Tip & How-To about Microsoft Windows XP Professional
Install wmp11 bypassing wga( only for genuine users)
Locate the wmp install folder or extract the setup.exe
find LegitLibm rename it to legitlib
run setup
click validate
will say cannot validate
click finish and setup will continue
Microsoft Windows XP Professional Logo
hp 1402 fatal error and MSI.scan
Hi Ihan,
You are facing terrible problem with that error message.. However we can try to fix it. There are few methods you can do..
Solution 1.
  1. Insert the product software CD into the CD-ROM drive on the computer.
  2. Right-click Start and then click Explore . Windows Explorer opens.
  3. Locate and select the CD-ROM drive that contains the product software CD.
  4. Locate and double-click the Setup and then the Scan folders to open them.
  5. Double-click Data1.cab or Scan.cab to open the contents of that file.
Extract, rename, and save the filesLocate the following files, right-click them, select Extract , and save them to the Windows Desktop. Leave Windows Explorer open after extracting the files.
  • F1922_TWUNK_16.EXE.096CD9AA_35CA_455C_ADCB_36EF6B7F7892After extracting this file to the Desktop, right-click it and rename it to TWUNK_16.EXE .
  • F1923_TWUNK_32.EXE.096CD9AA_35CA_455C_ADCB_36EF6B7F7892After extracting this file to the desktop, right-click it and rename it to TWUNK_32.EXE .
  • F1928_TWAIN.DLL.096CD9AA_35CA_455C_ADCB_36EF6B7F7892After extracting this file to the desktop, right-click it and rename it to TWAIN.DLL .
  • F1939_TWAIN_32.DLL.096CD9AA_35CA_455C_ADCB_36EF6B7F7892After extracting this file to the desktop, right-click it and rename it to TWAIN_32.DLL .
Then you have to copy these files to C:\windows\system32 folder ( this means overwrite the files ) and try to install the software. it should work.
for better understanding check the link below.
MSI.SCAN Solution
Solution 2.
you need to remove all the HP Printer entry from Add/remove or Programs and features under Control panel.
Then download the latest software from HP website by clicking on the link below.
HP PSC 1402 Printer Drivers
Regards,
Suhail
Oct 19, 2011 | Office Equipment & Supplies
i have a compressed brian lara cricket 2007 but when i extrack it it's setup gone 0kb and it is not install sorry for bad english
Hello
What did you use to compress it?First try to create a new folder in my documents,then rename it to the name of your game.
Then run the extraction,but extract it too the new folder you just made.Once extracted to your new folder,open that folder and look for the exe file of the game or the setup file and install from there.
There is a possibility when you compressed the game it became corrupt or just didnt work.Try the above first though.
Mar 25, 2011 | Codemasters Brian Lara International...
mtp function problem
Samsung MTP function Problem Solution It really worked for me.
1.)first copy umdf.exe from "wmp11-windowsxp-x86-enu.exe" to your Desktop, two methods:
a)unpack wmp11-windowsxp-x86-enu.exe(ex:with TotalCommander->Alt+F9) and copy umdf.exe to your Desktop
b)run the wmp11-windowsxp-x86-enu.exe(if you run it will extract the %TEMP% folder)
Click Start -> Run -> %temp% [ENTER]
Press F3 and search for "umdf.exe"
Copy this file to your Desktop
Cancel the WMP11 Setup
2.)Rename the folowing files, just copy&paste into your Command Prompt:
rename C:\WINDOWS\system32\drivers\wudfrd.sys test_wudfrd.sys
rename C:\WINDOWS\system32\drivers\wudfpf.sys test_wudfpf.sys
rename C:\WINDOWS\system32\wudfhost.exe test_wudfhost.exe
rename C:\WINDOWS\system32\wudfsvc.dll test_wudfsvc.dll
rename C:\WINDOWS\system32\wudfx.dll test_wudfx.dll
rename C:\WINDOWS\system32\wudfplatform.dll test_wudfplatform.dll
rename C:\WINDOWS\system32\wudfcoinstaller.dll test_wudfcoinstaller.dll [ENTER]
3.) Now run the umdf.exe and re-install it. After it's finished connect your phone and your MTP problem is solved.
Oct 24, 2010 | Cell Phones
Set Up Error Report:AppName:setup.exe
1. Open Windows Explorer.
2. Follow this path C:\\ Program Files \\ Common Files \\ Install Shield locate the sub
folders Engine and IScript.
3. Rename (Right Click and choose "Rename" both folders example: Engineold &
IScriptold.
4. Close out of Windows Explorer and run setup again.
5. Apply the latest update patches from our website www.roxio.com.
www.roxio.com
Mel
Jun 07, 2010 | Roxio Easy CD & DVD Burning
WINTV
Hi, you can download the driver for the HVR-1600 from HERE
(53MB FIle)
Step 1 - Extract the Installer
Download the file to a suitable location on your computer, then extract it . Windows has built in support for zip files, if you right click on the file and select 'extract all' a wizard will guide you through extracting the directory.
Step 2 - Remove the previous software version (if necessary)
If you had previously installed the WinTV-PVR-1600 in your PC, browse to the folder you just extracted to (e.g. through My Computer) and locate a file called hcwclear.exe
Run HCWCLEAR.EXE and choose the options Remove All WinTV Drivers and Applications (Total Removal) and Search All .INF Files for Conflicting Hardware.
Note: wait until the black box has disappeared of its own accord before proceeding.
Step 3 - Reboot
Shutdown and reboot your PC.
IMPORTANT! Once rebooted, please do not cancel any 'Found new hardware' wizards. Also ensure that the original driver CD is NOT in the CD drive.
Step 4 - New Driver Installation
After Windows reboots, you will see some New Hardware Found prompts. For each one, please choose the following options:
4A) On the first page, select 'No, not this time' and click Next.
4B) On the next page, select 'Install from a list or specific location (Advanced)' and click Next.
4C) On the next page you will be asked 'Please choose your search and installation options'. Select 'Search for driver in these locations' and then specify the extracted folder (the folder you extracted in step 1).
Note: Specifiy the 'Driver' subdirectory if Windows cannot find the driver file.
Note: You can also click the Browse button and browse for the directlry created in Step 1.
4D) Keep clicking Next for the rest of the steps then Finish to end the Hardware Installation Wizard
Depending on the model WinTV board, you may see several New Hardware Found wizards. Follow the same steps for each.
Step 5 - Run Setup.exe
Run Setup.exe from the extracted folder (from Step 1). You will be presented with a list of things to install, leave all the default settings and click Install.
Once the installation is complete, all drivers will be installed and you should have a WinTV2000 icon on your desktop.
Apr 11, 2008 | Hauppauge WinTV HVR-1600 - ATSC HDTV...
1,182 people viewed this tip
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
