Tip & How-To about Computers & Internet
Battery life extension
All batteries lose their capacity to hold a charge over time, but how you take care of them can affect how quickly this occurs. To keep batteries better for longer, try to drain them nearly all the way before charging, and charge them fully every time. If you're not going to be using the battery for a while (a couple weeks or longer) drain it to about 80% before storing it. For laptops and other devices that often stay plugged in, fully drain and charge the battery about once a month. Doing these things can help slow down the degradation of the batteries in your gadgets.
Computers & Internet Logo
battery on computer dies too quickly
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Feb 17, 2013 | Toshiba Computers & Internet
Fully charged battery not holding for a full day
If the cell phone battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Dec 05, 2011 | Samsung Cell Phones
why its battery quickly drains
Jul 18, 2011 | Motorola Mobility C168 Cellular Phone
The discharge of the battery do not occur normally. It is observed that while discharging it suddenly drops from 90% to 4%.
Ifthe laptop battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
Dec 14, 2010 | Acer Aspire One PC Notebook
new battery loses charge to quickly only lasts 24 hours have tried another still the same problem have fitted phone cover
For better battery performance, perform the following tasks,
1. Switch off the bluetooth. If needed put into hidden mode.
2. Switch off the wifi netword scanning (if applicable)
3. Reduce the screen brightness.
4.While keeping in pocket, take care to ensure that the mobile screen not at all touched or pushed inside pocket even though the screen is locked.
5. Charge th emobile phone for continuous 5 hours and dont charge until fully discharged. Follow this for atleast 5 times.
Then you can see the improvement in batery backup time.
I hope this is helpful to you
Dec 31, 2009 | LG KU990 Viewty
229 people viewed this tip
David Payne
David Payne
