Tip & How-To about Video Game Consoles & Games
How To Fix Scratches With Toothpaste
One of the worst thing about buying a used video game is worrying about scratches? In fact sometimes the scratches are so bad that your system will no longer recognize the game. I've been in this similar situation and though I wasted my money. However then I tried the Toothpaste Trick and I have been recommending it ever since.
The first thing you want to do is get some white toothpaste. You can try the other types or brands but I recommend regular white toothpaste. From there apply toothpaste to where the scratches are on your disc. Use a toothbrush or cloth and apply the toothpaste to the scratches. Make sure to be careful and avoid getting toothpaste near the center of the disc.
Once the toothpaste is on those scratches wait about 5-10 minutes. Once time is up go back to your disc and begin removing the toothpaste. You can try using another cloth however the toothpaste might be sticky. Get another cloth and apply a very tiny amount of water onto it. Use the wet cloth again to remove the toothpaste and then use a dry cloth to make sure the disc is try. Wait another 5 minutes to complete the process.
After that, your all finished! Your disc should be working good as new again and it only took a few minutes. Finally as stated earlier, be careful doing this. Make sure that you've tried other options such as simply cleaning the disc with a cloth before trying this trick. It should be used as a last resort.
Video Game Consoles & Games Logo
I accidently shook my xbox 360 while it was running and now my modern warfare 2 game got screatched is there a way i can use it again?
It depends how badly scratched your Modern Warfare 2 disk is. There are scratch repair kits, but they can only do so much. If a scratch repair kit doesn't do the trick, take your disk to a place like Best Buy or Gamestop. They have professional solutions to fix your disk. Beyond that, you can always try calling up the game developer. They sometimes have warranty for scratched disks.
May 01, 2011 | Video Game Consoles & Games
my xbox messed up my games modenr warfare and 2k11 and it wont play them anymore what can i do about this?
Unfortunately once a disk is scratched there isn't really anything you can do about it. Most of the things that promise to fix scratched disks are fake and scratch them worse. I would suggest buying a used copy of the broken games, and avoid moving your xbox with disks on them. Also, if you have a friend with the same game, borrow the disk, install it to your harddrive, and try to run it with your scratched disk. Sometimes if it is installed to the harddrive it will run even if the disk is scratched.
Mar 21, 2011 | Video Game Consoles & Games
my game starts then then the game stops and it says clean disk
this could be due to the fact that the lens is covered by some dust particle or your disc is badly scratched and cannot be read properly by the console.the best thing to do is to search for which cd cleaner is the best to use and at the same time try cleaning the surface of the disc
Nov 03, 2010 | Video Game Consoles & Games
noisy disc drive - has badly scratched disc in one place.
if you have your xbox standing up then you want to lay it down, i had this problem if you move your xbox when there is a disk in it, it will make a sound and scratch the disk. the best thing to do is to lay it down on a surface such as a table not the floor, if it still scratches your disks go into the place you got the game from and say your xbox scratched t and wont work anymore, they should give you a new game. if you tried this and it still does it then the best thing to do is to ring up microsoft for repair.
Jan 21, 2009 | Microsoft Xbox 360 Console
366 people viewed this tip
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
