Tip & How-To about Cell Phones
How to Hard Reset an iPhone
Owners and users of the Apple iPhone generally report loving the phone, but they also report frequent lock-ups where the screen suddenly freezes or goes black altogether. Some report success solving the problem with a soft reset or the holding down of the sleep/wake and home buttons for the 10 second reset requirement. If this does not work, a hard reset is required to bring the iPhone back to life.
Instructions
  1. Update iTunes to version 7.4 or higher from the Apple website if you haven't already.
  2. Connect the iPhone to your PC. You are automatically taken to the sync management page, and iTunes automatically begins syncing, or copying/backing-up the calendars, Internet bookmarks, contacts and e-mail accounts stored on the iPhone. Sync everything on the phone or pick and choose from the menu you're given. Sync everything on the iPhone you don't want to lose, because a hard reset restores the iPhone to its original state and all data added since it was first taken out of the box is lost.
  3. Go to the "Summary" tab at the top of the screen and select "Restore" from the drop-down menu.
  4. Wait as the iPhone hard resets. The iPhone comes back up in it's original factory state and a prompt appears asking if you want to restore data settings.
  5. Select "Yes" to restore the synced data to the iPhone.
Cell Phones Logo
iphone locks up
Try doing a hard reboot by pressing the top right button and the home button at the middle bottom.
Sep 09, 2009 | Apple iPhone 3G
Apple iPhone Battery Saving Guide The Apple iPhone doesn't have the best battery life in the world but if you follow this simple guide it should provide you with a longer battery life. 1. Turn down the brightness: You can reduce the battery consumption by turning down the brightness of the screen. Select Settings, Brightness, and then drag the slider to around the 25 percent mark, or as low as you can stand. 2. Turn Wi-Fi and Bluetooth off: From the main menu, tap Settings, Wi-Fiand select the "Off" switch. Same goes with Bluetooth; if you're notusing a Bluetooth headset, make sure the Bluetooth radio is deactivated(Settings, General, Bluetooth). 3. Check e-mail less frequently: If you are using Pop Mail then you can save battery by checking it less frequently. Select Settings, Mail, Auto-Check, and pick either the "every 30 minutes" or (better still) "every hour" options. 4. Sync less frequently: If you sync with an Exchange server either turn it to manual or set it only to check periodically 5. Make sure "Auto-Lock" is on: TheiPhone will keep its bright screen burning unless you manually pressthe lock/sleep control. If you haven't already, make sure the iPhone's"Auto-Lock" feature is on: tap Settings, General, Auto-Lock, and then pick a time interval (the shorter the better). 6. Turn off the equalizer: Apple has always suggested turning off the iPhone?s built-in equalizer to conserve battery life. Tap Settings, iPod, Equalizer, then spin the roulette wheel up to Off.
Dec 23, 2009 | Cell Phones
sync
While the iPhone certainly isn’t the first mobile handset to suffer from freezes, its functional breadth and the fact that many of its users install unsupported third-party applications make the device, generally, more freeze-prone.
settings can result in a reduction in or complete elimination of freezes:
  • Tap Settings on the home screen. Tap General. Tap Auto-Lock. Set to “Never.”
  • Tap Settings on the home screen. Tap Brightness. Turn Auto-Brightness off.
Oct 13, 2008 | Apple iPhone 3G
189 people viewed this tip
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
