Tip & How-To about Computers & Internet
To Connect Your Phone to Your Computer
In today's world we use mobile phones to all the PC connection, connecting the phone to our PC, we can dial your modem and connect to your ISP, intranet or any other network. In most cases, simply connect your phone to your computer, you can use telephones to the network including the Internet, and services.
Before you begin, it might be a good idea to contact your mobile provider and ask what services you have available, because some providers do not completely block these services, contact information, and you could be (ie, login, password , etc.).
BlueTooth: "Wireless PC Connections"
After checking with your phone provider to find out what services you have:
Verify that the Blue Tooth is active and detect your mobile device.
Blue Tooth Open control panel located on your PC.
On your PC, select "search phone", then select your mobile device and click the button "Pair."
Enter a "new" password, then enter "same" password on your mobile device when prompted.
When prompted on the PC, select the connection type and Internet connection information for your wireless service provider or ISP.
USB: "Data Cable"
Again, after an adjustment for operator services available to you:
If you have software that works the phone with the software. You may have to skip the rest of these steps.
Connect the data cable to the back of the phone and the other to a USB port on your PC or laptop.
If you are prompted to select the "how" to connect.
If you do not have software installed on your mobile device let your PC, check if it is unable to install the correct driver.
It may be necessary to access the device from your computer as a "Drive" and then examine it in a folder ..
As with all the information I can not guarantee the net this article 100% accurate, or even ensure that the information will not destroy the mobile device when you try to attach it to the Internet. This article was meant to be a brief overview of a typical outreach activities.
Computers & Internet Logo
how can connect internet on our pc with aircel sim
First load the mobile softwares on your PC from the CD
Once the necessary softwares are installed connect your phone through data cable
then follow below given procedure
Go to Start > Settings>control panel> double click on phone & modem
New pop up window opens.in this window got to Modems tab and select the phone modem which would be visible there.
click on the properties and then on diagnostics
click on query modem in new window and wait for some time to get response
You should see that AT command SUCCESS in the command response text area. If doesnt get any response check your phone or contact your phone manufacturer.
Now got to advanced tab in same window and put extra initialization commands given below:
AT+CGDCONT=1, "IP", "aircelgprs"
Now Modem installation complete
Create Dial up connection for Aircel:
Go to My Network Places ,click on it
click on View Network connections
go to create new connection
select connect to internet
select "Set up connection manually"
select connect using Dial up
select mobile handset Modem
Click next and put ISP name as Aircel
?ยท In next window put *99***1# as dial number
Leave The User Name, Password and Domain Fields Blank and select make this default connection & shortcut to desktop and click Finish.
Now you can connect through dial up.
Dec 20, 2010 | Computers & Internet
my samsung mobile is 'GT C3050C'. I install it pc studio, but I cannot use it by modem, I live in Bangladesh, I wanna to know it configuration,
2. Connect Your Samsung with a working Internet connection ( via )USB Cable
3. Samsung PC Studio or any other Samsung mobile drivers are not installed
Procedure
1. Connect your Samsung Star 3G to your PC and install the modem drivers that you have downloaded.
2. Goto Control Panel > Phone and Modem Options
3. Select the Modems tab. You will see Samsung mobile modem listed.
4. Select it and click on Properties.
5. Goto the Advanced tab and put the following in the box for Extra Initialization Commands:
+cgdcont=1,"IP","your_apn_name"
( or tye AT+CGDCONT=1, "IP', "apnname")
eg:- +cgdcont=1, "IP", "bsnlnet"
6. Hit OK and exit.
The next step is to create a dialler for your Samsung Star 3G mobile modem.
Error 619 solved
1. To create a dialler, Goto Control Panel>Network Connections
2. Hit Create a New Connection and proceed as follows (each sub-point is for each screen of the wizard):
2.1 Network Connection Type: Connect to the Internet
2.2 How do you want to connect to the Internet: Set up my connection manually
2.3 Select Connect using a dial-up modem
2.4 Select Modem-Samsung Mobile Modem
2.5 Type an ISP name according to your preference (could be anything)
2.6 Type*99# as the phone number ( or type *99*1*1# or *99***1# )
2.7 Leave Username, Password and Confirm Password fields blank
2.8 Hit Finish
That would complete the wizard and make a dial-up connection for you. Dial it and you will be connected to the Internet via your Samsung Star 3G phone modem without using Samsung PC Studio.
Nov 21, 2010 | Samsung Modem Configuration Software...
I am using samsung 3g metro gt-s5350 with MTNL sim. I am able to surf the net on the mobile but not able to use it as modem for using internet for my laptop. It is showing "os error, remote device not connected" . Please help
Samsung PC Suite - Internet through mobile modem -Error 619 - Data Cable
Rectifying the error
1. Samsung USB modem driver (Download from Samsung ' Local Link)
Procedure
6. Hit OK and exit.
Error 619 solved
2.8 Hit Finish
Nov 08, 2010 | Samsung Modem Configuration Software...
I want to connect laptop for internet using with my samsung Champ GT-C3303. So I need PC suite for samsung Champ GT-C3303 mobile
you need to download samsung kies software.. and install it. then automatically the required drivers will also be installed.. then follow the instructions as below..
NOTE: following instructions are for tata docomo internet. names may vary depending on your mobile network.
you just connect with bluetooth or data cable and find out the modem then u goto control panel ->phone and modem option then dialing rules tab ->new -> country/religion fill India and area codeand then ok. and then goto same dialog box in modem tab n select modem click ->properties and then advance tab n fill in extra initialization commands: AT+CGDCONT=1,"IP","TATA.DOCOMO.INTERNET" and then ok.
goto control panel ->network connection ->create a new connection ->new connection wizard next ->choose connect to the internet ->next ->choose setup connection manually ->choose connect using to dial-up modem ->next ->isp name -tata ->next ->phone number- *99# ->next ->next ->finish
then you a dialing tata icon in the desktop and you r connect internet in your pc
Sep 17, 2010 | Samsung SGH-D900 Cellular Phone
for download modem driver
hi all,
I am also having the same mobile.. Today only i find the driver and pc suite... i am sharing with you also for easy of working..
Steps:
1) Go to www.lgmobiles.com
2) Click GSM Mobile Phones Spec & PcSync
3) Select Your phone model as LG KG 195 in PC Sync Program
4). Then it automatically asks the location for downloading the pc suite
5) Unzip the file and click PhoneSuite
6) Click Settings and go to create connection
7) fill the appropriate settings which is stored in your mobile
8) Then click create and it will create an modem for your connection.
8) Connect your mobile to PC.
9) Open the PhoneSuite again and click settings and go to dialup
10) You will see the modem which you created. Select that modem and click dial-up.
That's all, your pc will be connected to the internet. If you are having any queries mail me at dharan415@gmail.com
The speed of lg mobile is high compared to nokia....
Enjoy surfing... Its a good mobile at cheap price.....
Bye all....
Oct 02, 2007 | LG KG800 Cellular Phone
284 people viewed this tip
David Payne
David Payne
