Tip & How-To about Office Equipment & Supplies
HP All In One printer acting up?
There's a standard reset that takes the printer back to factory specs that you should always try first.
NOTE: this reset will erase any stored speed dials and fax numbers in the machine!!!
It's what techs refer to as a "pound six" reset. You'll see why in a second.
Disconnect the power from the printer
Press the # and the 6 together on the keypad
Reconnect the power to the printer
Wait for the display to say "Semi NVM reset" (or something like that) OR the printer will shut off.
When either of those occur, release the buttons on the number pad.
If the unit powered down, turn it back on.
The printer will now go through several minutes of gyrations and dancing about and will finish up with a calibration page.
This reset will fix MANY MANY different issues with HP printers, and if you call for tech support, it's usually one of the first things a tech will have you do - so save yourself that 30 minute hold time and do the reset first!
If you have a lot of phone numbers stored in the unit, and don't want to lose them but still want to reset the printer, you can do a partial NVM reset. It doesn't fix as many issues with the printers, but it's less destructive. It's the "pound three" reset.
You guessed it...do exactly as above, but use 3 instead of 6.
Some retailers may suggest to you that you do a pound nine reset if you call them for assistance. We don't know how they ever learned of the pond nine, but you should NEVER pound nine an HP All In One printer!!!
how do i factory reset my Samsung exhibit sgh-599n
  1. Select Home > Menu and then tap Settings > Privacy.
  2. Tap Factory data reset.
  3. Tap Format USB storage to erase all data stored on the device internal storage area.
  4. Tap Reset phone > Erase everything.
Mar 03, 2015 | Samsung Cell Phones
reset to factory specs for blackberry curve 8330
how to reset the Curve back to factory state (a complete wipe-out). Please note if you just want to reboot the device, you only need to take out the battery.
To reset the phone back to factory state:
Go to Options -> Security Options -> General Settings
Press the BlackBerry Menu key and select "Wipe Handheld" and type in "blackberry"
Thanks.
Jun 04, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
My krzr screen shows everything backwards!
Try a master Reset.
To perform a master reset on the handset, follow these steps:
NOTE: A master reset restores the original factory settings and can erase all downloaded content, including ringtones, camera images, contacts stored in the handset memory, and Java™ applications. It does not erase data stored on the SIM card or memory card. Back up all necessary data on the handset memory before proceeding.
  1. From the main screen, select Main Menu.
  2. Scroll to and select Settings.
  3. Scroll to and select Initial Setup.
  4. Scroll to and select Master Reset.
  5. Enter the security code.
    • NOTE: The default security code is 000000 (six zeros).
  6. Select OK.
  7. Select Yes.
  8. Press the red End pattlnk_5142007_1444-redend.gif key to exit and return to the main screen.
Dec 09, 2008 | Motorola Mobility MOTOKRZR K1 Cellular...
need help
Resetting the Memory/Clearing the NVRAM clear all Faxes stored
CAUTION! Resetting the memory/clearing the NVRAM will erase any saved phone numbers and restore the printer settings to the factory defaults.
Step Action
1 Power off the All-In-One.
2 Press and hold the number 5 button and turn the All-In-One back on. Keep the 5 button held down until you see the standard Copy menu. This should take 8-10 seconds.
3 Press the menu button and use the down arrow button to find option 11. Manufacturing Menu. Press the check button.
4 Press down arrow button until you reach option 9. Clean NVRAM. Press the check button. The printer will display Clearing and then restart.
5 You will be prompted to go through setup again.
Mar 13, 2008 | Lexmark X7350 All-In-One InkJet Printer
i forgot my privacy code, how do i reset my sidekick so that i can get passed the privacy code
Which Sidekick is it? A Master Reset will take care of it,.
  • NOTE: A master reset restores the original factory settings and can erase all downloaded content, including ringtones, camera images, contacts stored in the handset memory, and Java™ applications. It does not erase data stored on the SIM card or memory card (if available). Back up all necessary data on the handset memory before proceeding.
Dec 28, 2007 | T-Mobile Sidekick
1,934 people viewed this tip
k24674
jasbo
jasbo
