Tip & How-To about CyberLink Power DVD 5.0 (cd-powerdvd5) for PC
Removing Cyberlink Power DVD Registration Pop Up
Are you using Cyberlink Power DVD version 6 or later.
these version keep popping the registration menu quite often which makes it somewhat annoying if you don't want to register it.
here is how to stop the pop up.
Close the Cyberlink Registration pop-up and shut down the program.In Windows XP, Go to "Start" > "My Computer" > "C drive".
In Windows Vista and 7, Go to "Start" > " Computer" > "C drive".Click on"Program Files" > "Cyberlink" > "Power DVD"> OLRSubmission".
Right-click on the "OLRSubmission" folder and choose "Rename".
Type"Submission" in the box and press "Enter" to set the name.
This will disable the pop-up.
CyberLink Power DVD 5.0 (cd-powerdvd5) for PC Logo
KEY FOR POWER DVD 6
my problem is i lost my key code for cyberlink power dvd 6 oem version and trying to get it back but i keep getting the deluxe version but i dont want the that because the version i have plays dvd&cd so can you help me?
Jul 25, 2010 | CyberLink Power DVD 5.0 (cd-powerdvd5) for...
UNABLE TO OPEN THE FILE UNDER POWER DVD 6
which file format you r trying to open in power dvd player.
powr dvd player doe not support all formats.
i will suggest you to download and use the vlc player,it almost supports all video formats
May 07, 2010 | CyberLink PowerDVD 6 Deluxe Full Version...
Lost CD-KEY for cyberlink powerDVD
hi,
Following is what , i gathered information from cyberlink source
What can I do if I lost my activation key?
Before contacting customer support, try to locate the activation key through the following steps:
If you have registered your products: If you have registered the software, you can log in CyberLink Members Zone and select Manage My Products in the left menu, and then click Manage CD-Keys tab. You will see all the keys you have registered before.
If you haven't registered the products: Retail or boxed versions: If you have a retail or boxed version, the CD sleeve/case should have an activation key sticker attached to it.
Online/Download version: If you have the online/download version, you can check your email inbox for your order confirmation e-mail. It provides you with the product key.
Bundled version: If you got your software free as a bundled version, the CD sleeve/case should have a sticker attached to it. If not, please contact the hardware supplier to get a new key.
If you still have no luck locating the activation key, you will have to register as a CyberLink Member and submit a technical support form to ask for a new key. You will need to attach a digital or scanned image (in .jpg format) of your installation disc as the proof of ownership of the original software copy.
Note: If you are reading this prior to having lost your key, then we strongly recommend that you register your software as this will keep your activation key safe and available if you ever need it. You can always find Online Registration shortcut in the CyberLink program folder of Windows Start menu
Sep 29, 2009 | CyberLink Power DVD 5.0 (cd-powerdvd5) for...
I have lost my serial key for power dvd 7.0 .can any one help me?
From their FAQ:
"What can I do if I lost my activation key?
Note: If you are reading this prior to having lost your key, then we strongly recommend that you register your software as this will keep your activation key safe and available if you ever need it. You can always find Online Registration shortcut in the CyberLink program folder of Windows Start menu."
http://www.cyberlink.com/prog/support/cs/faq-content.do?id=2325
Mar 12, 2009 | CyberLink Power DVD 5.0 (cd-powerdvd5) for...
unable to register cyberlink power dvd 6. reports no internet connection
When you first start your software, a registration dialog box will appear. All you have to do is submit your name and address to complete your registration.
If you have skipped that dialog, you can access it by the following steps (the following steps are based on Windows' Classic Start menu setup):
  • Click the Start menu of your computer,
  • select Programs,
  • select the CyberLink Product, and
  • then click Online registration
The same online registration interface appears. Submit your name, address and then click Register Now.
alfeild said-reports no internet connection-
is this on your connection or when you try to register your product.cyberlink.?
riz.
Aug 20, 2008 | Computers & Internet
2,408 people viewed this tip
Top CyberLink Computers & Internet Experts
Sunil Pratap Singh
Sunil Pratap Singh
Are you a CyberLink Computer and Internet Expert? Answer questions, earn points and help others
