Tip & How-To about Cycling
GXP Integrated Bottom Bracket Adapter
Cycling Logo
Slow and tight Sram red Crank
I'm sorry, but if you don't know how to order the correct BB or properly install it you should not be building a bike from scratch, as this is probably the first of many problems you will have. As for YouTube it's not a reliable source of technical info. Try this site: http://www.parktool.com/blog/repair-help
OR Contact the frame seller and find out what BB the frame takes or contact the seller of the BB and ask for assistance.
Jul 28, 2017 | Sram Red
Installed new front sram x9 trigger shifter & its overshifting
You might have to consider changing your bottom bracket for one with a longer shaft. Examine your chain line and do some research here:http://www.parktool.com/ and also here:http://sheldonbrown.com/gearing/index.html
Oct 15, 2009 | Cycling
SRAM FORCE crank lock
If it won't pedal you probably have a broken bottom bracket. This needs to be done in a bicycle repair shop as you need the right tools to disassemble it.You will also need the exact replacement parts as they come packaged with the kit and diagrams for installation. Sorry I'm not more help.
Jun 04, 2009 | Sram Force Crankset 53/39
635 people viewed this tip
Top Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
