5 is unable to recieve hdcp even though the specs say the set is HDMI AND HDCP complient,they say no rear projection is able to receive hd is this true,any help i would be very gratefull
Terminals and Connections Dual HDMI digital inputs with HDCP (High Definition Content Protection) offer an uncompressed solution to the transmission and display of high definition video and audio content. All JVC HD-ILA TVs also include dual auto sensing component video inputs, assuring the best possible picture quality whether a viewer is using DTV, D-VHS or DVD, and three S-Video (two rear, one front) inputs and four AV inputs (three rear, one front).
hdmi.gif High Definition Multimedia Interface
HDMI is a new standard digital connection between A/V devices, such as a set-top box, DVD player or A/V receiver, and a digital television. HDMI offers exceptional video and audio quality with a single quick-disconnect connector. It supports multi-channel digital audio transmissions and component video color spacing for true rendering of HD video.
We carry a full line of high-performance HDMI cables. See them here...
Audio Features The JVC BBE High Definition audio system with Advanced HyperSurround and Active Hyper Bass includes two direct-drive speakers mounted underneath the screen for rich, expansive sound that fills your home theater or TV room.
Aug 06, 2008 | JVC Televison & Video
241 people viewed this tip
David Payne
David Payne
