Tip & How-To about Computers & Internet
How to rip a DVD easily
DVDs contain folders and files which are specially developed for DVD players and not for computers.
If you explore the DVD on your computer, you see on most DVDs the folders Video_TS and Audio_TS. The folder Audio_TS is on video DVDs empty. This folders is normally used for audio DVDs.
If you open the folder Video_TS you see that the extensions of the files in it are .vob, .ifo and .bup. The .vob files are actually the .mpeg or video files and only these files contain video. The .ifo files contain information like scenes and time. The .bup files are backup files of the .ifo files. These files aren't relevant for computers.
If you double click a .vob file and you do not have any DVD player installed on your computer, the computer says that it can not open the file. But there is a trick to do let your computer play this file.
The trick to play this file is to copy the .vob files to a folder on your hard drive. The next thing you need to do is to change the file extension into .mpg.
Do not change the name of the file but be sure you change the extension of it!
If you copy the .vob file and you change the extension in .mpg, there is no guarantee that it works. This depends on the codecs you have installed on your computer. But often this trick will work.
So what is the solution if the above doesn't work? The following I will show you how to rip a dvd.
Step 1: Download best free dvd ripper and running it. click "Add". It supplies four ways to load files:
Step 2: Select output Profile
You can select one output format you want to rip a DVD as below.
Step 3: Edit the Video
If you want to customize the video, Wondersahre DVD Ripper offers a powerful video editing function, including cropping video, setting the video effects, trimming movie, even customizing personal watermark.
Step 4: Start to rip a DVD
After you select the output format and edit the video(option), all you need to do is clicking the "Start" button. Then you can get a cup of coffee and come back later to check if the conversion is finished. Furthermore, this DVD Ripper even offers the option to automaticlly shut down the computer when the conversion completed.
Now, you must get the idear how to rip a dvd. Enjoy it!
Related topic: How to rip DVD on Mac.
Computers & Internet Logo
music folder is not detect
With a desktop computer and the USB cable you can transfer music to your SanDisk Sansa MP3 player. Simply hook the USB cable up to an available USB port and begin dragging music files to the folders of your SanDisk MP3 player1 Free a USB port on your desktop computer. Now, grab the USB cable for your SanDisk Sansa MP3 player and connect the player to your computer.
2 Wait for your computer to find and recognize the player. This may take a few moments. Once you receive a confirmation message, open your computer and scan the icons for the SanDisk MP3 player.
3 Open the SanDisk Sansa MP3 player on your computer. The music files that you currently have saved to the player's memory are displayed.
4 Open a folder containing music files that is stored in your desktop computer's memory. Scan the files for songs that you want to transfer to the SanDisk Sansa MP3 player.
5 Left-click on a song file and drag to the SanDisk Sansa window. Drop the file and let your computer complete the transfer. The transferred file appears at the bottom of your music list.
6 Unplug your SanDisk Sansa player from your computer. Turn the player on and allow the file transfer to update to the internal memory of the MP3 player.
Nov 19, 2011 | SanDisk Sansa E280 MP3 Player
I have prepared a home movie on Windows Movie Maker and when I copied it to a DVD it would not play on a dvd player can anyone tell me what I did wrong please thanks joe
The reason why the DVD disk you created may not contain the file format the DVD player recognizes. On a normal DVD disk there are two folders - AUDIO_TS and VIDEO_TS folders. The video files are located in the VIDEO_TS folder. This video folder contains the VTS_xxx.vob video files (the video files has a .vob extension).
The video file you created may have a avi or wmv or mov or mpg extension, whilst these video files can be played on a computer but they won't play on a DVD player.
Check the movie software you are using and make sure it creates the correct file format for a DVD player.
Jan 07, 2010 | ASUS Computers & Internet
ROOT
Root Folder/ Directory refers to the main Folder which contains all the important informations and commands your player has. It is similar to your Root Directory in your PC -- Drive C:/ where all the system files are located.
Root Directory includes sub folders such as your player's Master Boot Record (MBR - very crucial, this is the boot operating system), music file directory, audio record directory, data files directory such as organizer and phone directory (if your player has one).
Root Directory is very important for your player's performance as it contains all the valuable informations and commands so your player would run under normal condition. Once everything was erased in that root folder, you'll render your player useless. So be extra careful when you upgrade your player's firmware as this erases all files including those the OPERATING SYSTEM in the root folder.
It is safe however to format within your player as this erases only your data files and music. Just to be sure, avoid formating your player in your PC's MY COMPUTER/ WINDOWS EXPLORER unless it is specified in the users manual.
Luckily, MBR are usually erased when you entered your player's SERVICE MODE and you choose to erase the Firmware using some special keys. So, as long as you're using your player as mentioned in your users manual, you're okay with it. If you doesn't know all about mp3 player repairs or upgrades, leave the SERVICE MODE or PLAYER RECOVERY to the technicians.
MANNY DE GUZMAN, JR.
aka "TECH DATA"
SoundMagik Home Studio
Manila, Philippines
Visit my website: http://mannydeguzmanartist.wetpaint.com
My talents/ modeling site: http//teenmodels2007.wetpaint.com/
My YouTube Channel "mannydeguzmanjartist":
http://www.youtube.com/user/mannydeguzmanjartist
My imeem.com social media channel "mannydeguzmanartist", where all my music editing, remixes, creations, and voice demos can be found: http://mannydeguzmanartist.imeem.com/
Mar 31, 2008 | Alba DVD55 DVD Player
How to upload files from MP3 player to computer
Hi. To upload files from your E260 to your computer, you can do the following: Step 1: Browse the player on your Windows Explorer. Under "Windows Explorer", your player should appear as an icon under "Portable Audio Devices" or as a "Removable Drive" with a corresponding drive letter. This really depends on the mode your player is in -- MTP or MSC mode. Step 2: Set your Windows Explorer to "Show Hidden Files or Folders". The folder containing your music files on the player is a hidden folder, so make sure you go to "Tools" menu on your Explorer window, then select "Folder Options", then select the "View" tab, then enable the "Show Hidden Files and Folders" radio button Step 3: If your player is set to MTP, you would find the sub folder called "PPI NAND". Open this folder and you would see a list of sub-folders, one of which is labeled "Music". Open that and you would see your music files If your player is set to MSC, open the drive letter corresponding to your E260 and you see a list of folders, one of which is labeled "Music". Open that and you would see your music files. Step 4: Select the music files you want and copy them to your local hard drive I hope the info helps.
Apr 25, 2007 | SanDisk Sansa e260 MP3 Player
242 people viewed this tip
David Payne
David Payne
