Tip & How-To about Computers & Internet
You Can Get Rid of Your USB, Really.
It's hard to believe that only 10 years ago, there were still people using floppy disks, and now we are using USB drives with capacities as big as 64GB! Though the reason for the USB has been fast speed, reliability, and the amazing amount of space it can hold, it definitely has its downfall. Many people either lose it, or forget about it - which can put you in a tough situation at times.
With the widespread availability of the Internet, your USB may have its days numbered. Here are four different things that can replace your USB drive.
Case 1: Let's say you're a college student that's been working on a term paper at home and have no printer. You spend all night on it and finally you are done. You could put it on your USB drive, or you could actually email it to yourself. Emails can now hold attachments of considerable size, GMail has about 25MB available for each email. After you email the paper to yourself, you can go to school, log in to your email and print it out. You no longer have to worry about forgetting something at home, and you just saved yourself from getting a printer (or using your printer ink at home).
Case 2: Let's say you always have around 1GB of stuff you always need with you - professional photos for your art portfolio, or essential programs you need to always install on a client PC. You can store up to 2GB of stuff on a free account with Dropbox. Wherever you go, as long as you have a WiFi connection you can access your files. Even better, they have apps for the Andriod and iPhone/iPod touch. That way, you can always check your files On-The-Go! http://www.dropbox.com/
Case 3: What if you want to back up a lot of stuff. Like ALOT. OF. STUFF. If you have a hotmail or MSN account, you can easily use SkyDrive. It's Free. It's 25GB of space.
Case 4: If you want to backup EVERYTHING and I mean EVERYTHING. You can sign up for a free account on Mediafire. Mediafire allows you UNLIMITED storage. Each file needs to be under 200MB (use Winrar to break a file into parts), and files cannot be password protected (but you can make your files private). Make sure you sign up with an email account that you do use. When you haven't logged into your account for almost 90 days, you will be sent an email to ask you to log in. If you don't log in after 90 days, your files are gone forever.
So as you can see, there are tons of different free options to use to store your files - and you can access them anywhere! Try your hand at it!
Computers & Internet Logo
where is the floppy disc on my acer SA80 - Z970
I doubt you have one. Computer manufacturers have not been installing floppy disks for some years now.
Jul 07, 2011 | Computers & Internet
What is a portable USB (2.0) hard drive ??? Is it just a big USB ? Please tell me everything about USB (2.0) hard drive.
First of all, USB is an interface, that can be used for various computer peripherals, like a mouse, keyboard, printer, storage devices etc. Additionally, the USB interface is able to deliver some power (5V 500mA), which is quite enough for many devices. USB 2.0 is the newer, faster version of the original USB 1.1 specification.
Now for USB storage. Basically there are two types on the market. First are Flash (solid-state devices), usually in form of a "dongle" (called pendrive, stick). They store information in semiconductor memory. Second are hard disks, just like the ones installed in desktop and laptop computers - they store information on magnetic media.
Hard disks in a small enclosure, equipped with special interface, that enables them to be connected via the USB interface, are "portable USB hard drives". Many of them can be powered from the USB socket alone, some need an additional power supply.
With today's technology, hard disks can have 10-20 times larger capacity than flash devices, so they are still indispensable when you want to store a lot of big files (like pictures, movies etc), or back up the contents of your computer's hard drive as a safety copy.
Nov 22, 2009 | LaCie External USB 2.0 500GB 7200 RPM 500...
IE DATA 702 fdd
Hello
I beleave it uses a HD/DD type of disk
Abbr.
Floppy Disk Type
Capacity
Info
SS/SD or 1S/1D
Single Sided, Single Density
100 K
First generation. Capacity varies
SS/DD or 1S/2D
5-1/4 inch Single Sided, Double Density
180 K
DD/DD or 2D/2D
5-1/4 inch Double Sided, Double Density
360 K
Most common type in the early 1980's
DD/HD or 2D/HD
5-1/4 inch Double Sided, High Density
1.2 Mb
DD
3.5 inch Micro Floppy, Double Density
720 K
Hard plastic case
HD
3.5 inch Micro Floppy, High Density
1.44 Mb or
2.88 Mb
Hard plastic case
May 05, 2008 | Ye Data YD-702D (850416000107) Internal...
IBM 3.5 Diskette/1.44 MB Capacity/IBM Formatted. Won't open.
replace the floppy drive it sounds as if the drive motor is bad the hum is a inactive drive motor when a floppy is good it will usualy click as it comes on along with a green indicator llight
Dec 09, 2007 | Maxell MAX556437 3.5" Diskettes, IBM...
245 people viewed this tip
David Payne
David Payne
