Tip & How-To about Cell Phones
HOW TO FREE MORE RAM ON YOUR S60 MOBILE
How to free more RAM on your phone>
Method 1: Flight mode:
Put your phone in "Flight mode" with Psiloc System Tools. Install System Tools, open it and select "Flight mode". This way you can restart the phone without your SIM card so there will be no running phone tasks in the background. Now you can have up to 3,5 MB of free RAM!
Note: ironically enough, Flight mode doesn't work when Smart Launcher is installed, at least in my case.
But i've also heard several reports of people who have both apps running without any problems.
Method 2: Smart Launcher trick:
Install Smart Launcher and open it. Go to Options, Settings and put Launcher ON.
Now plug in your charger and switch off your phone. Wait untill the battery meter appears and short press the Menu button (don't hold).
The menu should appear and now you can have 3,5 to 4,5 MB free RAM! (Hold Menu button to check RAM).
The trick is that with the charger plugged in, the phone must get a minimum software support for charging, even when
the phone is switched off. And somehow Smart Launcher has still got it's shortcut running and that's the Menu button. So when
you press the Menu button, you go directly to the Menu without any other phone tasks running in the background so
you trick the phone and you have more free RAM!
Note: when you unplug the charger, the phone will switch off.
Method 3:
It frees a little about 100~200 KB but I guess it's useful sometime. Close your menu not by selecting the right selection key "exit", or pressing the menu key another time, they only hide the menu app but do not close it, to close it select the left selection key "option" and scroll down and select "exit"
So when you open an app needs more ram reopen menu and close it, it's useful when play low bit rate video in realplayer paradis.
Cell Phones Logo
I have a samsung s3 gt-i9300 i cant make or get
Your Samsung Galaxy S3 must be restricted to some specific network. That is why it allows only emergency calls when a SIM card from some other network is inserted in. You need to unlock your Samsung Galaxy S3 to make it work with all SIM cards. You can unlock your Samsung Galaxy S3 safer and easier using unlock code. You can get the accurate unlock code for a Samsung Galaxy S3 from Unlock-Zone.com at affordable cost. Good luck.
..............UNLOCKING INSTRUCTIONS..............
Method 1:
1 - Switch ON your Samsung Galaxy S3 with a NOT ACCEPTED SIM Card.
2 - Samsung Galaxy S3 will ask for "Password".
3 - Enter the Unlock Code.
OR (if the Samsung Galaxy S3 shows "Insert Correct SIM Card")
Method 2:
2 - Don't bother about what's being displayed on your Samsung Galaxy S3.
3 - Compose : #0111*CODE#.
SOURCE: MobileUnlockGuide.com
Oct 02, 2014 | Cell Phones
when i on my phone it shows the message called activate your sim in flight mode then i press any key it dont work........
When you switch on the mobile you get Activate your sim in flight mode because the flight query in settings is out to ON.
When it asks please press NO or YES it goes into the mobile phone.
To OFF the flight query please follow the below step
Menu > Settings > Phone > Flight query > OFF
Thank You
Aug 18, 2010 | Nokia 3110 Cellular Phone
Samsung flight phone issues will not let me make or receive calls. Say emergency calls only.
using flight mode you cannot make calls
you have to switch it to normal mode
1. Flight mode [Support > Glossary]
In this mode (also known as offline mode ) you are able to use functions on the mobile phone (calendar, calculator etc.) even though the phone is not connected to a mobile network. You cannot make calls in flight mode .
Mar 30, 2010 | Cell Phones
275 people viewed this tip
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
