Tip & How-To about Computers & Internet
Reset Windows 7 Password
Anyone can forget a password. Okay you may think it will never happen to you, but think again, because it may just happen. Forgetting your user account password is no big deal providing you have taken the necessary precautions to create a Password Reset Disk.
Sadly, if you haven't created a Password Reset Disk for your Windows operating system then gaining access to your PC will become a nightmare. I'm not saying that it is impossible, because it isn't. However, this tutorial refers to resetting your user account password with the aid of your Windows Password Reset Disk.
The first you will know about your password being wrong is when you type the password in at boot up and a message appears telling you that The User Name or Password is Incorrect. It is at this stage that you need your Password Reset Disk.
Once you have your Password Reset Disk (you should have created this either on a floppy disk or a USB flash drive. See: Create a Windows 7 Password Reset Disk) you should insert the disk (or USB stick) into the relevant drive and then proceed as follows:
  1. After you have typed in the wrong password a message will appear informing you that the User name or Password is incorrect, you should forgot Windows 7 Password. At this point, Click the OK button to take you back to the log on screen
  2. User Name Or Password is incorrect error screen
  3. After you have returned to the Windows Log On screen look just below the Password dialogue box and you will see a Reset Password option, Click on this to start the Reset process.
  4. Windows Log On screen showing the Reset Password option
  5. After clicking on the Reset Password option the Password Reset Wizard will open
  6. Password Reset Wizard
  7. Click the Next button in the Password Reset Wizard screen
  8. The next screen (see fig 4) requires you to Insert the password reset disk
  9. If you haven't already done so, Insert the floppy disk or USB Thumb drive that holds the password reset file and then Select the drive from the password key disk is in the following drive dialogue box.
  10. Now press the Next button
    Insert the Password Reset Disk and then choose the drive from the drop down list
  11. You are now presented with the Reset the User Account Password screen
  12. The User Account Password Screen
  13. Type in the new password you wish to use and then type it in again to confirm your selection. Next type in a password hint and then click the Next button.
  14. The next screen to appear will be the Completing the password wizard screen. This should tell you that you have successfully reset your password.
  15. You have successfully reset your password
  16. Finally click the Finish button.
  17. You should now be taken back to the Log on screen where you can type in your new password and gain access to your system.
Tips: Not a Windows 7 user? Still Using XP or Vista? Don't know how to reset password on other Windows Versions? See these articles below.
How to Reset Windows XP Password?
How to Reset Vista Password?
Computers & Internet Logo
forgot administrators password, have no reset disc, windows 7. need pathway in command promt
This article describes how to reset windows 7 password without disk when forget login password and locked out of your laptop or computer.
If you are still bothered about forgetting windows 7 password and have no reset disk, the methods described in this article will help reset the lost password with or without disk. You just need a few minutes to read these methods in this article, and pick the right one to take it to carry out.
Method 1 and Method 2 describe how to reset a user account password under the condition that you can login your comptuter with another administrator account.
Method 3 shows how to reset a lost password with windows 7 password reset disk which you have created before forgetting login password.
Method 4 tell you how to reset or recover windows 7 login password with a password recovery software.
Sep 11, 2013 | Computers & Internet
samsung password reset
If you are using Windows OS; go to control panel select user accounts. Choose your account and click change password. Make sure you put a hint in for lost password, write it down or something. Forgetting it can be a headache. Hopefully you have an administrator's account and your account. If you forget the administrator account can still get in. Good Luck.
Apr 27, 2013 | Samsung R519-53S Notebook
253 people viewed this tip
David Payne
David Payne
