Tip & How-To about Computers & Internet
How to reset the System Management Controller (SMC) - Intel based Macs
Intel-based Macs: Resetting the System Management Controller (SMC)
In some situations, you may need to reset your computer's SMC. Learn how to identify these conditions and reset the SMC.
The System Management Controller (SMC) is a chip on the logic board that controls all power functions. If the computer is experiencing any power issue, such as not starting up, not displaying video, sleep issues, or fan noise issues, resetting SMC may resolve it. To reset SMC:
1. If computer is on, turn it off by choosing Shut Down from the Apple menu.
2. Connect power adapter to computer and to a working power source.
3. On built-in keyboard, press (left-side) Shift-Control-Option along with power button just once. Important: Use Shift-Control-Option keys on left side of keyboard.Note: When the LED on the MagSafe connector is orange/amber, resetting the SMC will change it to green for a few seconds, indicating that SMC was correctly reset.
4. Wait 5 seconds and press power button to start computer. Note: If bottom case is removed, you can alternately reset SMC by disconnecting both power adapter and main battery, and holding down power button for 5 seconds.
Computers & Internet Logo
WPA for Apple MacBook pro
Mac computers have always been known by being stubborn in wifi matters. Please try the basic steps, like reset SMC, most of the times it sorts this issues. If problem persists and you have access to the router, make sure you have WPA2 Personal AES.
Reset SMC:
Intel based Macs Resetting the System Management Controller SMC
To read more about the best WIFI settings for your Mac:
iOS and OS Recommended settings for Wi Fi routers and access points
Hope it helps,
Alex
Sep 05, 2014 | Apple MacBook Pro Laptop Computer with...
previous shutdown 128
A negative shutdown code may be from a hardware problem. (The codes are not publicly documented.)
Please, backup your system and important data before doing anything.
It could be from heat buildup, if your vents look clogged with dust, turn off your computer, then, gently vacuum or blow out any dust or other obstructions from the vents on your computer.
If you have an Intel based Mac, try this:
If this doesn't work, please consult an Apple Genius Bar:
Apple Retail Store Genius Bar
May 09, 2014 | Apple Mac OS X
reset macbook pmu
An Intel-based MacBook uses an SMC rather than a PMU. If you need to reset the SMC, follow these instructions. Intel based Macs Resetting the System Management Controller SMC
Dec 21, 2013 | Apple MacBook MB403LL/A White - 2.4GHz...
785 people viewed this tip
David Payne
David Payne
