Tip & How-To about Crafts & Hobbies
Stainless Steel for Projects
There are advantages in using stainless for brackets and metal plating or even as shims. You can get a cheap source of Stainless metal by going to Garage sales and Estate sales and buying used Silverware.
In particular, knives are handy for shims and reinforcement of weak parts. You can drill needed holes and also cut the blade to the length you need.
The spoons can be used to stir or mix chemicals. The forks can be detined to a single probe and used to punch reset buttons or release Electric connector tabs.
Sometimes you can make a single purpose tool better than anything you can buy using this idea.
Crafts & Hobbies Logo
LG6810 Dishwasher
Here is one source:
http://lge.andrewselectronics.com/lookup.aspx
I have provided the LG part numbers for the parts you are requesting. The vendor may need to convert those numbers to their own system.
Third item on the list should be: BRACKET, MOUNTING WITH SCREWS KIT --> LG part description and number: "ACCESSORY ASSEMBLY" 5001DD4001A
The lower cover assembly for Stainless part number is: 3551DD2001C To maintain quiet operation, recommend you order the "Lower Felt" part number 4766DD2004A
Good Luck!
Apr 06, 2009 | LG LDF6810 Built-in Dishwasher
Want to replace dishwasher panel with stainless steel
I'm not sure if that replacemetn part would work, but I know you can get cheap stainless panels and faux stainless options at applianceart.com. They have colors, textures, seasonal, designs, and stainless steel. You can choose between faux stainless (as seen on HGTV and the Today show) or regular stainless metal. check out www.applianceart.com
Jan 19, 2009 | Kenmore 13593 Stainless Steel Built-in...
KITCHENAID DISHWASHER DOOR PANEL
www.applianceart.com has many options for you to choose from. They sell many different panels to put on your dishwasher. If you call them (678-727-4747 x32) they can also send you a metal stainless plate that is easily installed. I think the metal ones are around $99.99 and the other options are $39.99
Sep 19, 2008 | KitchenAid 24 in. KUDI02IRBS Stainless...
709 people viewed this tip
Top Crafts & Hobbies Experts
R.A. Ellis
R.A. Ellis
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Craft and Hobby Expert? Answer questions, earn points and help others
