Tip & How-To about Computers & Internet
Fix internet connection windows 7
If your having a problem with Internet explorer dorpping your connection,here is a fix.
First left click start,then left click Control Panel.
Now under the headding (Network and Internet) look for View network status and tasks,left click (View network status and tasks) a new window will open called (View your basic network information and set up connections)
Left click (Local Area Connection) a new window will open,look to the bottom left you will see (Properties) left click that.
A window will open called (Networking) in the center of the window you will see (This connection uses the following items) in that window look for (Internet Protocol Version 6 (TCP/IPv6)
Remove the check mark from he box on the left and click ok,now click close,in the (Local Area Connection Status) window click Close.Now just click the X in the window Network and Sharing Center.Thats it your Internet connection should run much better and not drop your connection.
Hope this helps good luck and enjoy your internet connection once again....
Computers & Internet Logo
ERROR PROXY INTERNET EXPLORER
Google Chrome's connection settings and security settings are controlled by Internet Explorer's settings.
It appears by your error statement, that the Proxy Server settings in Internet Options has been changed to by pass the standard default of No Proxy Server. Sometimes Email Anti Spam Software can change this.
This should fix you up regarding the Proxy issue:
1. Click on Start and click on Control Panel.
Depending on your control panel view of Categories or Classic View:
1. Look for Network and Internet Connections category then Internet Options.
3. If in Classic View, double left click on Internet Options.
4. When Internet Properties opens, click on the Connections Tab and then the button LAN Settings near the bottom.
If the option to Use A Proxy Server... is checked then un-check it and click OK. Click OK again and re-open Google Chrome and see how it responds.
Let us know if you have further issues by using the "add a comment" link.
Thank you.
Apr 20, 2011 | Google Chrome
Recently I upgraded Microsoft Internet Explorer 8 to Microsoft Internet Explorer 9 and I am having problem with my Real Player, not able to download any program. So I wanted to uninstall Microsoft Internet Explorer 9 so that I can install back Microsoft Internet Explorer 8, but I can't do it. It looks like I am stuck with Microsoft Internet Explorer 9. Please help
Windows Internet Explorer 9 has been installed as a system update in the operating system, and as such can be removed from the Uninstall an update control panel menu.
To get there click the start orb in the lower left corner of the screen, and then Control Panel in the right menu.
Locate Uninstall a program in the Control Panel and click on the entry.To uninstall Internet Explorer 9 click the View Installed Updates link in the upper left corner of the screen. This opens a listing of Microsoft updates that have been installed on the computer system.
Right-click on Windows Internet Explorer 9 and select uninstall from the context menu.
To complete the uninstallation, the computer needs to be restarted in the end.
After restart ur pc Run reginout cleaner to clean it's registry files
Dec 08, 2010 | Microsoft Internet Explorer 8
i can not get internet explorer to work, when i open it, it fires up but says "invalid request, page does not exist" i use firefox mostly, but some of my programs accsess the web via internet explorer. i have tried uninstalling it and reinstalling it, and am current with I.E. 8. i also have scanned my p.c. several times with my virus protection, but it says everything is fine.
1. Go on start menu and find "control panel" 2. Once you've clicked on "control panel" click on "network and internet" 3. Click on "Internet options" 4. Click on the "connections" heading 5. Click "set up" and connect it up to your internet. Make sure internet explorer is also set as your default browser. How to set it as default browser - Open internet explorer (with connection or without)click on Tools> Internet Options. Click on the Program tab, then click on the Make Default button. If that doesn't work - 1. Go on start menu and find "control panel" 2. Once you've clicked on "control panel" click on "network and internet" 3. Click on "internet options then the "programs" heading 4. Click on "make default"
If this doesn't work then contact your internet provider.
Hope 1 of my two solutions helped :)
Dr Reed
Feb 27, 2010 | Microsoft Internet Explorer 8
internet explorer will not start. I have windows xp home edition and when the problem first stated I had IE 7 I have since upgraded to IE 8 and it still wont work. I have also tried resetting internet explorer to no effect please help.
If that doesn't work check on network and sharing centre on your control panel and make sure your 100% connected to the internet.
If you are and my connecting up to the internet didn't work try contacting your internet provider.
Dr Reed
Feb 14, 2010 | Microsoft Internet Explorer 8
error problem
The issue you have posted regarding that you are unable to open and use the I internet explorer showing error message “ iexplorer.exe ” can not open and needs to close could be due to number of reasons, The steps mentioned below generally fixes these kind of issues I would appreciate if you could try them to get iexplorer.exe issue fixed.
FIX I.
  1. Click On Start, point to Internet Explorer and then right click on the Internet option and left click on properties.
  2. Click on the Delete tab under the (temporary internet files)
  3. Click on delete temp internet files after selecting delete all.
Fix II.
  1. Click on start, point to control panel and click on it.
  2. On the Control Panel window, locate the Add/Remove software icon and click on it
  3. Locate the option Add/Remove Windows Components on the left side of the window and click on it.
  4. Locate the Internet Explorer option form the list and remove the Check Mark in the box by clicking on it, then click NEXT at the bottom. (This will Uninstall the Internet Explorer)
  5. Click on finish.
After you perform the above mentioned steps, restart the computer.
After the computer is restarted and when it gets back to the desktop screen perform the following steps.
  4. Locate the Internet Explorer option form the list and then Check Mark box by clicking on it, and then click NEXT at the bottom. (This will reinstall The Internet Explorer)
  5. Click on finish.
Restart the computer and check if you are able to open the Internet Explorer works.
Fix III
This issue can also occur if you have installed any third-party internet tool bar for example, Google, Yahoo, or Rediff etc so you can uninstall the tool bar form the Add/Remove programs, however you will not have to go into the Add/Remove windows components option, the tool bar software will be displayed on the screen which comes up once you click on the Add/Remove icon in the control panel. All you need to do is to select the toolbar and click on remove in order to uninstall it.
Fix IV
  1. Click Start and select Run.
    The Run window appears.
  2. In the Run window, type msconfig and click OK.
    The system configuration utility Window appears.
  3. Click on the option Startup at the top right hand corner.
  4. Click on the option disable all at the bottom of the screen.
  5. Click on apply.
  6. The system will request to restart, click on restart and let the system restart by itself.
  7. Once the system restarts it will prompt you a screen after it logs in, stating that the startup has been modified and it asks you weather to show that screen again, so select do not sow the screen when logged in next time and close the window.
Should you require any further assistance regarding this issue or any other computer related issue in future please feel free to contact get back to us, we will be more than glad to assist you.
Regards
Malik Khan
Feb 01, 2008 | Toshiba Satellite A100-S8111TD Notebook
198 people viewed this tip
David Payne
David Payne
