Tip & How-To about Sharp ELW516 Scientific Calculator
Sharp ELW516: Changing the default display to decimal
Getting Decimal Answers by Disabling WriteView on the Sharp EL-W516 Calculator
The Sharp EL-W516's WriteView display uses multiple lines to display mathematics as it is seen on a page. Fractions are shown as fractions, exponents as exponents, integrals as integrals, and so on. This makes entering calculations easier, and reduces the chance of errors.
At the same time, calculation results are displayed as fractions (or with roots or pi) whenever possible. Pressing the CHANGE button repeatedly will change these to decimal answers.
If you prefer to always get decimal results you need to disable the WriteView display mode. Doing this will make the calculator display like the Sharp EL-546W when in NORMAL mode. Answers will be given as decimals, but fractions will no longer look like fractions. In general, you will still need to follow the EL-W516 instructions.
Disabling WriteView
Press 2ndF and MATH to enter SET UP. Now press 2 for EDITOR.
There are now two options: 0: W-VIEW, and 1: LINE
Press 1 for Linear display mode to disable the WriteView display, and to get decimals as your answers.
To return to the WriteView display, go through the steps above but press 0 for W-VIEW.
NOTE: It is not possible to have decimals as the default answer form when in WriteView mode.
Sharp ELW516 Scientific Calculator Logo
sharp el w531 wont give answers in decimal
Press the CHANGE key to cycle through the different views.
If you don't want results showing up as fractions, switch out of the WriteView mode into the Line mode. Press SETUP, select "EDITOR" then "LINE."
If you need a manual, you may download a copy at http://www.sharpmea.com/cps/rde/xbcr/documents/documents/om/30_cal/elw531-g-h-ha-w535_om_gb.pdf
May 06, 2014 | Sharp Office Equipment & Supplies
EL 531X Sharp - Help with calculations
You need a SHARP with Write-View display capabilities. The EL-531X is unable to show that. The Write-View calculators from Shard have a W, example EL-W516 followed by Write-View. Not to be confused with the W in EL-520W
Feb 21, 2013 | Sharp el-531x scientific calculator
We purchased EL-W535X sharp calculator. Want answers in decimal point as opposed to fractions. How do we change this? My son threw out the instruction manual.
on the key pad row above 7-8-9-(-) all the way to the left there is a key that says change with two arrows moving in a cicle press after each answer will change from even fraction to uneven fraction then decimal
Sep 08, 2011 | Sharp Office Equipment & Supplies
My calculator will show fractions instead of decimals when doing division. How do I change that? There is a N1 displayed in the lower left corner also...I think that may be the problem
Getting Decimal Answers by Disabling WriteViewelw516.gif on the Sharp EL-W516 Calculator
Disabling WriteView
Feb 07, 2011 | Sharp ELW516 Scientific Calculator
How do you change modes so that your answers will be in decimal from not fraction
[2nd F] [Set up] 2 1 will solve the fraction problem. Must be in line mode not write mode to view decimals.
Jan 22, 2010 | Sharp EL-531VB Calculator
8,624 people viewed this tip
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
