Tip & How-To about Computers & Internet
How to increase your Internet Connection Speed?
Go to this site to see your current internet speed:
www.speedtest.net
Pick a server, for example: SEATTLE, WA.
Remember the RESULT so that you will notice that this is working...
- FASTER WEB PAGE LOADING:
This tweak will help web pages load faster, it has no real effect on download speeds,
just helps your pc look up websites faster thereby speeding up how fast the page loads and making web-surfing more enjoyable.
Navigate to this registry entry and change the following settings:
For XP & 2K
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Servic es\Tcpip\ServiceProvider
For 98, 98SE & ME
HKEY_LOCAL_MACHINE\System\CurrentControlSet\Servic es\VxD\MSTCP\ServiceProvider
On the right for ALL OS's change these entries: (ALL values are HEXIDECIMAL)
DnsPriority = 1
HostsPriority = 1
LocalPriority = 1
NetbtPriority = 1
To change the value right click on the value and select modify and enter the values above.
here is another one.....
go to start>run>regedit>then go to HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Servic es\Tcpip\Parameters
right click anywhere in the left side of the window then select NEW DWORD, then input the dword name, after the new registry entry is made, double click it and input the dword value....
dword name- SackOpts dword value-00000001
dword name- TcpWindowSize dword value-0005ae4c
dword name- Tcp1323Opts dword value-00000003
dword name- DefaultTTL dword value-00000040
dword name- EnablePMTUBHDetect dword value-00000000
dword name- EnablePMTUDiscovery dword value-00000001
dword name- GlobalMaxTcpWindowSize dword value-0005ae4c
Computers & Internet Logo
How to stop videos buffering
Buffering is typically the result of a slow internet connection. This can be at your end of the connection, your ISP or the site you are viewing the video from. You can check your current speeds at http://speedtest.net Speedtest net by Ookla The Global Broadband Speed Test There isn't much you will be able to do to resolve this, if you are on a slow connection you may consider upgrading your internet connection
Nov 28, 2014 | Visual Land Prestige 7 ME-107-8GB 7" 8 GB...
speedtest.net speedtest.net
Speedtest.net is Internet speed checking site...you can also check the speed of the internet at here also www.scanmyspeed.com
it will show results in Mbps and MBps.
Nov 16, 2011 | Computers & Internet
Internet Speed Prob
Because the speed also depends on how fast the site you download from is. For the www.speedtest.net and similar it's always almost at the maximum possible for your line because they are using very small packets of data and they send them as fast as they can.
When you download something the packets are much larger and your line can't get them faster. There are some download managers that are capable to trick your line into thinking there are multiple downloads at the same time when in reality there's only one - so you will get a faster download speed - but very few sites support them. In the end, even with one of them, if your line is slow you wouldn't get too much speed increase.
Just try it and see.
Oct 03, 2009 | Computers & Internet
147 people viewed this tip
David Payne
David Payne
